Gracias Gracias:  1
Tema: Error al iniciar OGRE 3D
    May 2009
    Angry Error al iniciar OGRE 3D
    HOLA SOY NUEVA EN EL FORO. QUIERO EMPEZAR A TRABAJAR CON EL MOTOR OGRE 3D Y TENGO VARIOS PROBLEMAS. YA INSTALE TODO COMO DICE LA GUIA DE INSTALACION Y AL INTENTAR EJECUTAR LA aplicación ME SALEN ERRORES:
    -------------- Build: Debug in prueba ---------------
    cl : Command line warning D9002 : ignoring unknown option '-mthreads'
    main.cpp
    cl : Command line warning D9002 : ignoring unknown option '-fmessage-length=0'
    cl : Command line warning D9002 : ignoring unknown option '-fexceptions'
    cl : Command line warning D9002 : ignoring unknown option '-fident'
    Linking console executable: C:\OgreSDK\bin\Debug\prueba.exe
    LINK : warning LNK4044: unrecognized option '/Wl,--enable-runtime-pseudo-reloc'; ignored
    LINK : warning LNK4044: unrecognized option '/Wl,--enable-auto-image-base'; ignored
    LINK : warning LNK4044: unrecognized option '/Wl,--add-stdcall-alias'; ignored
    LINK : warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs; use /NODEFAULTLIB:library
    main.obj : error LNK2019: unresolved external symbol __imp__MessageBoxA@16 referenced in function __catch$_WinMain@16$0
    main.obj : error LNK2019: unresolved external symbol __CrtDbgReportW referenced in function "public: char const & __thiscall std::_String_const_iterator<char,struct std::char_traits<char>,class std::allocator<char> >::operator*(void)const " (?D?$_String_const_iterator@DU?$char_traits@D@std@ @V?$allocator@D@2@@std@@QBEABDXZ)
    libcpmtd.lib(stdthrow.obj) : error LNK2001: unresolved external symbol __CrtDbgReportW
    libcpmtd.lib(xmbtowc.obj) : error LNK2001: unresolved external symbol __CrtDbgReportW
    libcpmtd.lib(xdebug.obj) : error LNK2019: unresolved external symbol __malloc_dbg referenced in function "void * __cdecl operator new(unsigned int,struct std::_DebugHeapTag_t const &,char *,int)" (?2@YAPAXIABU_DebugHeapTag_t@std@@PADH@Z)
    libcpmtd.lib(xmbtowc.obj) : error LNK2001: unresolved external symbol __malloc_dbg
    libcpmtd.lib(xdebug.obj) : error LNK2019: unresolved external symbol __free_dbg referenced in function "void __cdecl operator delete(void *,struct std::_DebugHeapTag_t const &,char *,int)" (?3@YAXPAXABU_DebugHeapTag_t@std@@PADH@Z)
    libcpmtd.lib(xmbtowc.obj) : error LNK2001: unresolved external symbol __free_dbg
    libcpmtd.lib(_tolower.obj) : error LNK2019: unresolved external symbol __calloc_dbg referenced in function __Getctype
    C:\OgreSDK\bin\Debug\prueba.exe : fatal error LNK1120: 5 unresolved externals
    Process terminated with status 1120 (0 minutes, 33 seconds)
    10 errors, 4 warnings
    QUE DEBO HACER?
    ESTOY USANDO VISUAL C++ 2005.-
    Nov 2006
    Respuesta: Error al iniciar OGRE 3D
    Estoy recien arrancando con Ogre y no sabría decirte sobre tu problema y menos en visual. Yo estoy usando CodeBlok con el compilador de MinGW y me funciona bien a lo menos los tutoriales de la wiki.
    En Ogreros.net tienes como configurar Codeblok para ogre y algunas de las tutoriales traducidas al español.
    Si en algo puedo ayudar me avisas.
    PD: estoy con problemas con el tutorial 6 con el CEGUI que me da errores..
    Senior Member Avatar de eduardo777
    Jun 2007
    Santa Rosa de Copán, Honduras
    Bajate e instala ogresdkwizard para projectos, y si compilas el ejemplo, te funcionara todo lo que hagas.
    Nov 2006
    Thumbs up Respuesta: Error al iniciar OGRE 3D
    Muchas gracias Eduardo777 se complico un poco para configurar el wizard con vc++ pero al final pude hacer correr el ejemplo que trae como también los tutoriales que no podía con codeblock.
    Creo que me paso al Visual C++ 2008 Express Edition si no me queda otra eleccion.
    Feb 2009
    Ahora Ogre solo puede ser trabajado con Visual Studio, hace rato no liberan versiones para CodeBlocks, una lástima porque mis proyectos eran de este último.
  1. Error al iniciar 3ds max 2011
    Por jsdali en el foro Problemas con Programas
    Último mensaje: 29-08-2012, 02:34
  2. 3ds Max Error al iniciar Massive
    Por rober2393 en el foro Problemas con Programas
    Último mensaje: 07-04-2012, 18:08
  3. Maya Error al exportar de Maya para Ogre
    Por Rembrandt_yyp en el foro Problemas con Programas
    Último mensaje: 07-04-2011, 21:32
  4. Error al iniciar 3DS 2009
    Por Ronso Palillo en el foro Problemas con Programas
    Último mensaje: 24-07-2010, 16:52
  5. After Effects Error al iniciar after Effects 7 0
    Por Rooo3DS Max en el foro Problemas con Programas
    Último mensaje: 13-06-2009, 01:55
