tengo un error con el mental ray solamente al cargar el motor, seleccionar el material, pero al asignarle una texutra en difuse x ejemplo algunos shader no cargan y me sale este mensaje_
API 0.0 error 301099: while defining texture "MI_default_texture_default_normal.dds": failed to open texture file default_normal.dds
IMG 0.0 error 101003: default_normal.dds: can't open file for reading (No such file or directory)
API 0.0 warn 302017: illegal argument "Component_falloff" for function call to "Component_falloff"
API 0.0 warn 302017: illegal argument "Component_reflection" for function call to "Component_reflection"
API 0.0 warn 302017: illegal argument "Conversión_color_to_float" for function call to "Conversión_color_to_float"
API 0.0 warn 302042: while defining material "max_default_mtl_phen|Mtl": material shader "Conversión_color_to_float" in material "max_default_mtl_phen|Mtl" returns a scalar, expected color
API 0.0 warn 302017: illegal argument "Conversión_float_to_color" for function call to "Conversión_float_to_color"
API 0.0 warn 302017: illegal argument "Illumination_phong_Phen" for function call to "Illumination_phong_Phen"
API 0.0 error 301099: while defining texture "MI_default_texture_default_1d.dds": failed to open texture file default_1d.dds
IMG 0.0 error 101003: default_1d.dds: can't open file for reading (No such file or directory)
API 0.0 error 301099: while defining texture "MI_default_texture_default.dds": failed to open texture file default.dds
IMG 0.0 error 101003: default.dds: can't open file for reading (No such file or directory)
API 0.0 error 301099: while defining texture "MI_default_texture_default_reflection.dds": failed to open texture file default_reflection.dds
IMG 0.0 error 101003: default_reflection.dds: can't open file for reading (No such file or directory)
API 0.0 warn 302017: illegal argument "Math_color_add" for function call to "Math_color_add"
API 0.0 warn 302017: illegal argument "Math_color_mix" for function call to "Math_color_mix"
API 0.0 warn 302017: illegal argument "Math_color_multiply" for function call to "Math_color_multiply"
API 0.0 warn 302017: illegal argument "Normals_bumpmap" for function call to "Normals_bumpmap"
API 0.0 warn 302042: while defining material "max_default_mtl_phen|Mtl": material shader "Normals_bumpmap" in material "max_default_mtl_phen|Mtl" returns a vector, expected color
API 0.0 warn 302017: illegal argument "Normals_make_normal" for function call to "Normals_make_normal"
API 0.0 warn 302042: while defining material "max_default_mtl_phen|Mtl": material shader "Normals_make_normal" in material "max_default_mtl_phen|Mtl" returns a vector, expected color
API 0.0 warn 302017: illegal argument "Texture_lookup_2d" for function call to "Texture_lookup_2d"
con el 3ds max 2012 por lo menos no se cuelga el programa y con el 2011 se cierra siemplemente
uso Windows 7 x 64
los programs están con todas las actualizaciones
no entiendo que esta mal
gracias por la ayuda
tomas
