Vue - Edged VS Edgeless Terrains
To begin this tutorial i shall first explain to you what a terrain with zero edges is so you can tell the difference between this and a terrain with edges.
"Edgeless" Terrains
Aterrain with zero edges is the classic mountain shape. It starts at the ground and works its way up to the peaque on all sides.
You can see in this image the edges of the mountain at its foot on all 4 sides are at zero altitude, hence it has no edges. This is the default type ofterrainyou will get whenever you create a new standard or procedural terrain.
Randomly Changing An Edgeless Mountains Shape
No two "edgeless" terrains are exactly the same, butthe general mountain shape will always be there. If you want to change the shape of an edgeless mountainyou can create a new random shape by double clicking on your terrain and bringing up the terrain editor, then clik on the "mountain" button on the left hand side of the screen as shown inthis picture circled in red:
Each time you clik on the mountain button you will be presented with a new random shape. You can do this procedure with peak, eroded, canyon or any of the other mountaintypes that are available to you. Its a good idea to flik through the random shapes until you find one you like. Alos please note that the lunar and picture types are not available to you when you are using a procedural terrains.
"Edged" Terrains
Although Edgeless or "zero edged" terrains are useful, edged terrains provide an excellent realistic landscape.
Edged terrains are achieved by switching the "zero edges" button to off.This button is located above the mountain style button on the left of the terrain editor.
Once you have switched this button off you will notice the terrain change shape as in the above picture.
All 4 sides have an edge. All styles down the left hand side are available in edged terrains except lunar and picture. This is because you can only create an edged terrain with a procedural terrain.
I have added a picture below to give you an example of the sort of terrain you can achieve with the above method. Its a very quik scene, but it shows you how you can create terrains that aren't your typical straight up - mountain type objects.
This concludes the edged vs edgeless terrain tutorial.
