Foros 3DPoder.
Bienvenido a Foros 3DPoder..
¿Te ayudo?
Retroceder   Foros 3DPoder. > :: Infografia y diseño grafico. > Script
google adsense
Respuesta
Herramientas
Antiguo 22 sep 2007   #46
damiles
El Programador
Predeterminado Re: Sugerencias Script para blender
A primera leida si que está, esta por el final ya no digo mas XD
damiles is offline   Responder Con Cita
Enlaces patrocinados
Antiguo 22 sep 2007   #47
fog
Environment Artist
Avatar de fog
Pos sera que es mouseInView3DWindow no?
Si estoy intentando meter un objeto en 2d, pero era para probar ir testeando cosillas
__________________
Blog
Antiguo 22 sep 2007   #48
fog
Environment Artist
Avatar de fog
He encontrado esto, que es para pasar las screen coords a world coords
Código:
#dehomonogizes a vector
def dehom(v):
    ret = Vector(v[0]/v[3],v[1]/v[3],v[2]/v[3])
    return ret
#takes the inverse of a matrix and returns it
def inverseMatrix(m):
    ret = Matrix([0,0,0,0],[0,0,0,0],[0,0,0,0],[0,0,0,0])
    det = m.determinant()
    for i in range(4):
        for j in range(4):
            temp = Matrix([0,0,0],[0,0,0],[0,0,0])
            col = 0
            for x in range(4):
                if x != i:
                    row = 0
                    for y in range(4):
                        if y != j:
                            temp[col][row] = m[x][y]
                            row = row +1
                    col = col +1
            tdet = temp.determinant()
            total = i+j
            if (total % 2):
                sign = -1
            else:
                sign = 1
            #i and j are flipped
            ret[j][i] = (sign * tdet) / det
    return ret
#grabs the depth of a pixel from a depth buffer
def getPixelDepth(x,y):
    z = BGL.Buffer(BGL.GL_FLOAT, [1])
    glReadPixels (x,y, 1, 1,
              GL_DEPTH_COMPONENT, GL_FLOAT, z);
    print "value from depth buffer is",z
    return z[0]
#screen_x and screen_y are from Window.GetMouseCoords()
#screen_z is from a call to getPixelDepth(screen_x,screen_y)
def transSC2WC(screen_x,screen_y,screen_z):
  found = 0;
  #clip taken from letter rips code
  for win3d in Window.GetScreenInfo(Window.Types.VIEW3D):
      # we search all 3dwins for the one containing the point
      #(screen_x, screen_y) (could be the mousecoords for example)
      win_min_x, win_min_y, win_max_x, win_max_y = win3d['vertices']
      # calculate a few geometric extents for this window
      mid_x = (win_max_x + win_min_x)/2.0
      mid_y = (win_max_y + win_min_y)/2.0
      width = (win_max_x - win_min_x + 1.0)
      height = (win_max_y - win_min_y + 1.0)
      # check if screencoords (screen_x, screen_y) are within the 3dwin
      if (win_max_x > screen_x > win_min_x) and (  win_max_y > screen_y > win_min_y):
          found = 1
          break
  if(not found):
      print "Not Found!"
      return 0, 0, 0
  coords = Vector( 2* ( screen_x - mid_x)/ width,
        2*(screen_y - mid_y)/height,
        2*screen_z - 1,
        1.0)
  persp = Window.GetPerspMatrix()
  invpersp = inverseMatrix(persp)
  newcoords = coords*invpersp
  newcoords = dehom(newcoords)
  return newcoords
__________________
Blog
Antiguo 24 sep 2007   #49
Klópes
12 meses, 12 pagas
Avatar de Klópes
Cita:
Escritos por fog Ver Mensaje
Vale, a partir de eso yo he hecho esto, que pone un objeto vacío al pinchar. Para que funcione hay que activar Enable Script Links, y en la ventana 3D>View>Space Handler Scripts>nombre_del_texto
Código:
# SPACEHANDLER.VIEW3D.EVENT
import Blender
from Blender import *
from Blender.Window import *
evt = Blender.event
def transSC2WC(screen_x,screen_y):
  found = 0;
  for win3d in GetScreenInfo(Types.VIEW3D):
          found = 1
          break
  if(not found):
      return 0, 0, 0
  coords = Mathutils.Vector( 2* ( screen_x - mid_x)/ width,
        .0,
        1.0)
  persp = GetPerspMatrix().invert()
  co = coords*persp
  co = Mathutils.Vector(co[0]/co[3],co[1]/co[3],co[2]/co[3])
  return co
if evt == Draw.LEFTMOUSE:
	mc=GetMouseCoords()
	o=Object.New('Empty')
	o.setLocation(transSC2WC(mc[0],mc[1]))
	Scene.GetCurrent().link(o)
	Redraw()
__________________
Y sus discípulos le preguntaron, diciendo: ¿Qué significa esta parábola? Y él dijo: A vosotros os es dado conocer los misterios del reino de Dios; pero a los otros por parábolas, para que viendo no vean, y oyendo no entiendan.
Mateo 8, 9-10
Klópes is offline   Responder Con Cita
Antiguo 24 sep 2007   #50
fog
Environment Artist
Avatar de fog
Otia Klopes!!!
Magnifico!! Lo de 3D>View>Space Handler Scripts>nombre_del_texto no lo sabia!!!
Con eso activas el spacehandler no?
Muchas gracias Klopes!!
__________________
Blog
Antiguo 24 sep 2007   #51
SHAZAM
Administrador
Avatar de SHAZAM
No se si existe en Blender porque nunca lo he necesitado pero ayer viendo la página de Modo vi una herramienta que me gustó, a ver que opináis al respecto:
Luxology - Video
__________________
Victor Navone
SHAZAM is offline   Responder Con Cita
Antiguo 24 sep 2007   #52
damiles
El Programador
Perdona por mi ignorancia en estos temas, pero ese resultado no se obtendria igualmente aplicando un extrude sobre todo el objeto y luego un subsurf???
Antiguo 24 sep 2007   #53
Klópes
12 meses, 12 pagas
Avatar de Klópes
Cita:
Otia Klopes!!!
Exacto.
Estoy buscando cómo detectar que estás pinchando sobre un objeto.
__________________
Mateo 8, 9-10
Antiguo 24 sep 2007   #54
damiles
El Programador
Dios Python y blender me parecen un misterio para mi xD, bueno tampoco lo he mirado, pero ahi esta el señor klopes para enseñarnos.
Antiguo 24 sep 2007   #55
Klópes
12 meses, 12 pagas
Avatar de Klópes
Cita:
Escritos por damiles Ver Mensaje
Hasta que me ponga medianamente al día... la API ha crecido tanto desde el Pythonlopes como el propia Blender. Tendré que escribir otro manual...
__________________
Mateo 8, 9-10
Antiguo 24 sep 2007   #56
fog
Environment Artist
Avatar de fog
Si eso tambien lo estuve pensando....
El tema es pillar la normal de la cara en la que esta enciam el mouse para pillar la orientacion del objecto no?
__________________
Blog
Antiguo 24 sep 2007   #57
Caronte
BlenderAdicto
Avatar de Caronte
Cita:
Escritos por SHAZAM Ver Mensaje
Luxology - Video
Existe un script que hace eso mismo y se llama "Solidify".
No sé si viene con la versión oficial, yo lo tengo desde hace bastante tiempo.
__________________
"Algún día todo será digital"
Caronte.
My latest personal work
Caronte is offline   Responder Con Cita
Antiguo 24 sep 2007   #58
pedropp
Avatar de pedropp
si, el script "Solidify Selection" (en el menú Mesh/Scripts) lo pusieron oficialmente en la 2.43
__________________
"La vida es como el tetris, cuando llegan los palos no sabes como encajarlos"
[SIGPIC][/SIGPIC]
pedropp is offline   Responder Con Cita
Antiguo 24 sep 2007   #59
SHAZAM
Administrador
Avatar de SHAZAM
Cita:
Escritos por Caronte Ver Mensaje
Ahora que lo he localizado he recordado que una vez lo probé, el alzheimer me tiene frito
Thx
__________________
Victor Navone
Antiguo 24 sep 2007   #60
fog
Environment Artist
Avatar de fog
Alguien sabe si hay alguna manera de saber la relación entre la coordenada del mouse y la coordenada del vértice mas cerca en una geometría?
Un poco rebuscado vamos
__________________
Blog
Respuesta
Etiquetas Identificativas
blender, para, script, sugerencias
Herramientas
Normas de Publicación
BB code is habilitado
Las caritas están habilitado
Código [IMG] está habilitado
Trackbacks are deshabilitado
Pingbacks are deshabilitado
Refbacks are deshabilitado
Saltar a Foro
Temas Similares
Granja de PCs para renders en max 3dpoder 3DStudio Max 14 20 ago 2008 07:40
Hair strand (Pelo en Blender) COMPLETADO 3dpoder Blender 3 22 dic 2007 12:28
Problemas con el script para el " Heredar Ángulo de giro de la pierna" en Max 6 Buen Rollal Script 0 08 ene 2007 16:34
Blender Game Engine --Andando--como mover el actor 3dpoder Blender 0 18 sep 2005 04:43
Tracking automático con BOUJOU 3dpoder 3DStudio Max 1 23 abr 2005 17:15
google adsense
La franja horaria es GMT. Ahora son las 19:54.
Bad Credit Loan | Remortgages | Secured Loans | Loans | Remortgages
Content Relevant URLs by vBSEO
