Hola a todos, alguien me podría resolver este código:
rollout rollTentacle "Tentacles"
spinner UInBones "Number of Bones:" type:#integer range:[0,99999,5]
spinner UIBonesLength "Bones Length:" type:#float range:[0,9999,30]
button UICreate "Create"
on UICreate pressed do
undo on
punto=point()
punto.transform= matrix3 1
prevNode=punto
attributesIns=attributes TentaclesAttributes
parameters paramsTA rollout:rollTA
FWeightManual type:#float ui:UIWeightManual default:0
FWeightProcedural type:#float ui:UIWeightProcedural default:100
FFrec type:#float ui:uiFrec default:10
FAmplitudeB type:#float ui:UIAmplitudeB default:1
FAmplitudeE type:#float ui:UIAmplitudeE default:2
FPhase type:#float ui:UIPhase
FOffset type:#float ui:UIOffset
rollout rollTA "Tentacle_Parameters"
group "Wave Parameters"
spinner UIFrec "Frecuency:" range:[-9999,9999,0]
spinner UIAmplitudeB "Amplitude B:" range:[-360,360,0]
spinner UIAmplitudeE "Amplitude E:" range:[-360,360,0]
spinner UIPhase "Phase:" range:[-9999,9999,0]
spinner UIOffset "Offset:" range:[-9999,9999,0]
group "General Weights"
slíder UIWeightManual "Manual:" range:[0,100,0]
slíder UIWeightProcedural "Procedural:" range:[0,100,0]
addmodifier punto (EmptyModifier())
punto.modifiers[1].name="WaveControl"
custattributes.add punto.modifiers[1] attributesIns
TAtt=punto.modifiers[1].TentaclesAttributes
TAtt.FWeightManual.controller=bezier_float()
TAtt.FWeightProcedural.controller=bezier_float()
TAtt.FFrec.controller=bezier_float()
TAtt.FAmplitudeB.controller=bezier_float()
TAtt.FAmplitudeE.controller=bezier_float()
TAtt.FPhase.controller=bezier_float()
TAtt.FOffset.controller=bezier_float()
n=UInBones.value
for i=1 to n do
BoneVar=bonesys.createbone [(i-1)*UIBonesLength.value,0,0] [i*UIBonesLength.value,0,0] [0,0,1]
BoneVar.parent=prevNode
BoneVar.rotation.controller=rotation_list()
ScriptVar=euler_xyz()
BoneVar.rotation.controller.available.controller=S criptVar
ScriptVar.z_rotation.controller=float_expression()
ScriptVar=ScriptVar.z_rotation.controller
ScriptVar.addScalartarget "Frec" TAtt.FFrec.controller
ScriptVar.addScalartarget "AB" TAtt.FAmplitudeB.controller
ScriptVar.addScalartarget "AE" TAtt.FAmplitudeE.controller
ScriptVar.addScalartarget "Phase" TAtt.FPhase.controller
ScriptVar.addScalartarget "Offset" TAtt.FOffset.controller
StringVar="degToRad(sin(F*Frec+Phase+Offset*"+(((i-1)/(n-1) as float) as string)+")*(AB*"+((1.0-(i/n as float)) as string)+"+AE*"+(((i/n as float)) as string)+"))"
ScriptVar.SetExpression StringVar
BoneVar.rotation.controller.weight[1].controller=float_expression()
BoneVar.rotation.controller.weight[1].controller.addScalartarget "Weight" TAtt.FWeightManual.controller
BoneVar.rotation.controller.weight[1].controller.setExpression "Weight/100"
BoneVar.rotation.controller.weight[2].controller=float_expression()
BoneVar.rotation.controller.weight[2].controller.addScalartarget "Weight" TAtt.FWeightProcedural.controller
BoneVar.rotation.controller.weight[2].controller.setExpression "Weight/100"
prevNode=BoneVar
createdialog rollTentacle 180 80
Me manda un error en la lista maxscript en el No 41 y el No 42 addmodifier punto (EmptyModifier())
y diga me cual es la solución para que me funcione en la versión 3dsmax2012 y se los agradezco mucho y
espero una respuesta sulla gracias....
