Foros 3DPoder
Retroceder   Foros 3DPoder > :: Infografía y diseño gráfico. > Tutoriales, Libros y Manuales.
ViDeoTuToRiaLeS oN LiNe auToCaD 2D, 3D y 3D STuDio MaX
Tema Cerrado
LinkBack Herramientas
Antiguo 29-abr-2008   #1 (enlace permanente)
g0o0z
Avatar de g0o0z
* Ha dado las gracias: 0
Agradecido 2 veces en un mensaje
Predeterminado ViDeoTuToRiaLeS oN LiNe auToCaD 2D, 3D y 3D STuDio MaX
Links de cursos de Cad y MaX muy buenos, en ingles pero se entienden superbien, algunos capitulos vienen con su pdf saludos
AutoCAD 2D Tutorials
AutoCAD 3D Tutorials
3D Studio MAX Videos
He aqui con todo y el temario completisimo:
Autocad 2D
· Chapter 1
· Introduction to AutoCAD
1.1 Launching AutoCAD
1.2 Text and Graphics Screens
1.3 Cursor
1.4 Cancel
1.5 Menus and Colors
1.6 Toolbars
1.7 Status Bar and Command Prompt
1.8 Typing Commands/Aliases
1.9 AutoCAD Pointing Device
1.10 Undo
1.11 Function and Accelerator Keys
1.12 Online Help
· Chapter 2
· Introduction to Commands
2.1 Opening a Drawing
2.2 New Drawings
2.3 Saving Drawings
2.4 File Safety Precautions
2.5 Exiting AutoCAD
· Chapter 3
· Draw Commands
3.1 Line Command
3.2 Cartesian Coordinate System
3.3 Dynamic Input
3.4 Orthogonal Lines
3.5 Polar Tracking
3.6 Circles
3.7 Arcs
· Chapter 4
· Erase and Selection Sets
4.1 Erase and Selection Sets
4.2 Selection Set Options
4.3 Oops Command
4.4 Selection Preview
· Chapter 5
· Basic Display Commands
5.1 Zoom
5.2 Pan
5.3 Redraw and Regen
5.4 Blipmode
5.5 Aerial View
· Chapter 6
· Drawing Aids
6.1 Snap
6.2 Grid
· Chapter 7
· Object Snapping
7.1 Object Snaps
7.2 Case by Case Object Snaps
7.3 Object Snap Settings
7.4 Aperture
· Chapter 8
· Setting Up a Drawing
8.1 List
8.2 Measuring Distances
8.3 Calculating Areas
8.4 Quick Calc Command
8.5 ID Command
8.6 Units
8.7 Drawing Limits
8.8 Drawing Scales and Paper Sizes
8.9 Scalelist Command
· Chapter 9
· Plotting
9.1 Plot Command
9.2 Adding a Plotter
9.3 Plot Settings
9.4 Plot Styles
95. Add a Plot Style
9.4 Named Plot Styles
· Chapter 10
· Edit Commands
10.1 Move
10.2 Copy
10.3 Previous Selection
10.4 Offset
10.5 Extend
10.6 Trim
10.7 Mirror
10.8 Rotate
10.9 Scale
· Chapter 11
· Text
11.1 Text
11.2 Text Justification
11.3 Text Styles
11.4 Font Files
11.5 Multiline Text
11.6 Editing Text
11.7 Special Control Codes
11.8 Spell Check
11.9 Scale Text
· Chapter 12
· Layers, Linetypes, and Colors
12.1 Intro to Layers and Layer Dialog
12.2 Layer Shortcuts
12.3 Layer Previous
12.4 Layer States
12.5 Color Command
12.6 Linetypes
12.7 Lineweights
12.8 Object Properties
· Chapter 13
· More Edit Commands
13.1 Break
13.2 Stretch
13.3 Fillet
13.4 Chamfer
13.5 Rectangular Array
13.6 Polar Array
13.7 Lengthen
13.8 Join
· Chapter 14
· Advanced Display Commands
14.1 Transparent Commands
14.2 Multiple Command
14.3 Advanced Calculator Functions
· Chapter 15
· Polylines
15.1 Pline Options
15.2 Editing Polylines
15.3 Editing Vertex Options
15.4 Explode Command
15.5 Turning Lines into Polylines
· Chapter 16
· More Draw Commands
16.1 Polygon
16.2 Rectangle
16.3 Spline
16.4 Converting Plines to Splines
16.5 Donut
16.6 Ellipse
16.7 Multilines and Editing Multilines
16.8 Construction Lines and Rays
· Chapter 17
· Crosshatching
17.1 Hatch Command
17.2 Hatch Boundaries
17.3 Hatch Origin
17.4 Gradient Hatch
17.5 Hatch Options
17.6 Editing Crosshatch Patterns
17.7 Inherit Hatch
· Chapter 18
· Boundaries and Regions
18.1 Boundary Command
18.2 Region Command
· Chapter 19
· Blocks and Attributes
19.1 Creating Local Blocks
19.2 Inserting Blocks
19.3 Control Color and Linetypes of Blocks
19.4 WBLOCK Command
19.5 Purge
19.6 Creating Dynamic Blocks
19.7 Manipulating Dynamic Blocks
19.8 Dynamic Blocks Visibility State
19.9 Defining Attributes
19.10 Editing Attributes
19.11 Block Attribute Manager
19.12 Attribute Extraction Wizard
19.13 AutoCAD Tables and Spreadsheets
· Chapter 20
· Design Center and Tool Palettes
20.1 Design Center Overview
20.2 Design Center Blocks
20.3 Hatching from the Design Center
20.4 Tool Palettes
· Chapter 21
· Point, Divide, and Measure
21.1 Point Styles
21.2 Point Command
21.3 Divide
21.4 Measure
· Chapter 22
· Grips
22.1 Grips Overview
22.2 How to Use Grips
22.3 Copy Multiple with Grips
22.4 Grip Settings (DDGRIPS) Command
· Chapter 23
· External References
23.1 External Reference File Overview
23.2 Attaching Xrefs
23.3 Clipping Xrefs
23.4 Xref Layers
23.5 Binding Xrefs
23.6 Editing Xrefs
23.7 Overlay and Xrefs
· Chapter 24
· Raster Images
24.1 Inserting Images
24.2 Adjusting Image Appearance
24.3 Clipping Images
· Chapter 25
· Advanced Selection Commands
25.1 Selection Modes
25.2 Groups
25.3 Object Selection Cycling
25.4 Draw Order
25.5 Object Filters
25.6 Quick Select
25.7 Layer Filters
25.8 Point Filters
· Chapter 26
· Dimensioning
26.1 Linear Dimensions
26.2 Aligned Dimensions
26.3 ArcLength Dimensions
26.4 Radial Dimensions
26.5 Angular Dimensions
26.6 Baseline Dimensions
26.7 Continued Dimensions
26.8 Leaders
26.9 Quick Dimensions
26.10 Ordinate Dimensions
· Chapter 27
· Dimension Styles
27.1 Creating New Dimension Styles
27.2 Lines
27.3 Symbols and Arrows
27.4 Text
27.5 Primary Units
27.6 Alternate Units
27.7 Tolerances
27.8 Fit and Dim Scales
27.9 Modifying Dimensions
27.10 Typing Dimension Variables
27.11 Dimension Overrides
· Chapter 28
· Views and Viewports
28.1 Named Views
28.2 Viewports
· Chapter 29
· Model Space and Paper Space
29.1 Creating a Layout
29.2 Mview Command
29.3 Irregular Shaped Viewports
29.4 Modelspace and Paperspace
29.5 Maximizing Viewports
29.6 Adding Text in Pspace
29.7 Plotting in Paper Space
29.8 Layout Wizard
29.9 Viewport Layers
· Chapter 30
· Options Menu
30.1 Files
30.2 Miscellaneous Display
30.3 Open and Save Options
30.4 Plot and Publish Options
30.5 System Settings
30.6 User Preferences
30.7 Drafting Options
39.8 Selection and Profile Options
· Chapter 31
· Drawing Utilities
31.1 Audit
31.2 Drawing Recovery Manager
31.3 Rename
· Chapter 32
· Data Management
32.1 Importing Files
32.2 Exporting Files
32.3 Copying from AutoCAD
32.4 Print Screen
32.5 Sheet Sets
32.6 New Sheet Sets
32.7 Sheet Set Manager
32.7 Opening Sheet Sets
· Chapter 33
· OLE and External Applications
33.1 OLE Linking to AutoCAD
33.4 Hyperlinks
33.5 Opening a Hyperlink
· Chapter 34
· Communication and Collaboration Tools
34.1 Plotting to WEB
34.2 Configuring DWF Files
34.3 Publish Command
34.4 Publish to WEB
34.5 e-Transmit
34.6 i-Drop
· Chapter 35
· AutoCAD WEB
35.1 Autodesk DWF Viewer
35.2 Autodesk Composer
· Chapter 36
· Customization
36.1 Creating Personalized Workspace
36.2 Customize User Interface
36.3 Exporting/Saving CUI
36.4 Importing/Loading CUI
36.5 Customizing Toolbars
36.6 Customizing Menus
36.7 Keyboard Shortcuts
36.8 Mouse Buttons
· Chapter 37
· External Applications and LISP Routines
37.1 Loading LISP Routines and External Applications
37.2 Menus with LISP Routines
· Chapter 38
· CAD Standards
38.1 Configuring CAD Standards
38.2 Check Drawing Standards
38.3 Layer Translator
38.4 Redline Markup Language
38.5 Revision Cloud
38.6 Wipeout
· Chapter 39
· Slide Shows
39.1 Mslide Command
39.2 Scripts
39.3 Pausing a Slide
39.4 Running a Script
39.5 Repeating a Script/Slideshow
· Chapter 40
· Isometrics
Autocad 3D
· Chapter 1
· Controlling Views
1.1 Viewports
1.2 3D Viewports
1.3 Preset Views
1.4 Vpoint Tripod
1.5 Vpoint Rotate
1.6 3D Vpoint
1.7 Vpoint Vectors
1.8 Preset Viewpoints
1.9 Plan View
· Chapter 2
· Thickness and Elevation
2.1 Thickness
2.2 Changing Thicknesses
2.3 Elevation
2.4 Elevation Shortcut
· Chapter 3
· Visualizing the Model
3.1 Hide
3.2 Shade
3.3 Shadedge
3.4 Shadedif
3.5 Hidden Line Removal for Plots
3.6 Hidden Line Removal for Mviews
· 4
· Chapter 4
· Z Coordinates
4.1 3D Coordinates – 3D Polylines
4.2 Move in Z Direction
4.3 3D Point Filters
· Chapter 5
· User Coordinate System
5.1 UCS Icon
5.2 UCS Overview
5.3 World Coordinate System
5.4 3 Point UCS
5.5 Plan UCS
5.6 UCS View
5.7 UCS Object
5.8 Other New UCS Options
5.9 Saving UCS
5.10 Restoring UCS
5.11 UCS Dialog Box
· Chapter 6
· 3D Orbit
6.1 Introduction to 3D Orbit
6.2 Zoom and Pan in 3D Orbit
6.3 Projection Mode
6.4 Shading in 3D Orbit
6.5 Camera, Swivel, and Distance
6.6 Visual Aids
6.7 Clipping Planes
6.7 Continuous Orbit
· Chapter 7
· Dynamic View and Perspective
7.1 DView Camera
7.2 DView Target
7.3 Setting Camera and Target with POint option
7.4 Setting Perspective Distance
7.5 Turning Perspective Off
7.6 Zooming in DView
7.7 Panning in DView
7.8 Clipping Plane
7.9 Twisting Objects
7.10 Hiding Objects in DView
· Chapter 8
· 3D Model Objects
8.1 Wireframes
8.2 Surfaces
8.3 Solids
· Chapter 9
· 2D Solids and 3D Faces
9.1 2D Solids
9.2 Hatch Solids
9.3 3D Face
9.4 Edge
9.5 3D Invisible Face
9.6 Pface
· Chapter 10
· 3D Surfaces
10.1 Box
10.2 Pyramid
10.3 Wedge
10.4 Dome
10.5 Sphere
10.6 Cone
10.7 Torus
10.8 Dish
10.9 Mesh
· Chapter 11
· Complex Surfaces
11.1 Revolved Surfaces (Revsurf)
11.2 Surftab Variables
11.3 Tabulated Surfaces (Tabsurf)
11.4 Ruled Surfaces (Rulesurf)
11.5 Edge Surfaces (Edgesurf)
· Chapter 12
· Solids
12.1 Extrude
12.2 Extrude with Taper
12.3 Extrude Curves
12.4 Extrude with Path
12.5 Revolve
12.6 Box
12.7 Sphere
12.8 Isolines
12.9 Facetres
12.10 Cone
12.11 Wedge
12.12 Torus
· Chapter 13
· 3D Edits
13.1 Rotate 3D
13.2 Align
13.3 Mirror 3D
13.4 Rectangular Array 3D
13.5 Polar Array 3D
· Chapter 14
· Solid Composites
14.1 Subtract
14.2 Union
14.3 Intersect
· Chapter 15
· Modifying Solids
15.1 Extrude Face
15.2 Taper Face
15.3 Delete Face
15.4 Copy Face
15.5 Color Face
15.6 Imprint
15.7 Extrude Imprint
15.8 Clean
15.9 Shell
· Chapter 16
· Enhancing the Drawing Process
16.1 Section Command
16.2 Slice Command
16.3 Solview
16.4 SolDraw
16.5 Create 3D View UCS
16.6 SolProf
· Chapter 17
· Rendering
17.1 Render
17.2 Render Selection
17.3 Render Cropped Window
17.4 Render Without a Dialog Box
17.5 Turning Render Dialog Box On
17.6 Render to File
17.7 Print Screen
17.8 Render Window
17.9 Light Scale Icon Smoothing
· Chapter 18
· Materials
18.1 Render Materials
18.2 Materials Library
18.3 Applying Materials by Attach
18.4 Applying Materials by Layer
18.5 Applying Materials by Color
18.6 Complex Materials
18.7 Material Mapping
18.8 New Materials
18.9 Adjusting Material Appearance
18.10 Advanced Settings
· Chapter 19
· Lights
19.1 Point Light
19.2 Spotlight
19.3 Shadow Options – Light Command
19.4 Shadow Options – Render Command
19.5 Preferences
19.6 Distant Light
· Chapter 20
· Scenes
20.1 Scene Command
20.2 Adding Views to Scenes
· Chapter 21
· Backgrounds
21.1 Solid Background
21.2 Gradient Background
21.3 Image Background
21.4 Merge Background
· Chapter 22
· Landscaping
22.1 Landscape New
22.2 Landscape Edit
22.3 Custom Landscapes
· Chapter 23
· Miscellaneous Render Commands
3d studio max
· Visual Quickstart Guide Chapter 1
· 3D Studio MAX – Getting Started
1.1 Touring the Interface (page7)
1.2 Special Controls (page
1.3 Managing Files (page 17)
1.4 Backing up Files (page 2
· Visual Quickstart Guide Chapter 2
· 3D Studio MAX – Creating Objects
2.1 About Creating Objects (page 32)
2.2 Creating Mesh Objects
Standard Primitives (page 37)
2.3 Mesh Objects
Extended Primitives (page 47)
2.4 Creating Shape Splines (page 5
2.5 Placing Text (page 69)
2.6 Creating Sections (page 70)
2.7 AutoGrid and Helper Grid
(page 71)
2.8 Units of Measure (page 73)
· Visual Quickstart Guide Chapter 3
· 3D Studio MAX – Viewport and Navigation Display
3.1 Customizing Viewports (page 80)
3.2 Changing Viewport Resolution (page 89)
3.3 Navigating Viewports (page 92)
3.4 Test Rendering (page 106)
· Visual Quickstart Guide Chapter 4
· 3D Studio MAX – Object Selection and Display
4.1 Selecting Objects (page 10
4.2 Region Selection (page 110)
4.3 Selecting by Name (page 115)
4.4 Grouping Objects (page 117)
4.5 Changing Object Display (page 121)
· Visual Quickstart Guide Chapter 5
· 3D Studio MAX – Transforms
5.1 Transform Tools (page 12
5.2 Transform Gizmos (page 131)
5.3 Advanced Controls using Transform Centers (page 135)
5.4 Precision Aids and Other Transforms (page 139)
· Visual Quickstart Guide Chapter 6
· 3D Studio MAX – Modifying Objects
6.1 Bend Modifer (page 16
6.2 Twist Modifiers (page 169)
6.3 Noise Modifier (page 171)
6.4 Free Form Deformations (page 191)
6.5 Lathe Modifier (page 187)
6.6 Animating with a Melt Modifer (page 189)
6.7 Ripple Effect (page 190)
· Visual Quickstart Guide Chapter 7
· 3D Studio MAX – Animations
7.1 Moving Through Time (page 196)
7.2 Configuring Time (page 19
7.3 Key Framing (page 204)
7.4 Working with Keys (page 209)
7.5 Motion Controllers (page 213)
7.6 Curve Editor Controller (page 21
7.7 Adding Sound (page 222)
7.8 Constraining Animators (page 225)
7.9 Linking Objects (page 227)
7.10 Animating Links (page 229)
· Visual Quickstart Guide Chapter 8
· 3D Studio MAX – Editing Meshes
8.1 Editing Meshes and Sub Objects (page 232)
8.2 Extruding Polygons from AutoCAD Objects (page 254)
· Visual Quickstart Guide Chapter 10
· 3D Studio MAX – Compound Objects – Creating Terrains
· Visual Quickstart Guide Chapter 11
· 3D Studio MAX – Lights
11.1 Creating Lights, Spotlight, Omni Light, Free Directional Light (page 337)
11.2 Skylights (page 344)
11.3 Sunlight Systems (page 346)
11.4 Casting Shadows (page 347)
11.3 Controlling Illumination (page 355)
11.4 Navigating Lights (page 365)
11.5 Animating Lights (page 372)
· Visual Quickstart Guide Chapter 12
· 3D Studio MAX – Cameras
12.1 Creating Cameras (page 377)
12.2 Adjusting Cameras (page 381)
12.3 Navigating Cameras (page 38
12.4 Animating Cameras (page 396)
· Visual Quickstart Guide Chapter 13
· 3D Studio MAX – Creating Materials
13.1 Using the Material Editor (page 402)
13.2 Using Material Libraries (page 412)
13.3 Creating Standard Materials (page 415)
13.4 Creating Compound Materials (page 426)
· Visual Quickstart Guide Chapter 14
· 3D Studio MAX – Working with Maps
14.1 Browsing Maps (page 433)
14.2 Creating Maps (page 436)
14.3 Create a Noise Map (page 440)
14.4 Adding Maps to Materials (page 443)
14.5 Adding Maps to Materials (Faces Only)
14.6 Opacity Maps (page 446)
14.7 Bump Maps (page 447)
14.8 Reflections (page 455)
· Camera Matching
· Visual Quickstart Guide Chapter 15
· 3D Studio MAX – Rendering
15.1 Rendering Scenes (page 462)
15.2 Rendering an Animation to a Movie File (page 472)
15.3 Render an Image with Motion Blur (page 473)
15.4 Fog Effects (page 47
15.5 Volume Fog Effect (page 480)
15.6 Fire Effect (page 482)
15.7 Post Process Film Grain Effect (page 48
· Particle Systems
g0o0z está desconectado
Tema Cerrado
Marcadores
Etiquetas
autocad, line, max, studio, videotutoriales
(0 miembros y 1 visitantes)
Herramientas
Normas de Publicación
No puedes crear nuevos temas
No puedes responder temas
No puedes subir archivos adjuntos
No puedes editar tus mensajes
Los Códigos BB están Activado
Las Caritas están Activado
[IMG] está Activado
El Código HTML está Desactivado
Trackbacks are Desactivado
Pingbacks are Desactivado
Refbacks are Activado
Ir al Foro
Temas Similares
importacion de autocad a 3d max fraktal Modelado 4 11-jun-2008 09:51
Trayectorias y camaras en 3D studio max Rebirth07 Render, Iluminación y Cámaras 1 21-nov-2007 19:11
Exportar d autocad 2002 a 3d Max 7, y abrirlo con 3d max 7 b_boy_89 Diseño Gráfico y CAD 2 14-nov-2007 20:43
Necesito el 3D STUDIO MAX 6.0 + CARÁCTER STUDIO DFEX Peticiones y Búsquedas 11 24-feb-2005 19:07
Exportar de Autocad a 3D max mac3d++ Diseño Gráfico y CAD 0 03-oct-2004 02:24
La franja horaria es GMT. Ahora son las 02:55.
Desarrollado por: vBulletin® Versión 3.8.4
Derechos de Autor ©2000 - 2010, Jelsoft Enterprises Ltd.
Traducido por mcloud - vBHispano.com
Content Relevant URLs by vBSEO 3.3.2
