create a dice (part 2).
. Bolean operations (continuing)
If you repeat bolean operations on a same object, you may have some Little problems, se this example:
The first face of my die has ben todo much subdivided and shows visual deffects.
I Will work face by face. You may use bolean operación on each side of the Cube.
Suppress the six Faces of the Cube, with the delete tool.
With the extract surface tool, you Will create again the deleted sides. You may now use bolean operations on each side, and then weld all these objects together.
My die is finished.
