Gracias Gracias:  1
Tema: Cartoon Backgrounds 3dsmax
    Cartoon Backgrounds
    by HelLRaiseR
    1. Modeling your scene
    In first time, you must model the scene in a 3D modeler application like 3DS Max, Cinema 4D, Maya, etc. In my case, the person that model the scenes use 3DS MAX. The model must be make using IDs for generate the ID layer. I use this layer for get the masks of the objects in Photoshop (Corel Paint Shop pro in my case).
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-1.jpg
    When the scene is finished, we must test it in WME, and make the corrections. When the scene is definitive, we generates six renders:
    The base image.
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-2.jpg
    The occlusion layer.
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-3.jpg
    The shadow layer.
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-4.jpg
    The grass layer.
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-5.jpg
    The outline layer.
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-6.jpg
    The ID's layer
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-7.jpg
    The renders must have the double of the resolution of the game. When the scene have complete, we resize the image using “inteligent size” (or similar effect in your drawing tool) to mix, average and ponderates the pixels to get the better results.
    2. Import to Photoshop (or other)
    Import the images in Photoshop (or other application) in distinct layers with this order:
    The image must be like this (the ID layer are not visible)
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-8.jpg
    3. Retouch the shadow layer
    as you can see, the shadows are generated in the floor, not in the grass (I thinque that isn't possible), you must complete the color selecting the exterior zone of the grass, inverting the selection, and draw the new shadow filling the holes and adjusting the borders in separate layer with blak color (0,0,0)
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-9.jpg
    When the new shadow are filled, adjust the layer transparency and erase the old shadow. You will has an image like this one:
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-10.jpg
    4.Optimize the outline
    As you can see in the cartoon films on TV, the outline of the backgrounds normally never is black. The most times, the outline color is similar to the surface color but more dark. You must change the blak outline color with the appropiate color depending on surface. When you change the outline color, you have a image like this (I've put a sky in a new layer after the render layer).
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-11.jpg
    In this image, the outline layer is in normal mode. There are several ways to adjust the intensity of the outline. You need change the mode of the layer to “multiply”, then you can adjust the transparency of the layer and the outline will be more or less dark. If the original line is clear you can adjust the bright and contrast to make the line darque and more visible.
    Now I'm going to delete partially the outline, the objective is that in the illuminated zone, the outline will be clear and in the darque zone the outline will be the original color In some cases this can be reverse (this effect can do with 3D Max Ink & Paint, but I prefer to do this with the drawing app becouse I change the line at my convenience and I can make more clear or darque the line, etc.). To do this, use the eraser tool with a very low transparency value (about 25%) and erase the lines that are illuminated and don`t erase the lines in darque zone. You can erase the line more times becouse you are deleted with a low transparency and when you erase the line, this is more clear.
    Finally, the image will be similiar to this one.
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-12.jpg
    5. Apply effects
    The next step is draw the effects and objetcs that aren't maked with the 3d modeler, i.e.: the ground around the tomb, the detail of the trees, the grass, etc. This is the image (incomplete, It's necessary apply more effects, but it's OK for the tutorial purposes):
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-13.jpg
    6. Apply light effects
    When your image are finished, you must to mix and fusion all visible layers, the next step is to adjust the light and the saturation of the color, in the next image I apply the necesary light correction to make a “sunset” environment.
    When you finish to apply the light effects, you need to resize the image to the final resolution for use in the game.
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-14.jpg
    Remember: This background aren't finished, is only published for the tutorial purposes, the next images are corresponded to finished backgrounds.
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-15.jpg
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-16.jpg
    by HelLRaiseR
    Miniaturas adjuntadas Miniaturas adjuntadas Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-1.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-2.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-3.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-4.jpg
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-5.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-6.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-7.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-8.jpg
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-9.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-10.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-11.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-12.jpg
    Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-13.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-14.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-15.jpg   Cartoon Backgrounds 3dsmax-tutorial-cartoon-backgrounds-photorealistic-16.jpg
    Si vas a subir un trabajo al foro, hazlo adjuntando la imagen, archivo, vídeo o lo que sea, no publicando enlaces de otros sitios.
    Jan 2009
    Respuesta: Cartoon Backgrounds 3dsmax
    Se ve bueno, pero tiene algunos errores de ortografia.
    (si, igual que mi mensaje, pero estoy en una computadora sin acentos )
  1. Ofertas de Trabajo BeautiFun Games S.L. busca Artista Backgrounds (Tiles) 2D
    Por Stratos en el foro Ofertas de Empleo
    Último mensaje: 20-02-2015, 10:37
  2. Blender Backgrounds
    Por Marckandres en el foro Postproducción
    Último mensaje: 06-01-2013, 11:53
  3. Problemas con los backgrounds
    Por alextula2 en el foro Render, Iluminación y Cámaras
    Último mensaje: 29-01-2008, 19:14
  4. Problemas con los backgrounds
    Último mensaje: 29-01-2008, 18:32
  5. Los backgrounds en blender
    Por ninot en el foro Partículas y Dinámicas
    Último mensaje: 07-11-2006, 22:08
