Foros 3DPoder.
Bienvenido a Foros 3DPoder..
¿Te ayudo?
Retroceder   Foros 3DPoder. > :: Infografia y diseño grafico. > Problemas con Programas
google adsense
Respuesta
Herramientas
Antiguo 15 jul 2003   #1
SHAZAM
Administrador
Avatar de SHAZAM
Predeterminado ¡Para usuarios del 3dsmax! ¡Cuidado con SP4 W2000!
Esta noticia fue publicada ayer en CGTalk:
Cita:
this went out from discreet this weekend concerning 3dsmax and win2k SP4
Do NOT install win2k SP4 if you're maxfiles are dear to you and yours.
Attention All 3ds max Customers,
We have identified and confirmed that installing the Windows 2000 Service Pack 4 causes the corruption of .max files. All 3ds max (.max) files saved with Windows 2000 SP4 installed will no longer load in 3ds max on systems with Windows 2000 SP2 or SP3 installed. Our Engineering Team has narrowed in on the problem and is working with Microsoft to resolve the situation. In the interim it is strongly advised that all 3ds max users do not install the Windows 2000 Service Pack 4. If Windows 2000 SP 4 has already been installed it is suggested that customers revert back to SP2 to create usable (.max) file content. This affects all 3ds max files created in versions 3 through 5.1
3ds max files created while Windows 2000 SP4 is installed can be retrieved through either of two workarounds:
Option 1
(Please be aware that some data will still be lost in this workaround.)
Revert Windows 2000 SP 4 Systems back to SP3 or earlier
Use "File Merge" to retrieve data from corrupted .max files created under Windows 2000 SP4 and resave.
Note: If you have Render Effects or Atmospherics in your max file, use the Merge button in the respective dialogs.
Option 2
Open corrupted .max files created under Windows 2000 SP4 in Windows XP and resave.
Revert all systems back to Windows 2000 SP3 or previous.
Bear in mind that 3ds max 5.1 is officially supported for Windows 2000 SP2, so for optimum stability revert to this operating system platform to use 3ds max 5.
Thank you for patience and assistance in getting this problem resolved.
En resumen, los que trabajéis con 3dsmax bajo Windows 2000, no instaléis el service pack 4, hasta nuevo aviso.
Un saludo,
Shazam.
__________________
Victor Navone
SHAZAM is offline   Responder Con Cita
Antiguo 16 jul 2003   #2
mesh
Antón pirulero...
Predeterminado Re: ¡Para usuarios del 3dsmax! ¡Cuidado con SP4 W2000!
es mas, parece que recomiendan tener el sp2 porque es el que está soportado oficialmente, como cuando recomendaron no instalar el sp3 en ordenadores con office porque aquello ralentizaba. el que pueda que los entienda yo ya paso....
mesh is offline   Responder Con Cita
Antiguo 16 jul 2003   #3
Txoldo
Avatar de Txoldo
Por mi experiencia en el curro, simplemente decir que con Microsoft hay que andar con pies de plomo. En cualquier caso estoy seguro que no se trata por el mal hacer de Discreet, sino de Mocosoft, que cambian los sistemas y recomendaciones a base de SPs.
En nuestra empresa, que realizamos aplicaciones Windows nos solemos encontrar con este tipo de problemas. Hasta el punto que una aplicacion que hicimos no funcionaba correctamente sobre la misma version de Windows del mercado Frances, y no supieron decirnos (Microsoft) el motivo de ello. Asegurarte que algo va a funcionar con todas las versiones y revisiones de Windows es increiblemente dificil. Y si a eso unimos Office (que tambien hemos tenido problemas con este paquete y Windows juntos), pues no me estraña.
Nos toca sufrir.
Txoldo is offline   Responder Con Cita
Respuesta
Etiquetas Identificativas
3dsmax, con, del, sp4, usuarios, w2000, ¡cuidado, ¡para
Herramientas
Normas de Publicación
BB code is habilitado
Las caritas están habilitado
Código [IMG] está habilitado
Trackbacks are deshabilitado
Pingbacks are deshabilitado
Refbacks are deshabilitado
Saltar a Foro
google adsense
La franja horaria es GMT. Ahora son las 22:17.
Credit Cards | Problem Mortgage | Loans | Personal Loans | Credit Cards
