Tema: Shortcuts para 3dsmax
    no sabia bien donde colocar este tema, si no es aquí que un administrador lo mueva...espero que les sirva....saludos
    FUNCIONES DE TECLADO DE 3D STUDIO MAX 5®
    Bueno, son para 3D MAX 5®, algunas funciones trabajan para 3D MAX 6®,
    COMANDO=TECLADO
    Help = F1
    Shade Selected Faces = F2
    Wireframe/ Smooth + Highlights= F3
    View Edged Faces = F4
    Restrict to X = F5
    Restrict to Y = F6
    Restrict to Z = F7
    Restrict place cycle= F8
    Render last= F9
    [B]Render scene= F10
    Maxscript listener= F11
    Transform type-in dialog= F12
    Redraw all views= ` (~)
    Sub-object level 1= 1
    Sub-object level 2= 2
    Sub-object level 3= 3
    Sub-object level 4= 4
    Spot/directional light view= shift+4
    Sub-object level 5= 5
    Show main toolbar= alt-6
    Polygon counter= 7
    Environment dialog= 8
    Render to texture= 0
    Lok user interface= alt+0
    Transform gizmo size down= menos -
    Transform gizmo size up= más +
    Top view= te
    Show tab panel= y
    redo viewport operation = shift+y
    redo scene operation= ctrl+y
    isometric user view= u
    pan viewport= i
    spacing tool= shift+i
    select invert= ctrl+i
    adaptive degradation= o
    open file= ctrl+o
    perspective user view= p
    hide particle systems= shift+p
    pan view= ctrl+p
    cap (poly)= alt+p
    zoom viewport in= [
    zoom viewport out= ]
    sound= \
    set key mode= '
    angle snap= a
    select all= ctrl+a
    align= alt+a
    snap= s
    hide shapes= ctrl+s
    save file= ctrl+s
    snap cycle= alt+s
    zoom extents selected all= z
    undo viewport operation= shift+z
    undo scene operation= ctrl+z
    zoom mode= alt+z
    transform gizmo= x
    expert mode= ctrl+x
    see-through display= alt+x
    disable viewport= de
    select none= ctrl+d
    front view= f
    show safeframes= shift+f
    cycle selection method= ctrl+f
    camera view= c
    hide cameras= shift+c
    match camera to view= ctrl+c
    cut (poly)= alt+c
    clone ctrl+v=
    hide grinds= g
    hide geometry= shift+g
    select-by-name dialog= h
    hide helpers= shift+h
    place highlights= ctrl+h
    bottom view= b
    sub-object selection= ctrl+b
    viewport background= alt+b
    autokey mode= n
    new scene= ctrl+n
    normal align= alt+n
    show selection bracket= j
    set keys= que
    material editor= m
    meshsmooth (poly)= ctrl+m
    left view= L
    hide lights= shift+L
    default lighting= ctrl+L
    backup time one unit=, (coma)
    forward time one unit= . (punto)
    play animation= /
    selection lock= spacebar
    go to start frame= home
    sub-object level cycle= replace
    select ancestor= page up
    select child= page down
    go to end frame= end
    virtual viewport= numpad /
    virtual viewport zoom in= numpda +
    virtual viewport zoon out= numpad -
    virtual viewport pan up= 7 8 9
    virtual viewport pan left= numpad 4
    virtual viewport pan right= numpad 6
    virtual viewport pan down= numpad 2
    saludos
    pd:por ahí lo pueden imprimir y pegar frente a su pc...
    Última edición por carlosall; 13-06-2005 a las 14:59
    Wiki Member Avatar de tonneti
    May 2004
    Donostis
    Re: Shortcuts para 3DS MAX .!!!
    muy practico este post, me viene de genial
    un saludo
    gracias tío muy practico.
    Senior Member Avatar de Mario
    Madrid
    Supongo que a nadie le ha picado la curiosidad que cuando se arranca el MAX salen unos ejemplitos de las teclas.
    En la carpeta raíz hay un archivo que se llama "splash.swf" donde esta todo eso y mas.
    Apr 2008
    Muchas gracias, me ha servido de verdad.
    Es cosa de ser un poco más intruso y descubrirlo todo del max.
    jijiijiji. Gracias
  1. Respuestas: 3
    Último mensaje: 23-09-2014, 14:04
  2. Que marca para un portatil para 3dsmax mas VRaY
    Por cesarob en el foro Hardware
    Último mensaje: 22-10-2011, 21:05
  3. Maya Problema con Maya shortcuts
    Por kesioo en el foro Problemas con Programas
    Último mensaje: 26-03-2011, 17:49
  4. jpeg con los shortcuts en el teclado
    Por rushdie en el foro 3DStudio Max
    Último mensaje: 08-12-2006, 14:50
  5. Shortcuts a scripts en max consulta
    Por dfx3 en el foro Plugins
    Último mensaje: 14-03-2006, 18:42
