Creating Area Lights - Part 2
Candles, Area lights, and Translucent Materials
In this tutorial we will be expanding on what we have learned in the previous area light tutorial, by creating a realistic candle with a flame and applying an area light to the flame. I will alos touch on Translucent materials. I will not be going into as muchdetail for the basic steps like moving objects and scaling etc as these have already been covered in previous tutorials.
To begin with, download this candle model ( I have created in 3D strata. Import this obj file into a new vue scene. Resize the model to something around 20-50cm's in height, and zoom the camera in on the candle.
Next we will be applying a texture to our candle model. We have a couple of options here. We can apply a simple "flat white" texture (found in the "basics" folder of the Vue materials library) or add the translucent material "orange wax" (found in the "subsurface scattering" folder of the vue material library).
The later option will look more realistic. The candle won't look flat and will absorb the light from the flame but please keep in mind that using translucent materials will significantlyincrease render times. If you have decided to use the "orange wax"material, your probably going to want to change the color from orange to something else.. To do this edit the orange wax material in the material editor and under "Translucancy" change absorption filter color and scattering filter color to a color that you want your candles to appear as. For my final render i used a very light yellow color.
Creating the flame: To begin, create a sphere. Stretch the sphere upwards to create an oval shape. This is your flame object. Resize this object so that it iswithin propotions to your candle i.e. looks like a flame.
Position it so that it is at the top and centered with your candle object. Apply the "Flat White" basic material to the flame object.
Next we need to convert it to an area light ((File menú -> Object --> Convert to Area Light ) and lower its power setting. Candles are not like light blubs or sunshine or even lamps, they emit very little light, so in order to keep our scene looking realistic, its a good idea to keep the power very low. For this tutorial I set my flames light power to a value of 5.
Go into the light editor and enable flare. Reduce the size of your flare to appróximately 15% and turn the "ring" option off.
Still in the light editor turn Volmetric on and increase intensity to a value of 6. Alos increase quality to full and unchek the "cast shadows in volumn" option. This will make your light look smother and will help avoid any graininess caused by volumetric light.
Note: If you are creating múltiple candles in a ne, turn volumetric light on for only one candleand turn it off for the rest. This will help reduce your render time.
When you are working with radiosity scenes its alsoa good idea to create an enclosed environment.
Light sources that are enclosed will bounce their light from all directions / off all surrounding walls, making for a more realistically lit environment. The quickiest way to do this is to first create a cube 60m x 60m x 60m or whatever size you require for you scene. Position the cube so that it is level with the ground plan and so that it encompasses all of your scene objects, including the camera you are working with. When the cube is in the right spot press control-D to duplicate this object. Scale down one of the cubes so that it is smaller on all axis then the other cube. For the above scenario I would enter 59m x 59m x 59m. Boolean Difference the smaller cube from the larger one to hollow out the inside of the cube.
If you are unfamiliar with Boolean operations, chek out my previous tutorial on this subject.
Tip: You can save this object into your Vue library and import it whenever you are working with room's and radiosity.
To finish off the scene we need to adjust our lighting like we did in the previous area light tutorial.
1) Delete the sun from the scene
2) In your atmosphere editor, enable radiosity in the light settings,
3) increase radiosity gain to 1.5 and
4) slide the light balance setting all the way across to 100% (sunlight).
Its alos worth noting, when your render is complete, if you enable "lens glare" in the post processing options, the edges of your candles become softer. You can see the difference in the following 2 examples. You may need to enlarge these pictures to see the detail as the effect is a VERY subtle one.
Note: If you are having trouble seeing the difference, try downloading both enlarged pictures to your computer and flicking instantly from one picture to the other. The difference will appear much more obvious.
Candles without post processing "Lens glare" enabled.
Candles with post processing "Lens glare" enabled.
Add as many candles to your scene as you like, but keep in mind that for each candle you add, you are adding an extra light source and increasing your render times.
This concludes the area-light tutorial. Thanks for reading!
