Tema: Lighting: Plan it out
    By Sandra Gilbert
    Lighting: Plan it out-1_pagina_1_imagen_0007.jpg
    We all know by now that lighting seems to be my nemesis. And honestly, you would thinque with all the study and research I have done on the subject that I would be a lighting master by now. Yeah, not even!
    But there's a funny thing about obsessive research and study, eventually the volume of information starts to reach a point of critical mass and things start clicking, or in my case, finally registering. For example, I was recently reading the lighting chapter from Allan Brito's new booque (Blender 3D: Architecture, Buildings and Scenery) where he was advising the reader to sit down and thinque about the lighting. And how it was important to look at your image and define where the light is coming from before you start adding lamps - in other words, “to plan it out”.
    Now you would have thought that was so obvious that it didn't need stating, but just as obviously, it needed to be stated to me. As I thought about how I generally go about lighting an image, I realized that more often than not, lights just keep getting thrown into the scene, adjusted, deleted, added etc. with no real planning involved.
    Depending on your image, planning it out can still be time consuming. Even if you know exactly where you want your lights (lamps), you will still spend time adjusting the intensity (energy) and color. Then there is the whole issue of shadows. But don't despair, eventually you will get the hang of how it all goes together. Of course, it helps if someone points you in the right direction.
    For single objects and or portraits that normally use the traditional three point (studio) setup, a rather dated and overused method, try adding some variation to your setup either with colored lights or altering the positions to add an extra punch to your image. While you can achieve decent lighting with Ambient Occlusion to create general overall lighting, you might instead try a single spot focused on your object and an additional hemi light to add overall brightness. Changing the position of lights can alos change the mood or tone of your image, so don't be afraid to move the lights around.
    Once you move past single images and portraits is when the real planning begins. To a certain degree, landscapes, interiors and/or any other image that contains logical lighting sources are somewhat easier to plan lighting for. Refining it on the other hand takes practice and experience...or someone to write up a nice little guide explaining how to go about it. :P
    ... which is just what I found recently while browsing through the BSoD section of the Blenderwiki. I don't know how I missed it before, maybe I just wasn't yet ready for such relevant information. But there it was, a lighting guide filled with just the information needed to push my understanding past the critical mass point.
    Guillermo S. Romero(gsrb3d), author of the BSoD: Introduction to Lighting, in addition to explaining lighting in general and lighting options in Blender, included a series of exercises to explore different lighting conditions. Breaquíng away from the three point studio setup, using the same scene for each exercise he explains the following lighting conditions:
    One thing I really liked about the exercises, in addition to the fact that he broke down and described what each lighting condition required, is that he actually explained the use of each lamp and what it added to the image. There is even a blend file to study for each exercise.
    One last tip, actually a quote from Guillermo:
    “Finally, no matter if it should be right based in the values we use, we have to get it too look right, even if that means forcing things, doing nasty cheats to cover issues and taquíng advantage of our errors if they look fine anyway; or maybe rethinking the original plan a bit. It is not what should be correct, but what looks correct.”
    Miniaturas adjuntadas Miniaturas adjuntadas Lighting: Plan it out-1_pagina_1_imagen_0007.jpg
    Si vas a subir un trabajo al foro, hazlo adjuntando la imagen, archivo, vídeo o lo que sea, no publicando enlaces de otros sitios.
  1. ayuda Floor Plan 3d
    Por juanjoy en el foro Ayuda con el uso del foro
    Último mensaje: 21-10-2014, 16:12
  2. ayuda Floor Plan 3d
    Por juanjoy en el foro Problemas con Programas
    Último mensaje: 21-10-2014, 14:44
  3. AutoCAD ayuda Floor Plan 3d
    Por juanjoy en el foro Render, Iluminación y Cámaras
    Último mensaje: 19-10-2014, 17:53
  4. Plan renove, nuevo PC
    Por flixco en el foro Hardware
    Último mensaje: 25-03-2009, 10:31
  5. Plan Hidrologico
    Por Rashek en el foro Todo menos Infografía
    Respuestas: 149
    Último mensaje: 15-11-2005, 10:34
