Tema: Mudbox 2009 me reinicia el pc
    I'm waiting so long... Avatar de ikifenix
    Feb 2005
    Jauja
    El tema es que me he bajado el trial de mudbox 2009 de la página de Autodesk (no empeceis con temas de piratería).
    Lo instalo (he probado la versión de 32 y la de 64 bits), lo inicio, me aparece la ventanita de tutoriales y todo eso, pero cuando la cierro y paso el cursor por encima del visor, el pc se me reinicia. (con la versión anterior de mudbox no me pasa, solo con la 2009).
    Mi pc:
    2Gb ram ddr 400mhz
    Amd athlon 64 3000+ (2ghz)
    Ati Radeon x850 xt (últimos drivers instalados)
    Windows xp x64 sp2
    500gb disco duro
    Uso ratón, no tengo tableta.
    Requisitos del programa:
    The 64-bit versión of Mudbox 2009 software is supported on the following operating systems:
    • Microsoft Windows XP Professional x64 Edition, SP2
    • Microsoft Windows Vista Business, SP1
    At a minimum, the 64-bit versión of Mudbox 2009 software requires a system with the following hardware:
    • Intel EM64T, AMD Athlon® 64, or AMD Opteron® processor
    • 1 GB RAM (2 GB recommended)
    • 650 MB free hard drive space (2 GB recommended)
    • Ethernet adapter or wireless Internet card
    • Qualified hardware-accelerated OpenGL graphics card
    • Three-button mouse or qualified Wacom tablet
    • DVD-ROM drive
    Notes:
    • Latest graphics card drivers are required for proper display.
    Lo único que he encontrado ha sido esto, pero dice que no las recomienda, no que no estén soportadas:
    Important Notes
    (1) There are many cards based on GeForce GPU chipsets. NVIDIA and Autodesk do not recommend these cards for use with Mudbox as you may experience various refresh, display and stability problems, and inadequate performance. We suggest you choose NVIDIA workstation cards instead, such as the Quadro families which are much better suited to high-end 3D packages such as Mudbox. Nvidía GeForce VS Quadro White Paper [PDF]
    (2) For the same reasons as the ones listed in note (1), ATI and Autodesk do not recommend the use of ATI Radeon GPU chipsets cards.
    (3) For a productive user experience with Mudbox, it is recommended to use a card which has a minimum of 512 MB of video memory.
    En teoría tendría que funcionarme, ¿a alguien más le pasa o sabe como solucionarlo?
    PD: Mi pc funciona perfectamente, no se reinicia, ni se bloquea ni nada con ningún programa, solo con mudbox 2009 (por descartar problemas de SO o hardware).
    Gracias.
    Aug 2005
    Re: Mudbox 2009 me reinicia el pc
    Hola a todos,
    Yo tengo un problema similar al de ikifenix. Acabo de bajar la trial de Mudbox de la página de Autodesk, el software se incia pero cuando voy a escojer un modelo desde crear da un error desconocido y se cuelga, tengo que terminar el proceso desde el administrador.
    ¿A alguno de vosotros le a funcionado la trial? es para saber si el problema es mio o la trial esta mal.
    PD: la que he bajado es la 32 bits.
    Gracias.
  1. 3ds Max Mudbox Problema al pasar un objeto de 3d max a mudbox
    Por tienequien en el foro Materiales y Texturizado
    Último mensaje: 04-12-2012, 13:40
  2. Exportar a MudBox 2009
    Por Estevet en el foro Modelado
    Último mensaje: 12-05-2009, 12:23
  3. Mudbox 2009 - Bocas, orejas y todos esos detalles
    Por luisserrano en el foro Modelado
    Último mensaje: 05-01-2009, 01:42
  4. problema con mudbox 2009 =
    Por xnaxox en el foro Problemas con Programas
    Último mensaje: 15-12-2008, 03:56
  5. Mudbox 2009 performance preview
    Por Dexter en el foro Noticias
    Respuestas: 62
    Último mensaje: 09-10-2008, 09:09
