Tema: Blender script: Exportador de camara a after Effects y Shake
    Blender script: Exportador de cámara a after Effects y Shake
    Este script, en python, permite exportar los datos de cámara de una escena hecha en Blender a After Effects y Shake; para quienes como yo trabajamos con ambos programas es un puntazo poder integrarlos de esta manera
    Descarga en esta página:
    Blender Artists Forums - View Single Post - Maya Ascii camera export script
    Tutorial (en inglés)
    Cita Iniciado por osxrules en blenderartist.org
    Quik AE tutorial:
    What I did was set Blender to 1024 x 576 aspect 100 x 100. Then used the script to save a .ma file.
    In AE, file menú > import > file and choose the .ma file
    This loads a folder of tracking points called Solids and now a single composition element with the name of the .ma file.
    Double-clik the composition element and it should load all the tracking points into the scene. You can use the manipulation controls in the top left - orbit camera tool etc (hotkey is c) - to move the 3D view.
    Use the view menú > look at all layers if you get lost with some crazy camera movement. I wish the compositors had turntable view like Blender.
    Now you can add other layers so maybe load in an image then drag it down to the composition.
    Right-clik the added image and make it a 3D layer.
    Reset the position to 0 0 0.
    If the Blender camera was looking at 0,0,0 you should see the image in view.
    I had to scale the image down to about 0.5%.
    The image should stay where it is while the camera moves around it.
    To attach a composite object to a tracking point, you can simply parent it to one of the tracking shapes, then just reset the composite object position again if you want it to be in the same place.
    Descarga directa:
    http://www.geocities.com/ajr650/tracking_ae.zip
    http://www.geocities.com/ajr650/tracking_shake.zip
    Actualizado: He subido los scripts por si se rompen los enlaces, al parecer geocities esta en extinción.
    Última edición por SHAZAM; 26-09-2009 a las 01:08
    Victor Navone
    Chuck Jones
    John Lasseter
  1. Blender exportador de blender para google o3d
    Por kellogs en el foro Noticias
    Último mensaje: 29-07-2009, 10:55
  2. Funciona el exportador de Voodoo a Blender
    Por Klópes en el foro Problemas con Programas
    Respuestas: 17
    Último mensaje: 04-06-2008, 06:56
  3. Respuestas: 10
    Último mensaje: 08-11-2007, 16:11
  4. Exportador de curvas Blender a Max
    Por SHAZAM en el foro Programación y Scripts
    Último mensaje: 05-05-2007, 17:51
  5. Respuestas: 1
    Último mensaje: 21-09-2005, 14:06
