#1 |
Links de cursos de Cad y MaX muy buenos, en ingles pero se entienden superbien, algunos capitulos vienen con su pdf saludos
AutoCAD 2D Tutorials AutoCAD 3D Tutorials 3D Studio MAX Videos He aqui con todo y el temario completisimo: Autocad 2D · Chapter 1 · Introduction to AutoCAD 1.1 Launching AutoCAD 1.2 Text and Graphics Screens 1.3 Cursor 1.4 Cancel 1.5 Menus and Colors 1.6 Toolbars 1.7 Status Bar and Command Prompt 1.8 Typing Commands/Aliases 1.9 AutoCAD Pointing Device 1.10 Undo 1.11 Function and Accelerator Keys 1.12 Online Help · Chapter 2 · Introduction to Commands 2.1 Opening a Drawing 2.2 New Drawings 2.3 Saving Drawings 2.4 File Safety Precautions 2.5 Exiting AutoCAD · Chapter 3 · Draw Commands 3.1 Line Command 3.2 Cartesian Coordinate System 3.3 Dynamic Input 3.4 Orthogonal Lines 3.5 Polar Tracking 3.6 Circles 3.7 Arcs · Chapter 4 · Erase and Selection Sets 4.1 Erase and Selection Sets 4.2 Selection Set Options 4.3 Oops Command 4.4 Selection Preview · Chapter 5 · Basic Display Commands 5.1 Zoom 5.2 Pan 5.3 Redraw and Regen 5.4 Blipmode 5.5 Aerial View · Chapter 6 · Drawing Aids 6.1 Snap 6.2 Grid · Chapter 7 · Object Snapping 7.1 Object Snaps 7.2 Case by Case Object Snaps 7.3 Object Snap Settings 7.4 Aperture · Chapter 8 · Setting Up a Drawing 8.1 List 8.2 Measuring Distances 8.3 Calculating Areas 8.4 Quick Calc Command 8.5 ID Command 8.6 Units 8.7 Drawing Limits 8.8 Drawing Scales and Paper Sizes 8.9 Scalelist Command · Chapter 9 · Plotting 9.1 Plot Command 9.2 Adding a Plotter 9.3 Plot Settings 9.4 Plot Styles 95. Add a Plot Style 9.4 Named Plot Styles · Chapter 10 · Edit Commands 10.1 Move 10.2 Copy 10.3 Previous Selection 10.4 Offset 10.5 Extend 10.6 Trim 10.7 Mirror 10.8 Rotate 10.9 Scale · Chapter 11 · Text 11.1 Text 11.2 Text Justification 11.3 Text Styles 11.4 Font Files 11.5 Multiline Text 11.6 Editing Text 11.7 Special Control Codes 11.8 Spell Check 11.9 Scale Text · Chapter 12 · Layers, Linetypes, and Colors 12.1 Intro to Layers and Layer Dialog 12.2 Layer Shortcuts 12.3 Layer Previous 12.4 Layer States 12.5 Color Command 12.6 Linetypes 12.7 Lineweights 12.8 Object Properties · Chapter 13 · More Edit Commands 13.1 Break 13.2 Stretch 13.3 Fillet 13.4 Chamfer 13.5 Rectangular Array 13.6 Polar Array 13.7 Lengthen 13.8 Join · Chapter 14 · Advanced Display Commands 14.1 Transparent Commands 14.2 Multiple Command 14.3 Advanced Calculator Functions · Chapter 15 · Polylines 15.1 Pline Options 15.2 Editing Polylines 15.3 Editing Vertex Options 15.4 Explode Command 15.5 Turning Lines into Polylines · Chapter 16 · More Draw Commands 16.1 Polygon 16.2 Rectangle 16.3 Spline 16.4 Converting Plines to Splines 16.5 Donut 16.6 Ellipse 16.7 Multilines and Editing Multilines 16.8 Construction Lines and Rays · Chapter 17 · Crosshatching 17.1 Hatch Command 17.2 Hatch Boundaries 17.3 Hatch Origin 17.4 Gradient Hatch 17.5 Hatch Options 17.6 Editing Crosshatch Patterns 17.7 Inherit Hatch · Chapter 18 · Boundaries and Regions 18.1 Boundary Command 18.2 Region Command · Chapter 19 · Blocks and Attributes 19.1 Creating Local Blocks 19.2 Inserting Blocks 19.3 Control Color and Linetypes of Blocks 19.4 WBLOCK Command 19.5 Purge 19.6 Creating Dynamic Blocks 19.7 Manipulating Dynamic Blocks 19.8 Dynamic Blocks Visibility State 19.9 Defining Attributes 19.10 Editing Attributes 19.11 Block Attribute Manager 19.12 Attribute Extraction Wizard 19.13 AutoCAD Tables and Spreadsheets · Chapter 20 · Design Center and Tool Palettes 20.1 Design Center Overview 20.2 Design Center Blocks 20.3 Hatching from the Design Center 20.4 Tool Palettes · Chapter 21 · Point, Divide, and Measure 21.1 Point Styles 21.2 Point Command 21.3 Divide 21.4 Measure · Chapter 22 · Grips 22.1 Grips Overview 22.2 How to Use Grips 22.3 Copy Multiple with Grips 22.4 Grip Settings (DDGRIPS) Command · Chapter 23 · External References 23.1 External Reference File Overview 23.2 Attaching Xrefs 23.3 Clipping Xrefs 23.4 Xref Layers 23.5 Binding Xrefs 23.6 Editing Xrefs 23.7 Overlay and Xrefs · Chapter 24 · Raster Images 24.1 Inserting Images 24.2 Adjusting Image Appearance 24.3 Clipping Images · Chapter 25 · Advanced Selection Commands 25.1 Selection Modes 25.2 Groups 25.3 Object Selection Cycling 25.4 Draw Order 25.5 Object Filters 25.6 Quick Select 25.7 Layer Filters 25.8 Point Filters · Chapter 26 · Dimensioning 26.1 Linear Dimensions 26.2 Aligned Dimensions 26.3 ArcLength Dimensions 26.4 Radial Dimensions 26.5 Angular Dimensions 26.6 Baseline Dimensions 26.7 Continued Dimensions 26.8 Leaders 26.9 Quick Dimensions 26.10 Ordinate Dimensions · Chapter 27 · Dimension Styles 27.1 Creating New Dimension Styles 27.2 Lines 27.3 Symbols and Arrows 27.4 Text 27.5 Primary Units 27.6 Alternate Units 27.7 Tolerances 27.8 Fit and Dim Scales 27.9 Modifying Dimensions 27.10 Typing Dimension Variables 27.11 Dimension Overrides · Chapter 28 · Views and Viewports 28.1 Named Views 28.2 Viewports · Chapter 29 · Model Space and Paper Space 29.1 Creating a Layout 29.2 Mview Command 29.3 Irregular Shaped Viewports 29.4 Modelspace and Paperspace 29.5 Maximizing Viewports 29.6 Adding Text in Pspace 29.7 Plotting in Paper Space 29.8 Layout Wizard 29.9 Viewport Layers · Chapter 30 · Options Menu 30.1 Files 30.2 Miscellaneous Display 30.3 Open and Save Options 30.4 Plot and Publish Options 30.5 System Settings 30.6 User Preferences 30.7 Drafting Options 39.8 Selection and Profile Options · Chapter 31 · Drawing Utilities 31.1 Audit 31.2 Drawing Recovery Manager 31.3 Rename · Chapter 32 · Data Management 32.1 Importing Files 32.2 Exporting Files 32.3 Copying from AutoCAD 32.4 Print Screen 32.5 Sheet Sets 32.6 New Sheet Sets 32.7 Sheet Set Manager 32.7 Opening Sheet Sets · Chapter 33 · OLE and External Applications 33.1 OLE Linking to AutoCAD 33.4 Hyperlinks 33.5 Opening a Hyperlink · Chapter 34 · Communication and Collaboration Tools 34.1 Plotting to WEB 34.2 Configuring DWF Files 34.3 Publish Command 34.4 Publish to WEB 34.5 e-Transmit 34.6 i-Drop · Chapter 35 · AutoCAD WEB 35.1 Autodesk DWF Viewer 35.2 Autodesk Composer · Chapter 36 · Customization 36.1 Creating Personalized Workspace 36.2 Customize User Interface 36.3 Exporting/Saving CUI 36.4 Importing/Loading CUI 36.5 Customizing Toolbars 36.6 Customizing Menus 36.7 Keyboard Shortcuts 36.8 Mouse Buttons · Chapter 37 · External Applications and LISP Routines 37.1 Loading LISP Routines and External Applications 37.2 Menus with LISP Routines · Chapter 38 · CAD Standards 38.1 Configuring CAD Standards 38.2 Check Drawing Standards 38.3 Layer Translator 38.4 Redline Markup Language 38.5 Revision Cloud 38.6 Wipeout · Chapter 39 · Slide Shows 39.1 Mslide Command 39.2 Scripts 39.3 Pausing a Slide 39.4 Running a Script 39.5 Repeating a Script/Slideshow · Chapter 40 · Isometrics Autocad 3D · Chapter 1 · Controlling Views 1.1 Viewports 1.2 3D Viewports 1.3 Preset Views 1.4 Vpoint Tripod 1.5 Vpoint Rotate 1.6 3D Vpoint 1.7 Vpoint Vectors 1.8 Preset Viewpoints 1.9 Plan View · Chapter 2 · Thickness and Elevation 2.1 Thickness 2.2 Changing Thicknesses 2.3 Elevation 2.4 Elevation Shortcut · Chapter 3 · Visualizing the Model 3.1 Hide 3.2 Shade 3.3 Shadedge 3.4 Shadedif 3.5 Hidden Line Removal for Plots 3.6 Hidden Line Removal for Mviews · 4 · Chapter 4 · Z Coordinates 4.1 3D Coordinates – 3D Polylines 4.2 Move in Z Direction 4.3 3D Point Filters · Chapter 5 · User Coordinate System 5.1 UCS Icon 5.2 UCS Overview 5.3 World Coordinate System 5.4 3 Point UCS 5.5 Plan UCS 5.6 UCS View 5.7 UCS Object 5.8 Other New UCS Options 5.9 Saving UCS 5.10 Restoring UCS 5.11 UCS Dialog Box · Chapter 6 · 3D Orbit 6.1 Introduction to 3D Orbit 6.2 Zoom and Pan in 3D Orbit 6.3 Projection Mode 6.4 Shading in 3D Orbit 6.5 Camera, Swivel, and Distance 6.6 Visual Aids 6.7 Clipping Planes 6.7 Continuous Orbit · Chapter 7 · Dynamic View and Perspective 7.1 DView Camera 7.2 DView Target 7.3 Setting Camera and Target with POint option 7.4 Setting Perspective Distance 7.5 Turning Perspective Off 7.6 Zooming in DView 7.7 Panning in DView 7.8 Clipping Plane 7.9 Twisting Objects 7.10 Hiding Objects in DView · Chapter 8 · 3D Model Objects 8.1 Wireframes 8.2 Surfaces 8.3 Solids · Chapter 9 · 2D Solids and 3D Faces 9.1 2D Solids 9.2 Hatch Solids 9.3 3D Face 9.4 Edge 9.5 3D Invisible Face 9.6 Pface · Chapter 10 · 3D Surfaces 10.1 Box 10.2 Pyramid 10.3 Wedge 10.4 Dome 10.5 Sphere 10.6 Cone 10.7 Torus 10.8 Dish 10.9 Mesh · Chapter 11 · Complex Surfaces 11.1 Revolved Surfaces (Revsurf) 11.2 Surftab Variables 11.3 Tabulated Surfaces (Tabsurf) 11.4 Ruled Surfaces (Rulesurf) 11.5 Edge Surfaces (Edgesurf) · Chapter 12 · Solids 12.1 Extrude 12.2 Extrude with Taper 12.3 Extrude Curves 12.4 Extrude with Path 12.5 Revolve 12.6 Box 12.7 Sphere 12.8 Isolines 12.9 Facetres 12.10 Cone 12.11 Wedge 12.12 Torus · Chapter 13 · 3D Edits 13.1 Rotate 3D 13.2 Align 13.3 Mirror 3D 13.4 Rectangular Array 3D 13.5 Polar Array 3D · Chapter 14 · Solid Composites 14.1 Subtract 14.2 Union 14.3 Intersect · Chapter 15 · Modifying Solids 15.1 Extrude Face 15.2 Taper Face 15.3 Delete Face 15.4 Copy Face 15.5 Color Face 15.6 Imprint 15.7 Extrude Imprint 15.8 Clean 15.9 Shell · Chapter 16 · Enhancing the Drawing Process 16.1 Section Command 16.2 Slice Command 16.3 Solview 16.4 SolDraw 16.5 Create 3D View UCS 16.6 SolProf · Chapter 17 · Rendering 17.1 Render 17.2 Render Selection 17.3 Render Cropped Window 17.4 Render Without a Dialog Box 17.5 Turning Render Dialog Box On 17.6 Render to File 17.7 Print Screen 17.8 Render Window 17.9 Light Scale Icon Smoothing · Chapter 18 · Materials 18.1 Render Materials 18.2 Materials Library 18.3 Applying Materials by Attach 18.4 Applying Materials by Layer 18.5 Applying Materials by Color 18.6 Complex Materials 18.7 Material Mapping 18.8 New Materials 18.9 Adjusting Material Appearance 18.10 Advanced Settings · Chapter 19 · Lights 19.1 Point Light 19.2 Spotlight 19.3 Shadow Options – Light Command 19.4 Shadow Options – Render Command 19.5 Preferences 19.6 Distant Light · Chapter 20 · Scenes 20.1 Scene Command 20.2 Adding Views to Scenes · Chapter 21 · Backgrounds 21.1 Solid Background 21.2 Gradient Background 21.3 Image Background 21.4 Merge Background · Chapter 22 · Landscaping 22.1 Landscape New 22.2 Landscape Edit 22.3 Custom Landscapes · Chapter 23 · Miscellaneous Render Commands 3d studio max · Visual Quickstart Guide Chapter 1 · 3D Studio MAX – Getting Started 1.1 Touring the Interface (page7) 1.2 Special Controls (page 1.3 Managing Files (page 17) 1.4 Backing up Files (page 2 · Visual Quickstart Guide Chapter 2 · 3D Studio MAX – Creating Objects 2.1 About Creating Objects (page 32) 2.2 Creating Mesh Objects Standard Primitives (page 37) 2.3 Mesh Objects Extended Primitives (page 47) 2.4 Creating Shape Splines (page 5 2.5 Placing Text (page 69) 2.6 Creating Sections (page 70) 2.7 AutoGrid and Helper Grid (page 71) 2.8 Units of Measure (page 73) · Visual Quickstart Guide Chapter 3 · 3D Studio MAX – Viewport and Navigation Display 3.1 Customizing Viewports (page 80) 3.2 Changing Viewport Resolution (page 89) 3.3 Navigating Viewports (page 92) 3.4 Test Rendering (page 106) · Visual Quickstart Guide Chapter 4 · 3D Studio MAX – Object Selection and Display 4.1 Selecting Objects (page 10 4.2 Region Selection (page 110) 4.3 Selecting by Name (page 115) 4.4 Grouping Objects (page 117) 4.5 Changing Object Display (page 121) · Visual Quickstart Guide Chapter 5 · 3D Studio MAX – Transforms 5.1 Transform Tools (page 12 5.2 Transform Gizmos (page 131) 5.3 Advanced Controls using Transform Centers (page 135) 5.4 Precision Aids and Other Transforms (page 139) · Visual Quickstart Guide Chapter 6 · 3D Studio MAX – Modifying Objects 6.1 Bend Modifer (page 16 6.2 Twist Modifiers (page 169) 6.3 Noise Modifier (page 171) 6.4 Free Form Deformations (page 191) 6.5 Lathe Modifier (page 187) 6.6 Animating with a Melt Modifer (page 189) 6.7 Ripple Effect (page 190) · Visual Quickstart Guide Chapter 7 · 3D Studio MAX – Animations 7.1 Moving Through Time (page 196) 7.2 Configuring Time (page 19 7.3 Key Framing (page 204) 7.4 Working with Keys (page 209) 7.5 Motion Controllers (page 213) 7.6 Curve Editor Controller (page 21 7.7 Adding Sound (page 222) 7.8 Constraining Animators (page 225) 7.9 Linking Objects (page 227) 7.10 Animating Links (page 229) · Visual Quickstart Guide Chapter 8 · 3D Studio MAX – Editing Meshes 8.1 Editing Meshes and Sub Objects (page 232) 8.2 Extruding Polygons from AutoCAD Objects (page 254) · Visual Quickstart Guide Chapter 10 · 3D Studio MAX – Compound Objects – Creating Terrains · Visual Quickstart Guide Chapter 11 · 3D Studio MAX – Lights 11.1 Creating Lights, Spotlight, Omni Light, Free Directional Light (page 337) 11.2 Skylights (page 344) 11.3 Sunlight Systems (page 346) 11.4 Casting Shadows (page 347) 11.3 Controlling Illumination (page 355) 11.4 Navigating Lights (page 365) 11.5 Animating Lights (page 372) · Visual Quickstart Guide Chapter 12 · 3D Studio MAX – Cameras 12.1 Creating Cameras (page 377) 12.2 Adjusting Cameras (page 381) 12.3 Navigating Cameras (page 38 12.4 Animating Cameras (page 396) · Visual Quickstart Guide Chapter 13 · 3D Studio MAX – Creating Materials 13.1 Using the Material Editor (page 402) 13.2 Using Material Libraries (page 412) 13.3 Creating Standard Materials (page 415) 13.4 Creating Compound Materials (page 426) · Visual Quickstart Guide Chapter 14 · 3D Studio MAX – Working with Maps 14.1 Browsing Maps (page 433) 14.2 Creating Maps (page 436) 14.3 Create a Noise Map (page 440) 14.4 Adding Maps to Materials (page 443) 14.5 Adding Maps to Materials (Faces Only) 14.6 Opacity Maps (page 446) 14.7 Bump Maps (page 447) 14.8 Reflections (page 455) · Camera Matching · Visual Quickstart Guide Chapter 15 · 3D Studio MAX – Rendering 15.1 Rendering Scenes (page 462) 15.2 Rendering an Animation to a Movie File (page 472) 15.3 Render an Image with Motion Blur (page 473) 15.4 Fog Effects (page 47 15.5 Volume Fog Effect (page 480) 15.6 Fire Effect (page 482) 15.7 Post Process Film Grain Effect (page 48 · Particle Systems |
| Herramientas | |
Temas Similares
| Exportar d autocad 2002 a 3d Max 7, y abrirlo con 3d max 7 | b_boy_89 | Diseño Grafico y CAD | 2 | 14 nov 2007 13:43 |
| Necesito el 3D STUDIO MAX 6.0 + CARÁCTER STUDIO | DFeniX | Peticiones y Búsquedas | 11 | 24 feb 2005 12:07 |
| Problemas con 3D Studio Max | ultimando | Discusiones generales | 1 | 09 dic 2004 13:35 |
| Problema con 3D Studio MAX | zorro | Problemas con Programas | 4 | 08 nov 2004 14:36 |
| Exportar de Autocad a 3D max | mac3d++ | Diseño Grafico y CAD | 0 | 02 oct 2004 19:24 |
