Tema: Tutorial pelo en Blender
    Maestro -YeDaY- Avatar de -YeraY-
    Apr 2004
    Islas Canarias
    Blender Tutorial pelo en Blender
    Bueno en mi búsqueda del saber del pelo en max encontré esto:
    http://forums.cgsociety.org/showthre...light=hair+fur
    seguramente ya lo hayan posteado, porque no estoy al corriente de Blender en el foro, pero por si no lo han posteado.
    1. Add a Sphere (Space - Add - Mesh - UVsphere) (32 Rings x 32 Segments)
    2. Open Object menú (F7)
    3. Open Particle Buttons
    4. Click Add new
    5. Change the type of particle system from Emitter to hair
    6. Under the physics section change the 'normal' value from 0.000 to 0.060 (this determines the length of each strand
    your sphere should now have strands coming out of it
    7. change the 'random' value to 0.020
    8. go to the materials menú (F5)
    9. Click add new and under the Preview tab change the preview type to strand and enable oversampling.
    STRANDS
    The shape of your strands can be determined by adjusting the end width, start width and the shape. this is done in the render pipeline under 'strands'
    10. I chose the following settings for the purpose of this tutorial.
    11. open the textures menú click add new and select blend as the texture type
    12. open the colors tab, click colorband. click the line on the left hand side and change the 'A' (alpha) value to 1.000 then click the line on the right hand side and change the alpha value to 0.000
    13. go back to the material buttons, then under the 'map input' tab change the texture coordinates to 'strand'
    14. Now open the 'Map to' tab and turn 'col' (colour) off and 'alph' (alpha) on.
    15. in the render pipeline turn 'Ztransip' (transparency) on and in the material tab change the value of 'A' (alpha) to 0.000.
    If you render it now it is starting to look cool.
    16. go back to the particle buttons and under the 'particle system' tab change the amount to 10000, this will thicken the hair. if you have a good computer try turning it up more and more (save before doing this because it could cause blender to crash.
    now mess around with the physics buttons eg. 'brown' (Brownian), random, normal... and see what you can come up with.
    i used these settings
    and came up with this
    Última edición por 3dpoder; 11-03-2016 a las 02:17
    Aprendiz
    Madrid
    Re: Tutorial pelo en Blender
    Muchas gracias Yeray, yo no lo conocía.
    Lastima que no hayas puesto el iconito de blender al hilo. A ver si algún admin blenderadicto se lo pone, que el naranja se ve mejor. :mrghappy:
    30 años de Star Wars
    Apr 2004
    Islas Canarias
    cambiado...
  1. Blender Tutorial de pelo en Blender
    Por Soliman en el foro Blender
    Último mensaje: 27-01-2016, 23:18
  2. Blender Pelo en Blender 2 5 Cepillo de pelo
    Por Nellie en el foro Partículas y Dinámicas
    Respuestas: 21
    Último mensaje: 26-09-2011, 13:39
  3. Blender Tutorial: Creacion de Pelo en Blender 248
    Por angelsan en el foro Blender
    Último mensaje: 08-08-2011, 19:43
  4. 3ds Max Tutorial para crear pelo con polígonos
    Por akm en el foro Peticiones y Búsquedas
    Último mensaje: 21-06-2010, 04:15
  5. Tutorial de pelo en Blender
    Por David Bogas en el foro Partículas y Dinámicas
    Respuestas: 15
    Último mensaje: 03-02-2008, 01:08
