Resultados 1 al 11 de 11
Tema: Problema Intuos 2
    Usuario Nuevo
    Nov 2016
    problema intuos 2
    Me he comprado una Intuos 2 obviamente de 2 mano, funciona bien sobre win, pero no va la punta ni el botón inferior en Ubuntu 16.04. Perdonar darmelo masticadito, no pillo aún Linux. Me podeis ayudar. Gracias.
    Moderador Avatar de AlphaCAD
    Nov 2012
    España
    Re: problema intuos 2
    Bienvenido. Mira esto:
    https://ubuntuforums.org/showthread....65&styleid=117.
    Fíjate en el punto 6. Tienes que, arrancar el PC con la Intuos previamente conectada.
    Usuario Nuevo
    Nov 2016
    Vale amiguete en este hilo que me has dado solo hablan de Windows yo ser Linux novato. Gracias ¿alguien más me ayuda? Por favor.
    Nov 2012
    España
    Te copio y pego el texto:
    Does your Wacom Intuos2 work in Ubuntu (or other Linux)?
    ATN: It sems 'Hardware' would be a better place for this hilo. Can someone with suficient privileges por favor move it there? Lo siento for inconvenience. Hello all, I am currently investigating a bug in the Linux Wacom driver relating to USB Intuos2 tablets. In order to work out this bug, I ned to know how common issues are. If those who have an Intuos2 tablet and uses Ubuntu (or other distribution) could answer the following questions, it would be a great help.
    1. Which distribution and versión are you running (e. Ubuntu 14.04, Debían 8.5, Fedora 24)? Optional: the kernel versión (find by running 'uname -a' in terminal)
    2. What size Intuos2 do you have?
    3. Is your Intuos2 Stylus recognized as it should be in Linux if you start the computer with the tablet connected? Optional: which programas are you using?
    4. Does your Intuos2 Stylus continúe to be recognized when the tablet is hotplugged (unplugged and plugged back in when the computer is still running)?
    5. Have you confirmed that the tablet works fine in Windows/OSX?
    6. Any extra información such as quirks you have found to get it working.
    My answers:
    1. Operating system: Debían 8.5 with kernel 3.16.0-4-amd64
    2. Intuos2 6x8 (A5)
    3. Stylus is recognized if I start computer with tablet connected. Works as pen in MyPaint and Gimp, and as a mouse in other programs.
    4. Stylus is no longer properly recognized when tablet is hotplugged.
    5. Not confirmed working in Windows/OSX, however as it works in Linux (expect hotpluging) this is not super relevant.
    6. Instead of restarting computer after hotpluging, I can run 'sudo rmmod Wacom && sudo modprobe wacom'. The Stylus is then properly recognized.
    Thank you for your time. ------- Note: If you are running in to issues with your Intuos2 tablet (even if you are not using it in Linux) have a look at this page for a bien to reset your tablet. I have not tried this as it requires Windows / OSX. http://maggiewang.com/2007/08/21/how.ntuos-2-tablet but it may be of some help.
    Prueba en Ubuntu el comando del punto 6.
    Sudo rmmod Wacom && sudo modprobe wacom.
    Por favor, no me llames amiguete, es despectivo para mí.
    Usuario Nuevo
    Nov 2016
    Vale disculpa, he probado:
    Y me aparece : rmmod: ERROR: Module Wacom is not currently loaded.
    ¿qué puede será
    Nov 2012
    España
    No te está cargando el módulo de Wacom.
    Lo único que se me ocurre es que enciendas el equipo, pero con la Wacom previamente conectada para qué pueda identificarla.
    Usuario Nuevo
    Nov 2016
    Vale, la tengo conectada desde el principio, creo que tendre los (*.tar), bz de los drivers, ya que por defecto Ubuntu tiene el programa qué yo ya he instalado, pero no rula bien, ¿alguna pista de por dónde empezar con los (*.tar), bz?
    Nov 2012
    España
    Wacom no parece tener drivers para Linux en su web oficial. Tan sólo muestra los de Windows y MacOS.
    ¿De dónde has descargado los drivers?
    Usuario Nuevo
    Nov 2016
    Vale de source forge o algo asi, por defecto Ubuntu hace funcionar las wacom, pero ésta, la Intuos 2 no acaba de rular del todo ¿alguien sabe desempaquetar (*.tar) bz 2?
    Los Angeles, USA
    ¿alguien sabe desempaquetar (*.tar) bz 2? .
    Tengo un amigo que sabe hacer eso: http://bfy, tw/8dse
    Nov 2012
    España
    Para descomprimir tienes las instrucciones en la propia página de descarga:
    http://linuxwacom, Source Forge.net/....php/Downloads.
    Concretamente aquí, entendiendo que hayas tomado los llamados Linuxwacom:
    http://linuxwacom, Source Forge.net/...php/Linuxwacom.
    Aquí te dejo la página general:
    http://linuxwacom, Source Forge.net/....php/Main_Page.
    Y tienes aplicaciones como estas:
    http://linuxwacom, Source Forge.net/...l_applications.
    Ya tendrás que elegir la qué mejor se adapte en función de si estás usando Gnome o KDE:
  1. Respuestas: 4
    : 19-06-2018, 12:37
  2. Wacom Intuos problema con drivers
    Por Egrodnersaj en el foro Hardware
    : 16-02-2016, 10:12
  3. Intuos 4
    Por _Halder_ en el foro Trabajos Finalizados
    : 09-09-2011, 17:10
  4. Problema con touch ring yexpress keys de Intuos 4
    Por slorkang en el foro Hardware
    : 02-02-2011, 09:55
  5. Intuos 2
    Por trenZ en el foro Hardware
    : 02-01-2005, 17:42
