Tema: Material retouch using material node with vertex color
    Material Retouch using Material Node with Vertex Color.
    Material Retouch is control a shaded área by Material Node with Vertex Color. If you didn't get desired results in a tiny shaded área of a model, do you remake a model? But, remaking it takes time. In other way, Post Effects as typified by Composite Node give a 2D efect, thus, partially incorrect 3D. You can control shading of model as like 3D painting by Material Retouch in short time.
    First, paint Vertex Color a shading control área in red and blue at Vertex Paint mode. Paint a bright área in red, paint a shadow área in blue and, paint a inefective shading control área in black.
    Figure.1: Vertex Color painting example.
    Figure.2: "Material Retouch" Material Node.
    Note: Method of extraction of Red or Blue from Vertex Color using RGBCurve. Extraction of red is zero in all value of gren and blue at RGBCurve. Finally, rendering your scene and adjust Vertex color painting and Material Node structure for desired images.
    Figure.3: Left:normal shading Suzzane. Right:"Concave Retouch" shading Suzzane.
    It's from colors, because Blender 2.45 not supported shader influence controls. Notice, Material Retouch is effect to materials only. Thus, inefective to Tracing and Buffer Shadows.
    References:
    Locally Controllable Stylized Shading (English)
    http://www.olm, co.jp/en/rd/2007/07/...007_paper.html
    Locally Controllable Stylized Shading (Japanese)
    http://www.olm, co.jp/b/rd/2007/07/_...d_shading.html
    Test of Ton shading retouch on 3D (Japanese,XSI)
    http://artifacts, sakura, ne.jp/sakanaya/2007/10/3d.htm
    Credit:
    Nanmo(Japan)
    http://bleble, tumblr.com/
    Miniaturas adjuntadas Miniaturas adjuntadas Material retouch using material node with vertex color-material-retouch2.jpg   Material retouch using material node with vertex color-material-retouch3.jpg   Material retouch using material node with vertex color-material-retouch.jpg
    Si vas a subir un trabajo al foro, hazlo adjuntando la imagen, archivo, vídeo o lo que sea, no publicando enlaces de otros sitios. https://www.foro3d.com/f45/forma-correcta-de-insertar-imagenes-y-archivos-en-nuestro-mensaje-98930.html
  1. Maya Bloque vertex 2016 y color negro de material
    Por lcerraj en el foro Modelado
    : 25-10-2015, 14:04
  2. Retocar material usando nodos de material con vertices de color
    Por venomgfx en el foro Blender Art Magazine nº 14
    : 31-03-2014, 19:43
  3. Blender Material retouching using material node with vertex color
    Por 3dpoder en el foro Blender Art Magazine nº14 (in English)
    : 26-06-2009, 03:42
  4. Blender Project peach material node cook book
    Por 3dpoder en el foro Blender Art Magazine nº13 (in English)
    : 17-06-2009, 10:58
  5. Ver material color
    Por cebula en el foro Programación y Scripts
    : 16-02-2007, 23:25
