Foros 3DPoder.
Bienvenido a Foros 3DPoder..
¿Te ayudo?
Retroceder   Foros 3DPoder. > :: Noticias 3D > Noticias
Diseño Web
google adsense
Respuesta
Herramientas
Antiguo 09 jun 2006   #1
SHAZAM
Administrador
Avatar de SHAZAM
Animationmaster Hash's Animation Master 2006 v13.0 Release (y avances)
Ya está lista la oficial Hash's Animation Master 2006 v13.0 Release
Que ganas de actualizar
Cita:
Escritos por Will Pickering en los foros Hash Inc.
Here are links to the v13.0 Installer.
Windows:
v13.0 Installer (2006 - Yeti CD )
v13.0 Network Installer (Hasp Requires 2006 subscription)
OSX (Univeral Binary): TigerInstall13.zip
-fixes
  • 0003208: [Installation (Intel)] Invalid Library path on installation (gaijin)
  • 0003197: [_ Not Selected _] Last light is now the toon light. Default choreography light order reversed for toon light to look better. (Noel)
  • 0003185: [Rendering] jumsuit on girl in Sci Fi scene renders wrong (Steve)
  • 0003021: [Plugins] Unable to load NewtonPhysics and Symbiont2 plug ins (alantruly)
  • 0003168: [Rendering] simbiont is rendering wrong (Steve)
  • 0003039: [Interface] Tooltips are 'blank' (Steve)
  • 0002996: [Hair] progressive rendering has artifiacts (alweb)
  • 0003073: [Interface] final render panel 'history' section screwed up (Steve)
  • 0003192: [Lip Sync] Exercise 7 (James Hash)
  • 0003195: [_ Not Selected _] fog image now renders correctly in background when alpha buffer is off (Noel)
  • 0003191: [Interface] Drag drop into chor now uses default poses' results for surface collision. (Keekat's tail is posed above ground in next cd) (Noel)
  • 0003156: [Net Render] Multipass render does not work in NetRender (Godfrey)
  • 0003162: [Net Render] NetRender always renders with Alpha Channel on, can't change (ddustin)
  • 0003172: [_Other] No names in community window (James Hash)
  • 0003116: [_Other] SciFI Cityscape on new HASH2006 CD crashes on load (Steve)
  • 0003091: [Rendering] Specular is wrong on Buzz's helmet (Steve)
  • 0003135: [Materials] Combiner material does not work on the mac (Steve)
  • 0003157: [Net Render] Feature request: show each client's frames rendered/average time in Render Server (Godfrey)
  • 0003151: [Realtime] Exception #33 after opening a project (Fred)
The hair shaders mentioned in this thread are included in in this release.
Examples prj's to play with: hair.prj and hair_oirg.prj (r-click and select save-as)
__________________
Victor Navone
SHAZAM is offline   Responder Con Cita
Enlaces patrocinados
Antiguo 23 jun 2006   #2
SHAZAM
Administrador
Avatar de SHAZAM
Predeterminado Re: Hash's Animation Master 2006 v13.0 Release (y avances)
Primera actualización: A:M v13.0a
Cita:
Here are links to the v13.0a Installer.
Windows:
v13.0 Installer (2006 - Yeti CD ) (11m)
v13.0 Network Installer (Hasp Requires 2006 subscription) (15mb)
Reference.exe F1 Help File Installer (51mb)
OSX (Univeral Binary): TigerInstall13.zip (23m)
-fixes
  • 0003252: [Hair] Wild hair in NR (dylanperry)
  • 0003242: [Hair] Hair problems (rkaneko)
  • 0003198: [Rendering] Render hangs (PianoMan)
  • 0003269: [Materials] Plug-ins Missing Text Strings for sub properties of Color and Vector2 (scale) (tarmer1)
  • 0003244: [Interface] Values text in properties panel is white (jandals)
  • 0003177: [Hair] TWO: Hair-position variation does not vary position (jandals)
  • 0003250: [Composite] chors don't save with 'FrameBurn' (Noel)
  • 0003243: [_ Not Selected _] Changing model color over time (heath)
  • 0003245: [Plugins] Projects for TWO saved with 'simcloth' lock up when re-opening. (MMZ_TimeLord)
  • 0003196: [Rendering] m_usefrontrealtimelight not exposed or inited (Noel)
  • 0003083: [SDK] call for checking the state of "Object Render Mode" for a model in the chor (sgross)
  • 0003220: [Animation] TWO: When FACE nulls reach limits keyframes are still effected. (KenH)
  • 0003047: [Rendering] error loading string 5886 (Jack West)
  • 0003227: [Materials] Extended Gridturbulance combiner causes error when the material's root is deleted (splinesmith)
  • 0001312: [Animation] Force Keyframe button adds keys for bones not in current choreography action (jandals)
  • 0003234: [Relationships/Poses] Force Keyframe does not create keys in a Pose. (bobcroucher)
  • 0002564: [_Other] Compensate Mode + Force Keyframe not resetting bones/nulls (robcat2075)
  • 0002926: [Animation] Null refresh issue when you use Compensate/force keyframe. (KenH)
  • 0003176: [Interface] Displaying Rulers for Exercise 5 (James Hash)
  • 0003229: [Net Render] Crash on Job-Wizard if no IIO plugins loaded (willp)
  • 0003214: [SDK] added SDK AddNullObjectCache (sgross)
  • 0002543: [SDK] Open/Save/DirRequest calls in plugins fixed. wraped with scope {} around AFX_MANAGE_STATE(AfxGetAppModuleState()); then call; (sgross)
  • 0003209: [Rendering] Can't render to file when camera has plugin shader, and tools options rendering is using settings form the camera (fmsonic)
Salu2 actualiza2
__________________
Victor Navone
Antiguo 01 jul 2006   #3
SHAZAM
Administrador
Avatar de SHAZAM
Animationmaster Re: Hash's Animation Master 2006 v13.0 Release (y avances)
Llega la B
Cita:
Escritos por [b
Will Pickering en los foros Hash Inc.[/b]]Here are links to the v13.0b Installer.
Windows:OSX (Univeral Binary): -fixes
  • 0003297: [Interface] Customize Interface color doesn't work as expected (Tartiflette)
  • 0002165: [Animation] Can now export camera's chor action, and use on another camera (gschumsky)
  • 0003013: [Interface] Universal- ghosted (inactive) icon bitmaps do not show on toolbars (Steve)
  • 0003311: [Materials] Altering decal images in Photoshop crashes A:M when it regains focus (Paul Forwood)
  • 0003284: [_Other] Mac saves full file path beginning with drive name (jandals)
  • 0003296: [Interface] The SimCloth and Newton Setting for the Choreography are missing (splinesmith)
  • 0003133: [Animation] Visibility animation track does not change over time (Obsidian Games)
¿Qué pocos fixes,no? Buena señal
¿Sabíais que el plugin de exportación a Flash de Zpider viene ahora integrado de paquete?
Pues yo me acabo de enterar...
salu2 actualiza2
__________________
Victor Navone
Antiguo 02 jul 2006   #4
Véctor
Eso se arregla en pospo..
Avatar de Véctor
Contactar con Véctor a través de MSN
Cita:
Oleee
Véctor
Antiguo 12 jul 2006   #5
SHAZAM
Administrador
Avatar de SHAZAM
A:M v13.0c
Cita:
Escritos por Will Pickering en los foros Has Inc.
Here are links to the v13.0c Installer.
  • 0002925: [Composite] lightbuffers 4 pass makes a black .exr (eric2575)
  • 0003381: [Plugins] SelectAndDataPropertySample (Noel)
  • 0003338: [Interface] Editing Fields in Manipulator Properties panel often leads to crashing (Stuart Rogers)
  • 0003370: [Materials] Crash when entering values in the advanced manipulator (barney)
  • 0003371: [Timeline/Channel] Zero undo levels causes A:M to crash to desktop (MMZ_TimeLord)
  • 0003383: [_ Not Selected _] v12 pws filters with types, don't load and cause window placements to be skipped on load. (Noel)
  • 0002903: [SDK] Some issues with HFilenameProperty (sgross)
  • 0003356: [Net Render] Exr light buffers not working (Jack West)
  • 0002892: [Realtime] Model shortcuts in bound draw mode would cause an exception when a choreography loaded in muscle modeling or distort mode. (Steve)
  • 0003275: [Realtime] Grooming in a choreography would crash if you didn't have a model shortcut selected. (ddustin)
  • 0002277: [Composite] net render no light buffers for composit (Jack West)
  • 0000792: [Net Render] The scene that applies PostEffects(PostPlugin) is not correct in NetRender. (fb_o)
  • 0003368: [Composite] When a post effect is the focus of the composite view its changes are updated correctly now. (Noel)
  • 0003367: [Rendering] Scaling a sun light in Chor increases light intensity dramatically (yves)
  • 0003291: [Hair] Exception #035 Load hair model (jenpy)
  • 0003290: [Hair] The hair collision does not work (jenpy)
  • 0003345: [_Other] Constant Drivers </TYPEINFO> loaded incorrectly (jenpy)
  • 0003343: [Net Render] re ordering jobs in render server (dylanperry)
  • 0003203: [_Other] Some expressions caused close, revert or open project to fail (ddustin)
__________________
Victor Navone
Antiguo 13 jul 2006   #6
Leander
Tresmiltornillero
Avatar de Leander
Juas, ese error me salía al cargar a "harold", un actor de la biblioteca.
un abrazooooooooooooo... updating.....
Leander is offline   Responder Con Cita
Antiguo 20 jul 2006   #7
SHAZAM
Administrador
Avatar de SHAZAM
v13.0d
Cita:
Escritos por Will Pickering en los foros hash Inc.
Here are links to the v13.0d Installer.
  • 0003437: [_ Not Selected _] Hooks shouldn't save position or bias information, causes SVN conflicts. (TWO) (bobcroucher)
  • 0003436: [_ Not Selected _] Locate files dialog should remember relative paths for locating future files. (bobcroucher)
  • 0003423: [Hair] Hair Shaders are changing the rendering on non-hair objects (cosmonaut)
  • 0003393: [Plugins] consolidate works with any Filename Property, for dark trees etc. (Noel)
  • 0003342: [_Other] cannot load choreog into choreog without crashing (dylanperry)
  • 0003424: [Net Render] Ability to launch VNC or other remote view software from node in Renderserver (willp)
  • 0003233: [Animation] TWO: Changing blend mode of action in chor messes up blending. (KenH)
  • 0003403: [Modeling] Finding patches in wireframe mode when modeling (Noel)
__________________
Victor Navone
Antiguo 23 jul 2006   #8
SHAZAM
Administrador
Avatar de SHAZAM
Como somos poquitos a:meros dejo esta noticia aquí, para no abrir hilos solitarios.
Los de Enhance:A:M Textures están de rebajas y me pareció oportuno anunciarlo, por si a alguien le interesa; hay materiales muy chulos
http://www.shaders.co.uk/enhance:am/
Salu2 texturiza2
__________________
Victor Navone
Antiguo 23 jul 2006   #9
Leander
Tresmiltornillero
Avatar de Leander
Me gusta ser de los poquitos que del montón. Es mas friki.
gracias por la noticia.
Antiguo 28 jul 2006   #10
SHAZAM
Administrador
Avatar de SHAZAM
En Hash no paran...
La 13:0e
Cita:
Here are links to the v13.0e Installer.
  • 0003448: [Relationships/Poses] Bone relationships created in version ‘c’ do not work in version ‘d’ (rwilliamson)
  • 0003458: [Animation] CP weighting problem when cp controlled by the same bone more than once. (kattkieru)
  • 0003372: [Rendering] AM crashes when rendering with animated surfaces. (rkaneko)
  • 0003441: [Decaling] Continued problem of crashing when rendering to file --- movie or image sequence only (mike b.)
  • 0003450: [Modeling] #001 crash after making a hook (KenH)
  • 0003454: [Materials] annoying visual glitch with models that have Emmitter Materials (raillard)
  • 0003411: [Decaling] #001 unhandled exception crash in pose windows. (KenH)
  • 0003414: [Relationships/Poses] Unhandled Exception #001 with specific model/action (Emilio Le Roux)
  • 0003390: [Constraints] Compensate mode does not work on a pair of crucial bones (raillard)
  • 0003387: [Materials] Normal tweaking material nodes had no effect when material.bump percent was set (Jack West)
  • 0003351: [Plugins] Properties are not correct saved (sgross)
__________________
Victor Navone
Antiguo 11 ago 2006   #11
SHAZAM
Administrador
Avatar de SHAZAM
Y llega la F
Hash A:M v13.0f
Cita:
Here are links to the v13.0f Installer.
  • 0003495: [Modeling] Crash while trying to load older model (v8.5 with smartskin)(Wizaerd)
  • 0003472: [Interface] Environment Map material not showing option labels in interface (jpappas)
  • 0003282: [Rendering] Rendering SubPostEffect crash A:M (jenpy)
  • 0003463: [_Other] avoids potentional undo problems (kattkieru)
Por cierto, la v14 ya está en obras
Cita:
Escritos por Rodney, en los foros Hash Inc.
The code split from v13 at (or immediately after) Hash Bash. So... yes, v14 is under construction.
Salu2 actualiza2
__________________
Victor Navone
Antiguo 16 ago 2006   #12
Leander
Tresmiltornillero
Avatar de Leander
Cita:
Escritos por SHAZAM
Comooooooooooooooorrrrrrrr??????????????????
¿tienes idea de los features que va a tener?
Antiguo 16 ago 2006   #13
SHAZAM
Administrador
Avatar de SHAZAM
Cita:
Escritos por Leander
Pues no, realmente no se me ocurre otra que mejorar lo que ya hay, como la velocidad del render con hdri, o presets para las telas y partículas. La verdad es que no nos podemos quejar, tenemos un programa muy completo
Yo pediría incluir Silo dentro de A:M y fusionar ambas interfaces
__________________
Victor Navone
Antiguo 24 ago 2006   #14
SHAZAM
Administrador
Avatar de SHAZAM
v13.0g
Cita:
Here are links to the v13.0g Installer.
  • 0003548: [Lip Sync] Incorrect dictionary proccesson on some words (willp)
  • 0001847: [Modeling] Using muscle mode and exporting the chor model doesn't export muscle motion right. (KenH)
  • 0003190: [Relationships/Poses] Not all relationships will consider in the export (ftude)
  • 0001841: [_Other] Exporting a choreography as a model has exceptions visible only to developers and possibly Mac users (Noel)
  • 0003026: [Lip Sync] Dope sheet don't work with all words (ftude)
  • 0003316: [SDK] Bad texture mapping in new Hook and 5-point-patches exporting (Emilio Le Roux)
  • 0003488: [Decaling] Exported decals not staying on assigned patches (dborruso)
  • 0003395: [Decaling] SIGGRAPH DEMO - Decal Does not display properly when exporting with 5 point patch (dborruso)
  • 0003470: [Particle Systems] Blobbies dont render as expected (MagnusC)
  • 0003481: [Bones/Rigging] Steve hand gizmo rehresh problem (PF_Mark)
  • 0003445: [Interface] Timeline Thumbtack Causes Crash (Stuart Rogers)
Aun no se sabe nada de la v14, y de esta en curso se siguen corrigiendo cosillas para convertirla en la más estable de la historia.
Será que en Hash les gusta la cábala
__________________
Victor Navone
