Tema: Default SmoothGroupImport - un plugin para ZBrush 3 1
    Feb 2007
    Default SmoothGroupImport - un plugin para ZBrush 3.1
    hace un rato me he encontrado con esto:
    ZBrushCentral - SmoothGroupImport - a plugin for ZBrush 3.1 (3DsMax...)
    lo cual me llena de orgullo y satisfacción debido a la solución al problema de exportar a Zbrush sin que la malla se encogiese y sin tener que meterle más polígonos de los que tenía.
    Saludos...
    This plugin is designed for those who like to work with smoothing groups in Max or an app that supports them. It will import an OBJ into ZBrush and automatically crease the borders of any smoothing groups. If there are regular groups these are unaffected.
    INSTRUCTIONS
    Press the button and select an OBJ file from disk. You will have the option of importing into a mesh in Edit mode if you wish. The file will be imported and if there are smoothing groups defined the borders of each group will be creased.
    To uncrease the smoothing groups after subdividing to the required level, SHIFT+clik the Tool:Geometry:UnCrease button.
    INSTALLATION
    The zip contains:
    SmoothGroupImport.zsc - the plugin file
    SmoothGroupImportData - a folder which contains:
    ZFileUtils.dll - the dll file
    SmoothGroupImport_readme.txt - the readme file
    Unzip the zip file to your ZBrush3\ZStartup\ZPlugs folder so that the structure is like this:
    ZBrush3
    |--ZStartup
    |--ZPlugs
    ... SmoothGroupImport.zsc
    |--SmoothGroupImportData
    ... ZFileUtils.dll
    Restart ZBrush. You should now have an Import & Crease button in the Tool palette (below the Import button).
    I worked on this plugin while Anne-Lise was developing the ZFileUtils DLL, and the plugin makes use of several of the functions that the DLL provides. The ZFileUtils is available for all zscripters to use. For information relating to this plugin see here and for ZFileUtils see here .
    I hope you find the plugin useful.
    Última edición por 3dpoder; 16-11-2008 a las 23:01
    Aug 2007
    Madriz
    Re: Default SmoothGroupImport - un plugin para ZBrush 3.1
    Pos pinta muy interesante..
    Feb 2007
    lo cierto es que si, yo ya lo he probado y te guarda perfectamente los smoothig groups...
    Aug 2007
    Madriz
    Pos lo probare apenas tenga una oportunidad. Gracias por el Link..
  1. ZBrush ZStartup plugin para Zbrush
    Por 3dpoder en el foro Plugins
    Último mensaje: 07-07-2015, 17:33
  2. Plugin gratuito para hacer árboles con zbrush
    Por Gabriel Herrera en el foro Noticias
    Último mensaje: 30-08-2014, 03:45
  3. Plugin Zbrush Pelo para 3DSmax
    Por 3dpoder en el foro Programas de Diseño gráfico
    Último mensaje: 30-01-2012, 15:54
  4. ZBrush goZbrush, nuevo plugin para ZBrush
    Por exavi en el foro Noticias
    Respuestas: 12
    Último mensaje: 15-05-2010, 20:20
  5. Respuestas: 2
    Último mensaje: 09-01-2007, 18:37
