Hola el caso es que me baje la versión de prueba del plugin de la película de matrix y x-men Stroika 4.0 de la página del autor que además tiene tutoriales en youtube pero no se como instalar el plugin es para maya y se descarga el plugin y un archivo a parte que es la licencia.
(imagen de la carpeta que se descarga)
el plugin se puede descagar de aquí yo tengo maya 2014)
http://www.kolektiv.com/products.php..._VIEW=Software
el archivo stroika pdf son las isntrucciones para instalarlo pero no se entienden miren :
Installation
Nodelocked Licensing
Node Locked License
A node locked license refers to a license that is keyed to only run on a specific machine.
If you purchased a node locked license, the license file should look like this :
FEATURE stroika kolektiv 3.0 permanent uncounted 870A715B2107 \
HOSTID=00a0cc5a75b6
The HOSTID number is the unique identifier of the ethernet card in your machine as returned by the command :
Windows NT/2k/XP
C:\>ipconfig /all
Ethernet adapter Local Área Connection 2:
Physical Address. . . . . . . . . : 00-C0-F0-78-D8-81
*The hyphens in the physical address must be removed
© 2005 Kolektiv Development Inc.
Stroika 3.0
Linux / OS X
/usr/aw/COM/bin/lmutil lmhostid
lmutil - Copyright (C) 1989-1999 Globetrotter Software
The FLEXlm host ID of this machine is "00c0f078d921"
License Location
The license file that you receive can be renamed to anything you like as long as it has “.lic” as the extension. The location of the license depends on your operating system.
Windows NT/2k/XP
The license file that you received from the kolektiv must be placed in C:\flexlm on a Windows systems. If this directory does not exist, create it and put the license file inside.
Linux / OSX
The license file that you received from the kolektiv should be placed in /var/flexlm on Linux and OSX systems. If this directory does not exist, create it and put the license file inside.
Floating Licensing
Floating licenses allow a server to issue licenses to clients. Any machine can be a license server, but the license file must be encrypted for that specific server. Any client can request licenses from a server, regardless of what operating system they are using.
Client Side License Files
When using a floating license server, each client must have a license file that points to the server and ends with a “.lic” extension. The license file should look like this :
SERVER 192.168.0.102 0 27000
USER_SERVER
The ip address or name of the server can be specified and the port number must be specified as well. In the above example, the server's ip address is used and the server is listening to port 27000. 3
Stroika 3.0
License Location
Client License Location
The client license file that you create can be renamed to anything you like as long as it has “.lic” as the extension. The location of the license depends on your operating system.
Server License Location
The server license file that you create must be named “kolektiv_server.lic” for the startup scripts to work. The location of the license depends on your operating system.
Windows NT/2k/XP
Linux / OSX
Floating License Server Windows XP
To set options and start the license server
1. Select Start > Programs > Alias > Common Utilities > FlexLM License Utilities.
2. In the LMTOOLS window, clik the Service/License File tab and select the Configuration using Services option.
3. Clik the Configure Services tab.
4. Change the Service Name to FLEXlm Kolektiv
5. Turn on Use Services.
6. Turn on Start Server at Power Up.
7. Chek that the values shown are correct:
a. Path to the lmgrd.exe file is C:\Program Files\CommonFiles\AliasWavefrontShared\Licensing\e tc\lmgrd.exe
b. Path to the license file is: C:\FLEXLM\kolektiv_server.lic, where servername is the 4
Stroika 3.0
name of the license server machine.
8. Copy the kolektiv vendor daemon,
stroika\plugins\licenseServer\kolektiv.exe to C:\Program Files\CommonFiles\AliasWavefrontShared\Licensing\e tc\
9. Clik Save Service.
10. Clik the Start/Stop/Reread tab and clik Start Server.
To confirm the license server operation (Windows)
1. Clik the Server Status tab.
2. Clik Perform Status Enquiry.
If the license server is up, the window displays:
<servername>:license server UP(MASTER)
where servername is the license server computer name.
3. Close LMTOOLS.
Floating License Server Linux
To set options and start the license server on Linux
1.Log in as root if you have not done so.
2.Copy the license file into /var/flexlm .
3.Copy the init daeomon stroika/licensing/linux/bin/kolektiv_flexlm into /etc/rc.d/init.d .
4.Copy the kolektiv vendor daemon stroika/licensing/osx/etc/kolektiv into /usr/etc .
5.Stop then start the lmgrd daemon by entering the following commands:
/etc/rc.d/init.d/aw_flexlm stop
/etc/rc.d/init.d/aw_flexlm start
•If the server was on previously, the command issues some status information. An example of this status information is:
lmdown - Copyright (C) 1989-2004 Macrovision Corporation. All rights reserved.
Shut down FLEXlm server on node servername 1 FLEXlm License Server shut down
•If the server is already off, the command issues an error message similar to: 5
Stroika 3.0
lmdown - Copyright (C)2004 Macrovision Corporation. All rights reserved.
Connection to "servername" failed: Cannot connect to license server(-15,12:146) Connection refused
where servername is the name of the server machine. You can ignore this error message.
•If the server starts successfully, the status message should look similar to this:
License file = /var/flexlm/aw_servername.dat
FLEXlm Licensing daemon for Alias software: /usr/etc/lmgrd
4.Log out of root.
Floating License Server OSX
To set options and start the license server on OSX
1.Copy the license file into /var/flexlm .
2.Copy the kolektiv vendor daemon stroika/licensing/osx/etc/kolektiv into /usr/aw/COM/etc .
3.Start the license server by typing the following in Terminal. (You may be prompted for your password.)
sudo stroika/licensing/osx/bin/kolektiv_flexlm start
4.To confirm the server has started, type the following in Terminal:
sudo /usr/aw/COM/bin/lmstat -c /var/flexlm/kolektiv_server.lic
5.If the server has started successfully, you should see output that contains the line License server UP (MASTER) v9.5.
6.Load Stroika to see if the licensing setup has worked.
