Gracias Gracias:  1
Tema: 3DSMax 2015 - Extension1
    Senior Member Avatar de cabfl
    Canary Islands
    New features
    OpenSubdiv Support:
    Efficiently represent subdivisión surfaces using OpenSubdiv libraries, open-sourced by Pixar and incorporating technology from Microsoft Research.
    Visualize your model interactively without the need to render for a better WYSIWYG experience, greater productivity, and more accurate realization of creative intent.
    Get faster in-viewport performance for meshes with high subdivisión levels by taking advantage of both parallel CPU and GPU architectures.
    Reduce the guesswork when animating models and help shorten production times, with efficient smooth surface representation.
    Create complex topology in less time, by taking advantage of efficient crease modeling workflows with CreaseSet modifier and Crease Explorer.
    Easily transfer your models to and from certain other packages that support OpenSubdiv using Autodesk® FBX® asset exchange technology and achieve a consistent appearance.
    Alembic Support:
    View massive datasets in the Nitrous Viewport, and transfer them more easily through your production pipeline with new Alembic support.
    Work with production-proven technology, co-developed by Sony Pictures Imageworks Inc. and Lucasfilm Ltd.
    Move complex data through a pipeline in a manageable form: complex animated and simulated data is distilled into a non-procedural, application-independent set of baked geometric results.
    Get more from your workstation, with highly efficient use of memory and disk space.
    Enjoy faster data transfer and load times, with the ability to export and load only selected geometry.
    Enhanced ShaderFX:
    Get more shading options and better shader interoperability between 3ds Max, Autodesk® Maya® software, and Autodesk® Maya LT TM software.
    Create a wider range of procedural materials with new node patterns—wavelines, voronoi, simplex noise, and brick.
    Create normal maps from 2D grayscale images with a new bump utility node.
    Get faster access to the shaders you need, with a searchable node browser.
    3DSMax 2015 - Extension1-3ds-max-2015-extension1-alembic-support-1920x1080.png
    Última edición por cabfl; 13-08-2014 a las 17:45
  1. 3ds Max cómo instalo Vray 3dsMax 2015
    Por jason en el foro Render, Iluminación y Cámaras
    Último mensaje: 30-07-2015, 22:40
  2. 3ds Max Tengo un problema con el Shader fx de 3DsMax 2015
    Por LUISK1027 en el foro Problemas con Programas
    Último mensaje: 16-02-2015, 05:08
  3. Maya Blendshapes desde Mudbox 2015 a Maya 2015 no funcionan.
    Por Atonb6 en el foro Problemas con Programas
    Último mensaje: 04-09-2014, 08:46
  4. Maya 2015 - Extension1
    Por cabfl en el foro Noticias
    Último mensaje: 13-08-2014, 17:49
  5. 3DsMax 2015 a la vista
    Por Jaca en el foro Noticias
    Respuestas: 36
    Último mensaje: 10-05-2014, 01:21
