Tema: YaF a RaY user's guide
    Blender YAF(A)RAY user's guide
    Al final de este mensaje puedes encontrar el pdf adjunto.
    Image by StoneAge
    About this document:
    Document revisión 3. Written by Alvaro Luna Bautista.
    1. What Yaf(a)Ray is.
    2. Yaf(a)Ray Installation notes (Windows).
    3. Yaf(a)Ray UI and General workflow.
    4. Render Output Window.
      1. Objects, Lights and Camera settings.
      2. 5.1 Object.
      3. 5.2 Lights.
      4. 5.2.1 Point and Sphere.
      5. 5.2.2 Directional and Sun.
      6. 5.2.3 Area.
      7. 5.2.4 Spot
      8. 5.3 Camera.
      9. 5.3.1 Architect
      10. 5.3.2 Angular
      11. 5.3.3 Orthogonal
      12. 5.3.4 Perspective /DOF
      1. Material settings.
      2. 6.1 Mapping notes.
      3. 6.2 Glass
      4. 6.3 Glossy
      5. 6.4 Coated Glossy
      6. 6.5 ShinyDiffuse
    5. Render settings.
    7.1 Lighting Methods
    7.1.1 Bidirectional
    7.1.2 Pathtracing
    7.1.3 Photon Mapping and Final Gather
    7.1.4 Direct Lighting and Ambient Occlusion.
    7.2 General Settings.
    7.3 Anti Aliasing settings.
    7.4 Background Settings.
    Yaf(a)Ray is Yet Another Free Raytracer; nobody knows for sure what the (a) stands for. It is a raytracing render engine based on a new source code, different than the used for the YafRay 0.0.x series. Rewriting the source code from scratch was necessary because the old design was exhausted and did not allow for more changes or additions. There are several conceptual differences to YafRay 009. As a consequence of these depth changes, renders will completely differ from YafRay 009 ones. You will find additional information about Yaf(a)ray in the link below:
    YafRay has been an open source project closely related to Blender from the start. For many years it was the only choice Blender users had apart from Blender Internal. In fact, YafRay 009 and previous releases of YafRay used an exporter plug-in that was 'hacked' into the official Blender source code. This plug-in provided a good integration of YafRay in Blender, but on the hand it shaped a lot its development. There were some YafRay features that did never make the Blender panels because it meant more contamination of the Blender source code. On the other hand, many times YafRay development efforts were focused on supporting Blender new features instead of exploring independent raytracing routes.
    Integrating Yaf(a)Ray into Blender like the old YafRay 009 would mean a complete redesign of the exporter plug-in and adding more 'alien' code to Blender. Besides, at the end of the day YafRay and Blender are separated F.O.S.S. projects. Taquíng into account that there exist now other external render engines for Blender users apart from Yaf(a)Ray, that kind of integration does not make sense anymore. Ideally, a render API should exist in Blender for equal and seamless integration of any external engine.
    Until that render API arrives, Yaf(a)Ray uses:
    1. A python-coded User Interface (UI) to use in a Blender window to configure materials, lights and render settings and to launch the scene rendering.
    2. A separate graphical Render Output Window where Yaf(a)Ray renders are shown and saved.
    Overview of Yaf(a)Ray most important features
    2. Yaf(a)Ray installation notes (Windows)
    Yaf(a)Ray does not need any Blender special compilation to work, any official release from will worque for instance. There are two components needed to run Yaf(a)Ray, which are:
      1. Yaf(a)Ray binaries. Default installation proposed for Yaf(a)Ray binaries is C:\Program Files\YafaRay or the equivalent in your respective OS language.
      2. In the same installation process, some Yaf(a)Ray python scripts should be installed in the Blender scripts folder. The installer will look for it and tell you where it is found. Alternatively you can point the installer to the Blender executable folder, usually in C:\Program Files\Blender Foundation\Blender or the equivalent in your respective language.
    1. A separate installer for the Render Output Window libraries. They must be installed in the Blender executable folder, usually in C:\Program Files\Blender Foundation\Blender or the equivalent in your respective OS language.
    Note: It is necessary to have Python 2.5 installed to runYaf(a)Ray scripts. You can find it here:
    3. Yaf(a)ray UI and general workflow
    Once everything is installed, a special entry is added in the Blender Render menu, called YafaRay Export 0.0.3, which automatically executes the Yaf(a)Ray User Interface (UI) inside a Blender 3DWindows. Split your 3DWindows and clik in YafaRay Export 0.0.3
    Note: Here you can learn how to split the Blender 3DWindows:
    The Yaf(a)Ray User Interface (UI) will be shown, which is divided into:
    1. Three main sections of settings which are Object/Light/Camera, Material, and Settings.
    2. A Help text.
    3. Two function buttons which are Refresh view and Render.
    • Settings: This section is used to choose a lighting method and to configure render general parameters, render anti-aliasing and background settings.
    • Material: The script takes Blender defined materials and applies them custom Yaf(a)Ray material properties.
    • Object/Light/Camera: The script takes the current Blender selected and active object and applies it custom Yaf(a)Ray properties, depending on the object selected (camera, light or object). Lights and camera settings in Yaf(a)Ray UI script replace almost all Blender and YafRay 0.0.9 settings, except from texturing mapping settings.
    • Help: displays a brief help text.
    • Refresh View: The User Interface must automatically refresh to show specific settings for the kind of object selected in the Blender 3DWindows. Use the Refresh button if the UI is not self refreshed when a new object is selected. A right mouse button clik on a empty area of the User Interface will refresh it too.
    • RENDER: Launches the scene rendering and a separate Render Output Window in which the render progress can be seen. Use the Render Output Window settings to save your image. Once the render is finished or stopped, the Render Output Window must be closed before coming bak to Blender. Don't forget to save your render.
    1. Render Output Window
    2. Object, Lights, and Camera settings
    (to complete as the development of this part progresses, at the moment a few simple buttons)
    5.1 Object
    With this feature, objects in the scene can act as area light sources. Arealight is a light type that can produce software shadows and its shape can be seen in reflective surfaces. The software shadows need to be sampled several times and later interpolated to reduce noise. This type of light takes more time to render in contrast with point light types such as spot and point.
    First of all, you must select the mesh you want it to act as a light source. Next you must clik on the Object/Light/Camera button. Finally you must activate the Enable Meshlight button. To change the light color, just clik on the rectangle next to 'Meshlight color:' to open a Color Picker.
    • Meshlight color rectangle: opens a Color Picker.
    • Power: intensity multiplier for meshlight color.
    • Double Sided: considers both sides of the mesh as arealight sources.
    • Samples: defines the amount of samples taken to simulate the software shadows. The more samples, the less noisy the shadows but the longer it will take to render.
    5.2 Lights
    Lights settings are mostly controlled by the Yaf(a)Ray UI. In Blender, the only actions required are placing lights and choosing a Blender light type. Arealight size and spot beam parameters are controlled in Blender panels though. In Yaf(a)Ray, lighting power is controlled by a couple of buttons (Power and Color) available in the python UI for every light type, therefore Blender Distance and Energy buttons haven't any effect in Yaf(a)Ray.
    Once a light is placed and its type defined in Blender, select it and press Object/Light/Camera main button. The python UI will automatically change to show specific settings for the type of light selected.
    When you create o select a Lamp light in the Blender 3DWindows, the python UI will let you choose between two options to configure this kind of light, Point and Sphere.
    A Point light is a typical omni directional point light source as in Blender Internal with hard shadows, while a Sphere light is a spherical area light source which can produce software shadows.
    • Light color rectangle: opens a Color Picker.
    • Power: intensity multiplier for light color.
    • Radius: sets the radius of the Sphere light in Blender units.
    • Make light visible: area light gets rendered visibly.
    • Samples: defines the amount of samples taken to simulate software shadows. The more samples, the less noisy the shadows but the longer it will take to render.
    When you create o select a Sun light in the Blender 3DWindows, the Yaf(a)Ray UI will let you choose between two kind of lights to do this kind of job, Directional and Sun.
    Directional light is a traditional sun light model which produces parallel rays and hard shadows.
    The new Yaf(a)Ray Sun light is a more advanced concept and will help us to get blurred edges in shadows when the shadow itself gets further from the casting object, as in the real life. The angle button sets the visible area of the sun. Real Sun is visible in a cone angle of about 0,5º. A bigger angle mean a bigger sun, as well as softer shadows, which could be interesting for dawn or sunset scenes and for a sunlight filtered by an overcast sky.
    • Infinite: if enabled, area covered by the directional light is infinite. If disabled, light fills a semi-infinite cylinder.
    • Radius: if infinite is disabled, radius of the semi-infinite cylinder for directional light.
    • Angle: visible size of the sun light. Affects shadows.
    • Samples: it defines the amount of samples taken to simulate the software shadows, when Direct Lighting or Pathtracing is used. The more samples, the less noisy the shadows but the longer it will take to render.
    5.2.3 Area
    Arealight is a area light type that can produce software shadows and its shape can be seen in surfaces with reflective properties. The software shadows need to be sampled several times and later interpolated to reduce noise. This type of light takes more time to be computed in contrast with point light types such as spot and point.
    In regard to Arealight, the most important change is the Make light visible button and the general workflow to get 'visible' arealights in reflective surfaces. In the old workflow, when photons were enabled, we needed to place 'emit' planes just behind every area light to make arealights 'visible' and to add lighting power to the scene.
    Now, when Make light visible is enabled, a rectangle in the size of the area light is generated, so that the area light gets rendered visibly. Therefore, the 'emit' plane is no longer needed. More lighting power is added when Make light visible is on.
    When photons is enabled, arealights cast direct light and photons. The Make visible option really only affects reflections in surfaces.
    When Pathtracing is used, the Make light visible option alos creates caustics, although there exist an option to not trace caustics with path tracing as they tend to be extremely noisy ('none' option in Pathtracing settings, see 5.1.1).
    • Light color: opens a Color Picker.
    • Power: intensity multiplier for arealight color.
    • Samples: defines the amount of samples taken to simulate the software shadows, when Direct Lighting or Pathtracing is used. The more samples, the less noisy the shadows but the longer it will take to render.
    5.2.4 Spot
    Spot is a common point light with directional properties. Beam properties are defined in Blender panels (SpotSi and SpotBl sliders).
    5.3 Camera settings
    First a camera should be created or exist in your scene. Lens angle must be configured in the Blender camera panels. Then select the camera and press Object/Light/Camera main button. The python UI will automatically change to show specific camera settings. There are four camera types in Yaf(a)Ray: Architect, Angular, Orthogonal and Perspective.
    5.3.1 Architect
    This camera type works like a Perspective camera type, the only difference is that the vertical component of the perspective effect is neglected, so scene vertical lines are not convergent. DOF settings are available for this camera type; they are explained in the 5.3.4 paragraph.
    5.3.2 Angular
    A camera type useful to produce light probé images. (to complete)
    5.3.3 Orthogonal
    A camera type that renders a orthographic (perpendicular) projection of the scene, without perspective effects.
    • Scale: Specify the scale of the ortho camera, to control camera zoom.
    5.3.4 Perspective
    Perspective is the standard camera mode that simulates a lenses photographic camera, with perspective effects. All settings available for this camera type are used to enable and configure the depth of field (DOF) effect. DOF is the distance in front of and behind the subject which appears to be out of focus.
      • Bokeh type: controls the shape of out of focus points when rendering with depth of field enabled (blur disk). This is mostly visible on very out of focus highlights in the image. There
      • are currently seven types to choose from.
    • Bokeh rotation: rotation of the blur disk.
    • Aperture: The size of the aperture determines how blurred the out-of-focus objects will be. A rule of thumb is to keep it between 0.100 and 0.500 (0 disables DOF).
    • Bokeh bias: controls the accentuation of the blur disk. Three types available, uniform, center or edge, with uniform the default.
    • DOF distance: set the focal point in which objects will be in focus.
    • Obj: Enter the name of the Blender object that should be the focal point.
    • Calculate distance: it calculates the distance between the object entered in Obj: and the camera, and writes this value in the DOF distance button.
    The DOF effect depends alos on the render anti aliasing settings to get a nice blurred effect. First of all it is recommended to lower 'AA threshold' a bit, but not set it to totally zero. Setting a high number of 'AA passes' is alos not really going to make all that much difference, the main smoothness factor that makes the most difference is really the amount of 'AA samples'. A single pass with a high number of samples may be sufficient.
    6. Material settings.
    In contrast with the light settings, the UI script just takes Blender list of existing materials and applies them Yaf(a)Ray custom properties. For instance, in the scene below there is a list of three materials configured in Blender:
    (insert paragraph here about mat preview)
    Settings in the Blender/YafRay 'Material' panel are replaced by Yaf(a)Ray UI settings. Ramps are not supported. Blender Multimaterial (more than one material in an object) is supported.
    There are four material types in Yaf(a)Ray, with many possibilities for each of them to achieve advanced properties. They are glass, coated_glossy, glossy and shynnydiffusemat. This is a brief list of what Yaf(a)Ray materials can be useful for:
    Glass: glass, water, fake glass.
    Glossy: all kind of plastics, clean and polished metal, clean rough metal, car paint, finished wood, lacquered surfaces, painted surfaces, varnished wood, glaze and organic surfaces, materials with anisotropic reflections.
    Coated_glossy: car paint, lacquered surfaces.
    Shnydiffusemat: stone, rusted metal, concrete, fabric, paper, rough wood, curtains, emit surfaces, perfect mirror, materials with a basic transparency and alpha mapping with shadows, etc.
    6.1 Mapping notes.
    (this section needs a big overhaul and needs to be much more complete. I have prepared a lot of stuff to do it)
    All the properties configured in the Shaders and Mirror Transp Blender/YafRay 009 panels are replaced with the Yaf(a)ray UI settings. Only Blender mapping settings from Texture, Map input and Map to panels (F9) are taken into account.
    (insert pic about Blender panels and buttons supported)
    Map to texture modulation modes are partially supported. In the image below for instance, the shinydiffuse material will process only five Blender Map to modulation modes, which are Nor, Col, Raymir, Alpha, and Translu. In the first case for instance, the Blender Nor mode will affect bump mapping in Yaf(a)Ray. (to complete)
    6.2 Glass
    This kind of material can be useful to render realistic glass, water and any kind of transparent medium with index of refraction. Use this material to get refractive caustics and light reflection (mirror) depending on the incident angle.
    This material can be alos useful to get glass with fake transparent shadows, when caustic rays are not powerful or uniform enough to lit the scene behind a transparent object.
    Absorption is the process by which light is absorbed by a medium, although not all light get absorbed, some is reflected or refracted instead. The more distance light had to get thought a medium, the more it gets absorbed. In a glass with different sections, the glass color will get darker if the section is bigger. By using Absorption we alos get tinted caustics, depending on Absorp. Color.
    Example of the absorption effect with tinted refractive caustics.
    Filter settings not only defines the color of the refracted light, but it alos affects color of the transparent medium, like Absorption color does.
    Use Absorption if you want to get the “absorption” effect (as the object section gets bigger, the object color gets darker). Use Filter if the absorption effect is not important to you and you want more control over the refracted color. Filter color alos defines color of the transparent shadows when the Fake Shadows button is enabled.
    Not all light tracing methods are optimized to render lighting effects after a refraction event. Path tracing (without post-caching) is not well suited for such a case. Pathtracing caustics tend to be very noisy and a very big amount of samples is needed to get a smooth result. To get transparent shadows in such a material you have got two options: working out a caustic photon map with enough visual consistency, or activate both the Fake Shadows button in the Material section and the Transparent Shadows button in the Render section to get fake glass shadows.
    • Absorp. color: opens a Color Picker. It defines the color of of the non-absorbed light, therefore it sets the color of the glass. White disables absorption.
    • Absorp. Distance: transmission of light through the material.
    • Filter color: opens a Color Picker. It defines the color of the refracted light.
    • Mirror color: opens a Color Picker. It defines the color of the reflected light.
      • IOR: Light index of refraction, it produces either refraction or reflection, depending on the
      • incident angle.
    • Transmit Filter: strength of the refracted light when a Filter color is used.
    • Dispersion power: strength of the dispersion effect, disabled when it is 0. When Path tracing is used, noise depends on path tracing samples, the more the samples the lesser the noise.
    • Fake Shadows: When enabled, light rays that get through this object are traced without refraction index. Use Filter color and Transmit Filter to tint these rays. The Transparent Shadows button in the Render section must be enabled too for this feature to work.
    6.3 Glossy
    A glossy reflection means that tiny random bumps on the surface of the material cause the reflection to be blurry. In fact there is a wide range of materials with such a reflection. Yaf(a)ray glossy material can be useful for all kind finished surfaces such as plastics, polished metal, car paint, finished wood, lacquered surfaces, painted surfaces, varnished wood, glaze and organic materials, etc. Yaf(a)ray glossy reflections have got by default Fresnel effect. Below there is an example of a glossy reflection.
    Example of Glossy reflection
    This material will be useful to get anisotropic reflections too. An anisotropic reflection means that reflection is not equal in all directions. This kind of reflection happens when a defect in a reflective surface repeats quite regularly and in the same direction. When Anisotropic is enabled, the exponent value is divided into a vertical and an horizontal component. If you want to get an anisotropic reflection, use a different value for each one. As a result the reflection will take an oval shape. The anisotropic effect can be reinforced by using a suitable bump map. When Anisotropic is enabled, two new buttons will show up, and the exponent will have no effect. Horizontal and Vertical components of the exponent depend on UV mapping coordinates.
    • Diff. color: opens a Color Picker. It defines the color of the diffuse reflection.
    • Glossy color: opens a Color Picker. It defines the color of the glossy reflection.
    • Diffuse reflection: amount of diffuse reflection (Diffuse color brightness multiplier).
    • Glossy reflection: amount of glossy reflection.
    • Exponent: Blur of the glossy reflection; the higher the exponent the sharper the reflection. Use values between 0.5 and 200 for plastics and higher values for metallic surfaces.
    • As diffuse: Treat glossy component as diffuse, faster when using photon mapping.
    • Anisotropic: Enables anisotropic reflection (disables isotropic Exponent)
    • Exponent Horizontal: exponent blur in the U direction (UV mapping coordinates)
    • Exponent Vertical: exponent blur in the V direction (UV mapping coordinates)
    6.4 Coated Glossy
    Coated Glossy is básically a glossy material (see the previous paragraph) with some kind of reflective coating layer on top. IOR is the setting that controls reflectivity of the coating top layer.
    6.5 Shinydiffuse
    Shinnydiffuse is a model of diffuse shader without 'viewer' properties (apart from Fresnel). It can be useful to get:
    • Diffuse materials without any specular (glossy) component.
    • Perfect mirror reflection without or with Fresnel effect (for reflective caustics).
    • Translucency with color filtering and alpha mapping with shadows calculation.
    • Transparency with color filtering and alpha mapping with shadows calculation.
    • Diffuse Emit surfaces.
    For instance, this material can be used for rough stone, rusted metal, concrete, fabric, paper, rough wood, chrome balls, car paint, curtains, billboards, etc. Shadows calculation from alpha mapping is supported.
    When Mirror strength is higher than 0, a new option appears to enable Fresnel reflection. If Fresnel is enabled, a new button appears to set an index of refraction (IOR) for the Fresnel reflection: the higher the index, the higher the reflection. Use this option to get reflective caustics.
    • Diffuse color: opens a Color Picker. It defines the color of the diffuse reflection.
    • Mirror color: opens a Color Picker. It defines the color of the mirror reflection.
    • Mirror strength: amount of mirror reflection (enables Fresnel)
    • Transparency: Basic transparency effect without refraction.
    • Translucency: Diffuse transmission of light in the shadowed part of the object.
    • Transmit filter: amount of tinting of light for Transparency and Translucency.
    • Emit: Amount of diffuse light the material emits. If Direct Lighting is used, only surface properties can be seen. To use it as a lighting source you will have to use path tracing. It does not emit photons.
    • Fresnel: Enables Fresnel Reflection.
    • IOR: Index of Refraction for the Fresnel effect, produces reflective caustics.
    Example of a mapped transparency with color filtering and shadows calculation from alpha mapping.
    Example of a mapped translucency with color filtering and shadows calculation from alpha mapping.
    Example of reflective caustics using shinydiffuse Fresnel reflection.
    7. Render settings
    Render Set can be used to configure as many as five different set of render settings. You can use this feature to compare rendering performance between different sets. Render sets can be renamed by using the Name: text button.
    There are currently four lighting methods available in Yaf(a)Ray. Bidirectional, Pathtracing and Photon Mapping perform global illumination (direct light + indirect light), while Direct lighting only takes into account direct light from emitting sources without indirect light contribution. Caustic photon mapping and Ambient Occlusion can be rendered when Direct lighting is used.
    7.1.1 Bidirectional
    (to complete. In beta stage. Use a high number of AA passes and AA inc. samples and AA thresold=0 to reduce noises in every pass)
    7.1.2 Path Tracing
    Path tracing is a relatively old GI biased method in which each ray is recursively traced from the camera along a path until it reaches a light source. When a light source is found, the light contribution along the path is calculated bak to the camera taquíng into account surface properties. Many samples are need to be taken and interpolated for each camera pixel to get a smooth result. A light source can be either a light, the scene background or both. Scenes with relatively small light sources and with a high contrast between light sources and its surrounding areas will need more samples to remove noise. Therefore pathtracing is a GI solution more suited for outdoor scenes and for daylight indoor scenes with big windows and a regular distribution of light.
    Path tracing (without post-caching) is not well suited for caustic effects. Pathtracing caustics tend to be very noisy and a very big amount of samples is needed to get a smooth result. In Yaf(a)Ray we have alternative methods to render the caustics component caustics when pathtracing is used:
    • Path+Photon: a mix of a caustic photon map and path tracing caustic rays are used to get caustics.
    • Photon: a fast photon map is used to render caustics. Path tracing caustics rays are not rendered.
    • Path: Path tracing caustics rays are rendered.
    • None: the caustic component is not rendered.
    This is an example about how methods for the caustics component worque in pathtracing. In the first image (upper left), Path is used to get caustics, which are very noisy when a low number of samples is used (16). In the second render, 512 pathtracing samples are used to improve caustics but it takes much more time to render (38 minutes). In the third example, photons are used to produce the caustics component and the render time is the lowest of them all (Cm stands for Caustic method):
    Comparison between methods used for the caustic component in pathtracing
    The other components of the global illumination model are rendered as usual. Area light types (sphere and area) with the Make Light visible option enabled are needed to produce caustics in pathtracing. More information about the caustic photon map settings can be found in the 5.1.3 Direct Lighting paragraph (they are the same). The other pathtracing settings are:
    • Depth: defines the number of rays bounces in order to find the light sources, the more bounces the better quality and the less noise but the longer it will take to render.
    • Samples: This setting is the equivalent to GI Quality in YafRay 0.0.9, and it defines the number of samples to take per camera pixel, the more samples the better render quality and the less noise, but the longer it will take to render as well. A Depth of 3 to 5 and 32-256 samples should do okay for almost every scene. For this and for other 'Samples' settings, it is a good practice to increase & decrease your samples in base 2 steps (2-4-8-16-32-64... etc)
    • Use background: Makes use of the background color or texture as a light source.
    • No recursion: only lighting is calculated without reflective or refractive events.
    Yaf(a)ray settings on photons are more or less the same than in other raytracers. Photon mapping is a Global Illumination algorithm that calculates the flow of light energy throughout a scene. With photon mapping, light packets called photons are sent out into the scene from the light sources. Whenever a photon intersects with a surface, the intersection point, incoming direction, and energy of the photon are stored in a cache called the photon map.
    Once the actual rendering has started, the correct appearance of a surface in a given point is estimated by examining and interpolating photons in the neighborhood. This is in fact the slowest part of the algorithm. Diff. Radius defines the radius of this search, while Search defines the maximum number of photons to mix. Photon mapping is a technique meant to be used in closed or almost closed environments. HDRI backgrounds can't emit photons.
    • Depth: maximum number for reflections (bounces) and refractions.
    • Photons: Number of photons to trace. the more photons, the more information to generate the photon map from.
    • Diff. Radius: Radius to search for non-caustic photons.
    • Caustic Mix: maximum number of caustic photons to mix (blur).
    • Search: maximum number of non-caustic photons to mix.
    • Use background: (to complete)
    Final gather is a caching technique to improve and 'complete' photon mapping by gathering, after photon tracing, an appróximation of the local irradiance using several illumination bounces. This information is used at render time for further interpolation with the obvious advantage of requiring a less accurate, therefore faster, GI simulation and still have a physically correct simulation.
    To reduce noise in renders when using FG it is recommended to increase FG samples and to use relatively high anti aliasing settings.
    • FG bounces: in a precomputed phase, determines the number of bounces for Final Gather rays.
    • FG samples: Final Gathering samples for interpolation, the more the better, but the longer it will take to render.
    • Show map: (to complete)
    When Direct Lighting is used, only lighting provided from light sources is considered, without indirect contribution from other surfaces (light bounce). Since caustics photon mapping does not need post caching techniques like Final Gathering for blurring/interpolating photons, an option is provided to produce caustic photon maps when Direct lighting is used. Lights will be the caustic photons sources.
    • Photons: Number of caustic photons to shoot.
    • Caustic Depth: Number of refraction events for caustic photons
    • Caustic Mix: number of photons to mix (blur)
    • Caustic Radius: amount of caustic blurring. The result alos depends on Caustic Mix.
    Ambient Occlusion is a shading method that takes into account attenuation of light due to occlusion. Ambient occlusion is most often calculated by casting rays in every direction from the surface. Rays which reach the background or “sky” increase the brightness of the surface, whereas a ray which hits any other object contributes no illumination. As a result, points surrounded by a large amount of geometry are rendered dark, whereas points with little geometry on the visible hemisphere appear light.
    • AO Samples: The number of rays used to detect if an object is occluded. Higher numbers of samples give smoother and more accurate results, at the expensé of slower render times
      • AO Distance: The length of the occlusion rays. The longer this distance, the greater impact that far away geometry will have on the occlusion effect. A high Dist value alos means that the renderer has to search a greater area for geometry that occludes, so render time can be
      • optimized by making this distance as short as possible, for the visual effect that you want.
    • AO Color: Color for ambient occlusion rays, alos useful to test lighting AO power.
    Under this section are grouped several general raytracing settings:
    • Raydepth: Maximum depth (bounces) for recursive raytracing. Increase this setting to get deeper into successive reflective and refractive events in the scene.
    • Shadow depth: Number of bounces for shadow rays when glass fake shadows is enabled. A sort of 'fake' raydepth.
    • Gamma: Gamma correction in renders, to use in the linear worque flow. It changes the response to light of the render engine. Inverse correction of textures and colors is performed using the G. in setting. Gamma should be used accordingly with your monitor gamma. To take full advantage of this feature, a basic monitor calibration is recommended. A display gamma of 2.2 is the standard for the Windows OS. The standard for Macintosh and Linux is
    1.8. Use Gamma=1 to deactivate render gamma correction. More información about this technique:
    • G. In: Inverse Gamma correction applied to textures and color input. It should be the same value as Gamma.
    • Transparent Shadows: Enable to get fake shadows in a glass material.
    • Clamp RGB: Reduces the colors' brightness to a low dynamic range, for better anti aliasing on areas with fast hight contrast changes. The examples below were made by sevontheweb. The upper image has got aliasing issues in areas with strong contrast variations, but colors are crisp. In the lower image Clamp RGB has been enabled. There is better anti aliasing but colors are duller. Another way of solving this issue is increasing the render resolution and then scaling bak to the desired resolution using a good interpolation algorithm.
    Comparison between Clamp RBG enabled (top) and disabled (bottom)
    • Threads: to forque the rendering calculation into two or more simultaneously running tasks, for multiprocessing purposes.
    • Clay Render: produces a clay render overriding all materials.
    • Output to XML: The scene is written in a yaf(a)ray XML file. The file is located in the YFexport directory as per Blender settings.
    • Draw Render Params: The render most important parameters are written in a badge in the render image. Use this feature to compare renders and to asque for advice in the YafRay forums.
    • Custom String: Adds text to the previous render parameters.
    Yaf(a)ray now uses two more anti aliasing filters apart from default Box, which are Gauss and Mitchell. The only really good property of Box is that it has no danger of amplifying sampling noise. If a slight softness of edges is no problem for your work, try Gauss; if you want maximum detail try Mitchell.
    Pixelwidth (which gets translated to real filter size) has some influence too, the larger the softer the image. Use lower values than default to make your renders sharper. The way AA samples are configured has got changed too. AA samples defines the number of samples for only the first AA pass, while the AA inc. samples value is used for subsequent AA passes.
    There are four options for backgrounds, which are:
    • Sunsky: This kind of background tries to reproduce a realistic sky with its color variations. There is a tutorial about how to set up this kind of background, made by sandstorm:
    • Texture: A texture is used as a background. You can alos use it as a light source (Use IBL on/off button). The main purpose of this option is using HDRI images to lit the scene. Besides, there is an option to rotate the background (Rotation: button), a multiplier for background color (Power: button) and a sampling parameter for the background when used as a light source (IBL samples: button)
    The textures need to be loaded using Blender Texture buttons (F6). Yaf(a)ray uses the Blender Word mapping settings as well. In the texture and input panel, only the AngMap, Sphere and Tube modes work. In the adjacent Map to panel, Hori must be enabled for light probes to work.
    Settings used in Blender Panels for HDRI backgrounds in Yaf(a)ray
    • Gradient: A two-parts gradient (Sky and Ground) is used as a background, with the división between them in the camera horizon line. Power: button is a multiplier for background color.
    • Single color: A single color is used as a background. Power: button is a multiplier for background color.
    Última edición por 3dpoder; 22-11-2008 a las 21:18 Razón: Adjuntar el pdf en zip
    Semoviente. Avatar de carleptos
    Sep 2007
    Thumbs up Re: YAF(A)RAY user's guide
    Emocionado y agradecido.
    Besos y abrazos.
    Aquí, tratando de dar la talla.
  1. Ofertas de Trabajo The Becquer's Guide busca Riggin - animación
    Por Stratos en el foro Colaboraciones e Iniciativas
    Último mensaje: 30-09-2014, 08:37
  2. Maya Existe Biped guide XSI en Maya
    Por Gratif en el foro Animación y Rigging
    Último mensaje: 25-05-2009, 19:19
  3. 3ds Max The No-Joke Topology Guide for Serious 3D Modelers
    Por 3dpoder en el foro Temas Generales
    Último mensaje: 01-05-2009, 13:44
  4. Puedo usar mas curvas guide
    Por johannchristian en el foro Partículas y Dinámicas
    Último mensaje: 08-01-2007, 10:27
  5. texture guide hace colgar el modeler 9
    Por batou en el foro Problemas con Programas
    Último mensaje: 22-11-2006, 09:17
