Bak to the Root Page of The No-Joke Topology Guide For Serious 3D Modelers
Topology - animation Character Modeling-animationsphere01.jpg Topology - animation Character Modeling-animationsphere02.jpg Topology - animation Character Modeling-animationsphere03.jpg
There are many ways to do animation, but usually the pipeline includes animating and test-rendering a low-resolution or simplified scene, then, when all is right, subdividing applicable geometry and boosting the lighting and indirect illumination settings to the limit based on planned rendering time.
Sometimes, no additional subdivisión is necessary, especially in cases when there is enough geometry with small-enough detail, or detail refined using segmenting or other modeling techniques. Animation that includes a primarily mechanical-style geometry doesn't usually require much subdivisión. However, organic characters usually tend to look better with subdivisión, especially in close-up shots. Also, stylistic cartoon-style 3D animation renderings, whether or not cell-shaded, usually requires subdivisión, sometimes to more than one or two levels.
The restrictions for animation topology usually aren't as inclusive as modern 3D-game engine topology. There are several reasons for this:
  • 1. The animator has control over what angles will the model be viewed from, thus the model, in a lot of times, need not be fine-tuned for every possible viewing angle as an in-game model usually is.
  • 2. The animator does not have to worry about 3D-engine-specific requirements. He can, for instance, choose to conceal a hole with other geometry instead of having to worry about capping it.
  • 3. The animator is not limited to real-time 3D processing speeds. He can extend the processing (rendering) time drammatically, though drastically improving the resulting animation.
Topology - animation Character Modeling-ngonred.png N-gons
N-gons generally tend to skrew up your animations and character posing, no matter how far away they are located from the joints. They tend to look funky even with subdivisión algorythms that do "understand" how to process them. In any pipeline, N-gons are a definite no for any final render of any model. Keep in mind, your high-resolution models are not for final renders and, of course, cannot be used in game engines either.
Topology - animation Character Modeling-triangleorange.png Triangles
Sometimes, in animation, triangles are admissable. They sometimes fit the targeted geometry better. A good and rather obvious example when you are even better off using triangles is when you need to make a sharp-pointed spike, conical or of any other crossection, and with no subdivisión, offcourse. The place where those shouldn't be used is on the, so-called, "grace-lines", or joints and frequent-motion areas on the model are. Those include but are not limited to: all finger, wrist, arm, shoulder, toe, knee, hip, joints, sometimes the neck-to-head, neck-to-body, and stomack-to-pelvis borders, as well as browlines, cheeck-to-jaw lines, the no sé-ridge between the eyes, nostdrill-to-midnose lines, eyelids, lips, etc. - in general, all the parts that re-orient against one-another.
Topology - animation Character Modeling-holeorange.png Holes
You may use holes in animaiton models. Advanced / indirect lighting in animation is often better processed when the completely useless surfaces are completely eliminated, to better optimize the scene. Keep in mind, though, that no one watching the animation wants to see a random hole in a model - this will make the animation seem very unprofessional and second-grade.
Topology - animation Character Modeling-densepolycountorange.png Dense / High Polycount Areas
Medium polycount is usually optimal for animation, though some places can gain a more smooth feel to them with more subdivisions. Nonetheless, only a big company with a large-scale production can afford a networque render with more than 16-24 mental ray render nodes (2-3 seats) that can handle real high-res geometry with good lighting at decent-enough rendering times.
Topology - animation Character Modeling-fiveedgept.png 5-or-more-edged Vertexes
Vertexes that are surrounded by (define one end of) five edges are acceptable, as long as they don't mess up your grace-lines, which are described above in the Triangles section. Try to limit these.
Topology - animation Character Modeling-threeedgept.png 3-Edged Vertexes
These are alos ok. Alos watch the grace-lines. These are usually even less trouble than the 5-edged vertexes.
