AL INSTALARLOS SE ME CUELGA EL MAX , ¿QUE TENGO QUE HACER?
Le han agradecido 0 veces
en 0 Mensajes
en 0 Mensajes
Hi
Don't speak Spanish, but I must point out that NPR! and Cartoon Reyes, cannot exist at the same time. Personally I would un-install both, then only install NPR1, as it can do Cartoon Renders and so much more.
The reason they cannot exist together is that NPR1 is the big brother of Cartoon Reyes.
Hopefully if you do the above this will cure your problem. If not then I should imagine either your using Max 3.1 and are trying to use a Max 4 plugin. OR You have a bad installation for either NPR1 or Cartoon Reyes or both. Uninstall both plugins and run Max, if it no seems okay, install NPR1, if this now causes MAX problems, then you have a bad plugin.
Sorry if this doesn't help. Please let me know what happens.
en 0 Mensajes
Sorrry , I don't understand very good English, but both plugging are version's max 4.
Thanks
en 0 Mensajes
Yes both are MAX 4 plugins. BUT will not work together. NPR1 is upgrade to Cartoon Reyes. Use NPR1.
If this does not help, please try to explain better.
Actualmente hay 1 usuarios viendo este tema. (0 miembros y 1 visitantes)
Marcadores
