Tema: Windows no reconoce DC y DVD
    soy un emigrante Avatar de Pit [reloaded]
    viendo bob esponja
    Pues eso, al que le pase... se trata de esto:
    (yo me he vuelto mico hasta encontrarlo)
    He seguido los pasos, pero sin desinstalar los programas Adobe, y ya me reconoce otra vez los DVD driver
    Maldita informática, antes vivíamos mejor
    CD or DVD drive not recognized by Windows after you install an Adobe application
    Issue
    Windows 2000, XP or Vista doesn't recognize your CD or DVD drive after you install one or more of the following Adobe applications:
    • Audition
    • Encore
    • Photoshop Album
    • Photoshop Elements
    • Premiere Elements
    • Premiere Pro
    • Production Premium
    • Production Studio
    • Soundbooth
    Reason
    Other CD and DVD burning applications, such as Roxio Easy CD Creator, are installed on the computer.
    Solution
    Refresh the CD and DVD drivers list in the Windows registry.
    Disclaimer: The registry contains system-related information that is critical to your computer and applications. Before modifying the registry, be sure to make a backup copy of it. Adobe doesn't provide support for problems that arise from improperly modifying the registry. Adobe strongly recommends that you have experience editing system files before you modify the registry. For information on the Windows Registry Editor, see the Windows documentation or contact Microsoft Technical Support.
    To refresh the CD and DVD drivers list in the Windows registry:
    Important: After you refresh the driver list in the Windows registry, you may need to reinstall any other CD or DVD burning applications on your computer. If you restart Windows after this procedure and other CD or DVD burning applications do not recognize the CD or DVD drive, then reinstall those applications.
    1. Uninstall your Adobe application.
    2. Open Registry Editor:
      • On Windows 2000 and XP: Choose Start > Run. Type regedit in the Open text box and clik OK.
      • On Windows Vista: Choose Start. Type regedit in the Search text box, and press Enter.
    3. In the left pane of Registry Editor, navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
    4. Select File > Export (Windows XP and Vista) or Registry > Export Registry File (Windows 2000).
    5. In the Export Registry File dialog box, select Selected Branch under Export Range, name the file (for example, CDDVDkey.reg), and clik Save to save the file to the Desktop.
    6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Clik Yes in the Confirm Key Delete dialog box.
    7. Select the UpperFilters line, and then choose Edit > Delete. Clik Yes in the Confirm Key Delete dialog box.
    8. Close Registry Editor.
    9. Open Device Manager:
      • On Windows 2000 and XP: Choose Start > Control Panel. Double-clik the System icon, clik on the Hardware Tab, then clik on Device Manager.
      • On Windows Vista: Choose Start > Control Panel, double-clik System, then clik Device Manager in the Tasks pane.
    10. Clik on the plus symbol next to DVD/CD-ROM Drives.
    11. For each DVD-ROM or CD-ROM drive listed, select the icon then choose Action > Uninstall.
    12. Restart Windows.
    13. Windows will automatically detect and reinstall your DVD-ROM or CD-ROM drives. You can verify that the drives are installed by viewing them in Device Manager (see step 9). If the drives are not present, open Device Manger and choose Actions > Scan For Hardware Changes.
    14. Reinstall your Adobe application.
    15. Restart Windows.
    Important: If this solution doesn't resolve the problem with the application you reinstalled, then you should restore the CD and DVD drivers list in the Windows registry.
    To restore the exported CD and DVD drivers list:
    1. Double-clik the registry key you exported.
    2. Close the Registry Editor.
    3. Restart Windows.
    The Adobe Captivate demonstration below illustrates how to refresh the CD and DVD drivers list in the registry.
    Última edición por Pit [reloaded]; 18-09-2008 a las 09:01
    Re: Windows no reconoce DC y DVD
    Juer, macho, leyendo el título he pensao:
    "Que narices habrán hecho estos con el DC project para que al 'vindors' no le mole".
    Luego he leído el resto y se ha hecho la luz.
    viendo bob esponja
    ostias... he cambiado DC por CD...
    en qué estaría pensando
  1. 3D Max no me reconoce un objeto
    Por Piriel en el foro Modelado
    Último mensaje: 15-02-2012, 22:37
  2. 3ds max no reconoce mi ram
    Por sajat en el foro Hardware
    Último mensaje: 17-09-2009, 17:51
  3. Respuestas: 12
    Último mensaje: 24-11-2008, 14:43
  4. No se reconoce dispositivo usb
    Por INMACULADA en el foro Hardware
    Último mensaje: 09-11-2008, 16:51
  5. Windows XP64 no me reconoce los 4Gb
    Por d10s en el foro Hardware
    Respuestas: 21
    Último mensaje: 24-04-2008, 21:45
