Tema: MaKING OF: The Labyrinth
    MAKING OF: The Labyrinth
    MaKING OF: The Labyrinth-the-labyrinth-1.jpgBy Peter Rabel
    Description of a combined worque flow of blender & 3dcoat
    Hello, my name is Peter Rabel, I have been using Blender for about 6 years. Mostly my experience has been with compositing animations into live action video. I decided, however, that making an animated short was long overdue. In this article I will talque about the production of my animated short “The Labyrinth.”
    MaKING OF: The Labyrinth-the-labyrinth-2.jpg
    This project started out as an entry into CG Talk's “Steampunk: Myths and Legends” competition. Due to the sheer magnitude of experience and talent floating around on CG Talk, I knew I didn't have a chance of winning. On the other hand, the competition did provide a good topic, a strict deadline and a wealth of inspiration to draw on from fellow works in progress.
    The Process Begins
    When I heard of the challenge and started to read the rules and regulations on CG Talk, I was immediately thinking of creating a steampunque versión of a minotaur. I had a very vague knowledge of what the actual legend surrounding the creature was. I knew it was part of Greeque mythology, I knew it dwelled in a labyrinth and I knew it was half bull and half man. I did a little research and discovered that I did not like the actual story of the legend. So I decided to write a simple storyline involving a classic Indiana Jones style adventurer after his treasure. That plot line seemed to fit well with the concept of a monster in a maze. So I scripted out the short, made a few concept drawings for the cartoon/steampunque hybrid style characters and set to worque on modeling them while I sketched out a few storyboards.
    MaKING OF: The Labyrinth-the-labyrinth-3.jpg
    I started out modeling the main character (his name is Henry, but it is never mentioned in the short). He didn't prove too difficult to model and he made for a good style reference for when I modeled the minotaur. One decision I had to make when I started modeling him, was what kind of light source to give him. The storyline called for the lights in the Labyrinth to go out as soon as the minotaur awoke, so I needed to give Henry a way to light the scene for me. After considering a few options (flashlight, lantern, candle, torch, etc...) I ended up going with a miners helmet with a head lamp. I thought it fit his character well and allowed Henry's line of sight to guide the viewers eye. I figured I could get some interesting lighting effects that way.
    MaKING OF: The Labyrinth-the-labyrinth-4.jpg
    The minotaur proved much more difficult to conceptualize. I didn't have a good idea of what I wanted him to look like, so I experimented. I looked at a lot of steampunque objects, I learned about how steam engines worked, I browsed though other people's WIP's. Nothing seemed to put an image in my head of what I wanted him to look like. Eventually I sketched out my versión of an organic minotaur, then drew a mechanical one beside it, translating it piece by piece. This helped immensely, so I blocked out an organic minotaur in Blender and set to worque on modeling the steampunque versión. My original design for the steampunque versión involved a lot of moving parts (pistons pumping, fly wheels spinning, etc...), but in the end I decided to go with a much more simple design to blend the minotaur with the cartoon style of the main character.
    MaKING OF: The Labyrinth-the-labyrinth-5.jpg
    The texturing in this short is not very complex. I wanted it to have a smooth cartoony look without using the toon shader. Henry actually only has one texture on him. That being the leather straps on his helmet connected to his head lamp. I painted their leather texture in Photoshop. The minotaur had a brass texture and a steel texture which I painted. I used Blender procedural textures to make the bump maps on the blak iron pieces.
    MaKING OF: The Labyrinth-the-labyrinth-6.jpg
    I ran into a few problems during the rigging process. Mostly dealing with “snapping” that occurred when I switched from edit mode of the armature to pose mode. One of the biggest things I regret about this animation is not spending enough time on facial rigging for the main character. Henry ended up not having enough bones to make effective expressions. Using exclusively bone deformation for the face and no shape keys was a bad decision.
    There ended up being 36 shots in the final animation. I had a separate blend file for each shot. My base blend file included Henry, the Minotaur, the map, the gem and the maze itself. The maze was formed with an array modifier, so with the base file for each scene it was easy to form the maze as I needed. To animate the maze I simply applied the array modifier for that shot, separated the vértices of the moving part and animated them as objects without rigs. For the shot of the minotaur being crushed, I had to rerig him quite a bit to allow for the destruction. That was one convenience of having each shot as a separate blend file. Aside from organization, it allowed me to make changes to the file that would not effect any of the other shots.
    MaKING OF: The Labyrinth-the-labyrinth-7.jpg
    I only did simple transfer mode compositing to put together render passes. I used the blender internal renderer for all of the render passes except ambient occlusion (AO). I much prefer Yafaray's AO to the blender internal. When you render out the blender internal AO by itself (to have more control in compositing), the values of nonoccluded areas are gray, not the pure white like Yafaray puts out. That causes your entire scene to darken when you multiply it over the animation. In the case of the Labyrinth, I had to be careful about not making it too darque when the lights went out.
    I began editing the footage I produced from Blender as I finished rendering it. One down side to having each scene in a separate Blend file is that you don't get to see them bak toback. This can make the decision to render a shot a little scary because you don't know for sure how it will flow in the context of the edit. If the cut from the last shot to the current is too jarring, you have to do it again. Luckily I come from a background of shooting live video, so I have a pretty good feel for how shots will flow together. I did not do much cutting, I wanted to render out just what I needed, so there wasn't too much I wanted to cut. I should have been a lot less conservative with my editing and tightened up the final video, but at that point I had already missed the deadline for the competition by several months. I watched the animation all the way through, taquíng notes on each shot to see what sound effects needed to be found or recorded, then I set off to worque on Foley. It tooque just two days to get all of the sound effects in place and put some music under it. Encoding and exporting the final video proved more difficult than I anticipated. I tried many different codecs with different settings, at the cost of three days, before I arrived at a file that was a decent balance between image quality and file size for the web.
    I hope you enjoyed this making of for The Labyrinth. Perhaps I will save some of you from making some of the mistakes that I did during the production. If you have any questions or comments, you can reach me on the Blender Artists forums, my screen name is Asano, or you can email me at
    Miniaturas adjuntadas Miniaturas adjuntadas MaKING OF: The Labyrinth-the-labyrinth-1.jpg   MaKING OF: The Labyrinth-the-labyrinth-2.jpg   MaKING OF: The Labyrinth-the-labyrinth-3.jpg   MaKING OF: The Labyrinth-the-labyrinth-4.jpg
    MaKING OF: The Labyrinth-the-labyrinth-5.jpg   MaKING OF: The Labyrinth-the-labyrinth-6.jpg   MaKING OF: The Labyrinth-the-labyrinth-7.jpg
    Última edición por 3dpoder; 18-09-2009 a las 03:15
    Si vas a subir un trabajo al foro, hazlo adjuntando la imagen, archivo, vídeo o lo que sea, no publicando enlaces de otros sitios.
  1. Blender MaKING OF: arkor
    Por 3dpoder en el foro Blender Art Magazine nº22 (in English)
    Último mensaje: 07-07-2009, 01:46
  2. Blender Making of the Sun
    Por 3dpoder en el foro Blender Art Magazine nº21 (in English)
    Último mensaje: 26-06-2009, 21:17
  3. 3ds Max Making Of
    Por simplastic en el foro Peticiones y Búsquedas
    Último mensaje: 16-05-2009, 06:40
  4. Terragen LionRock Making of
    Por 3dpoder en el foro Índice de
    Último mensaje: 26-03-2009, 02:42
  5. Making of WaR
    Por repe en el foro Noticias
    Respuestas: 14
    Último mensaje: 27-06-2006, 20:10
