Foros 3DPoder.
Bienvenido a Foros 3DPoder..
¿Te ayudo?
Retroceder   Foros 3DPoder. > :: Técnicas 3d > Materiales y Texturizado
Oferta de trabajo en Decathlon
google adsense
Respuesta
Herramientas
Antiguo 25 ago 2004   #1
javierca
Predeterminado rejas
hola tengo un problema tengo que hacer una reja para un cerramiento exterior que es de alambre he visto que es con un material y un mapa de opacidad pero mi problema es que no se hacerlo me podriais ayudar.gracias
javierca is offline   Responder Con Cita
Enlaces patrocinados
Antiguo 25 ago 2004   #2
ikerCLoN
p a l e t o
Avatar de ikerCLoN
Predeterminado
Sacado de la ayuda de MAX:
Cita:
The gray levels of an opacity map determine the amount of opacity.
You can select a bitmap file or procedural map to make an object partially transparent. Lighter (higher-value) areas of the map render as opaque; darker areas render as transparent; and values in between are semi-transparent.
Setting the opacity map's Amount to 100 applies all of the map. Transparent areas are fully transparent. Setting the Amount to 0 is the equivalent of turning the map off. Intermediate Amount values are blended with the Opacity value on the Basic Parameters rollout. Transparent areas of the map become more opaque.
Specular highlights are applied to transparent areas of the opacity map, as well as to opaque areas, creating the effect of glass. If you want the transparent areas to look like holes, map the specular level as well.
Procedure
To map the opacity value:
Click the Map button for Opacity.
The Material/Map Browser is displayed.
Choose from the list of map types, and then click OK.
The Material Editor is now at the map level, and displays controls for the map parameters.
Use the map controls to set up the map.
Revisa los tutoriales de "Texturizado para Tontos" si te queda alguna duda. Los tienes en http://www.3dpoder.com/foro/viewtopi...urizado+tontos
¡Saludos!
__________________
-=: mi blog de desarrollo :=----- last update 19/09/08 DING DING DING!!!
Antiguo 25 ago 2004   #3
josepzin
Habitacus!
Avatar de josepzin
Predeterminado
Hey Iker... no lo trates mal... mira que tratarlo de tonto! ("Texturizado para Tontos")
:D
josepzin is offline   Responder Con Cita
Antiguo 25 ago 2004   #4
javierca
Predeterminado
el caso es que eso ya lo sabia y lo habia visto el problema es que no tengo textura de reja ni mapa de opacidad y eso es lo que no se hacer se que es con photoshop y lo hago con los rpc pero de rejas ni idea
un saludo y gracias por el enlace aunque ya lo tenia en mi ordenador
pd:no me molesta que me llamen tonto ni se me pasa por la cabeza de que lo hayais pensao pero la verdad soy tonto pa algunas cosas jejejeje
nos vemos
Antiguo 25 ago 2004   #5
Crist
que va aqui???......
Predeterminado
Cita:
Escritos por javierca
pero si haces un mapa de opacidad con los rpc como no puedes hacerlo con un mapa para una reja?? ahorasi no tienes el mapa de una reja, pos haslo tiras unas lineas y listo.....
saludos
__________________
Crist is offline   Responder Con Cita
Antiguo 25 ago 2004   #6
ikerCLoN
p a l e t o
Avatar de ikerCLoN
Predeterminado
El mapa de opacidad sólo lo necesitas si vas a hacer mapeando una imagen sobre un plano. Si modelas la reja, no te es necesario usar un mapa de estas características.
Como bien dice la ayuda de Max, necesitarías un plano, la imagen de la reja, y esa imagen de la reja pasada a escala de grises, de modo que lo negro es totalmente transparente, y lo blanco es opaco. Entre medio, puedes poner el resto de valores de gris que quieras, pero para tu caso, lo que es la reja sería de color blanco, y el resto de la imagen sería negro.
¡Saludos!
__________________
Antiguo 15 sep 2004   #7
pris
Predeterminado
Guenas, a ver javierca, para los que no tenemos ni pi. de inglés ni sabemos tirar unas lineas asi y aso, seguramente la "ayuda" no te habrá valido de mucho, si te he entendido no se para qué el mapa de opacidad, tienes una reja y un textura, pues a esa reja le aplicas un modificador mapa UVW, seleccionas gizmo y verás que hay un cubo anaranjado rodeando tu objeto que puedes mover, rotar, escalar para ajustarlo a tu modelo, sea el que sea, y sea cual sea el material que apliques, de opacidad o no.
Espero te sirva y si no insisite que intentaré ayudarte. Estaré pendiente.
Es que algunos no hablan, sólo rebuznan
pris is offline   Responder Con Cita
Antiguo 21 sep 2004   #8
Basie
Señor Miembro
Avatar de Basie
Contactar con Basie a través de MSN
Predeterminado
Pris, no entiendo tu última frase.
Basie is offline   Responder Con Cita
Respuesta
Etiquetas Identificativas
rejas
Herramientas
Normas de Publicación
BB code is habilitado
Las caritas están habilitado
Código [IMG] está deshabilitado
Trackbacks are deshabilitado
Pingbacks are deshabilitado
Refbacks are deshabilitado
Saltar a Foro
google adsense
La franja horaria es GMT. Ahora son las 09:59.
MPAA | Gas Suppliers | Debt Consolidation | Online Advertising | Discount Magazines
