Tema: Hacer Swf con herramientas libres gpl
    Aug 2005
    lavapies, madrid
    Hacer Swf con herramientas libres (gpl)
    Haciendo pruebas para generar un swf para mi empresa, que trabaja con software libre, me pasaron este conjunto de herramientas para linux, http://www.swftools.org/, contiene las siguientes aplicaciones para manipular y generar swf, y aprvechando que tenía que documentarlo, os cuento un poco por aquí.
    PDF2SWF A PDF to SWF Converter. Generates one frame per page. Enables you to have fully formatted text, including tables, formulas etc. inside your Flash Movie. It’s based on the xpdf PDF parser from Dereque B. Noonburg.
    SWFCombine A tool for replaceing SWFs into Wrapper SWFs. (Templates) E.g. for including the pdf2swf SWFs in some sort of Browsing-SWF.
    SWFStrings Scans SWFs for text data.
    SWFDump Prints out various informations about SWFs.
    JPEG2SWF Takes one or more JPEG pictures and generates a SWF slideshow.
    PNG2SWF Like JPEG2SWF, only for PNGs.
    GIF2SWF Converts GIFs to SWF. Alos able to handle animated gifs.
    WAV2SWF Converts WAV audio files to SWFs, using the L.A.M.E. MP3 encoder library.
    AVI2SWF Converts AVI animation files to SWF. It supports Flash MX H.263 compression. Some examples can be found at examples.html.
    Font2SWF Converts font files (TTF, Type1) to SWF.
    SWFBBox Allows to readjust SWF bounding boxes.
    SWFC A tool for creating SWF files from simple script files.
    SWFExtract Allows to extract Movieclips, Sounds, Images etc. from SWF files.
    RFXSWF Library A fully featured library which can be used for standalone SWF generation. Includes support for Bitmaps, Buttons, Shapes, Text, Fonts, Sound etc. It alos has support for ActionScript using the Ming ActionCompiler.
    Yo he usado las siguientes:
    1.
    Avi2swf, comprime dejando una calidad regular, en el mejor de los casos, aparte el swf que genera no funciona en loop. Para videos esta bien no obstante.
    2.
    Jpeg2swf, genera un swf a partir de una serie de jpgs, el problema es que ocupa tanto como ocupan los jpgs. Pero da mejor resolución que el avi2swf.
    3.
    Png2swf, igual que el Jpeg2swf pero con más calidad y tamaño.
    4.
    Swfc, genera un swf a partir de un archivo de código. Laborioso pero resultón. Es la forma de hacer algo realmente tipo flash, y se puede combinar con actionscript http://www.swftools.org/swfc/swfc.1.html
    5.
    Swfccombine, genera un swf a partir de varios.
    Senior Member Avatar de TBC3D
    Apr 2006
    En mitad de un sueño
    Re: Hacer Swf con herramientas libres (gpl)
    .impresionante!
    Habitacus! Avatar de josepzin
    Carthagonova
    Cita Iniciado por TBC3D Ver mensaje
    .impresionante!
    Lo mismo digo!!
    Yo estuve investigando hace un tiempo con FAMES (compilar ActionScript desde Eclipse), pero no llegué a tanto. La dependencia del GUI de Flash sigue estando.
    Voy a mirar ese listadon con atención
    Senior Member Avatar de otisnet
    Caldas the Reis against the machine. Pontevedra.
    Has probado esta librería:
    http://ming.sourceforge.net/
    Si te manejas bien con código php es muy resultona. Permite generar flash embebido en php o guardar el swf que generes con tu código en archivos independientes. Permite embeber también ActionScript. Aquí ejemplos con código:
    http://www16.brinkster.com/gazb/ming/index.html
    Otra alternativa es http://f4l.sourceforge.net/. Un clon del macromedía flash. Pero creo que el proyecto esta bastante parado.
    Renunciar a fracasar es renunciar a vivir.
    Marqués de Carabás Avatar de alberizo
    Nov 2005
    el proyecto f4l acabó hace tiempo, se unieron con otro que no recuerdo y dieron lugar a Uira, actualmente que yo conozca, libres y para linux, esta Uira y Ktoon, los cuales también están algo parados por falta de fondos.
    Leander dijo uno antes de ayer para Windows y Mac, era open source sino recuerdo mal.
    Carthagonova
    Relacionado con el tema: Video Streaming en Flash con Software Libre en http://www.morcy.org
  1. Pajaros libres free birds
    Por 3dpoder en el foro Cine
    Último mensaje: 04-10-2013, 00:16
  2. Herramientas para hacer videojuego
    Por 1Cess1 en el foro Videojuegos
    Respuestas: 13
    Último mensaje: 17-06-2011, 18:27
  3. Blender Herramientas Libres para Sintesis 3D
    Por 3dpoder en el foro Un Enfoque práctico a Blender
    Último mensaje: 10-09-2009, 01:55
  4. Y los ratos libres
    Por MiraVirtual en el foro Trabajos en Proceso
    Último mensaje: 03-10-2008, 12:31
  5. Logos de programas libres
    Por Crawler en el foro Peticiones y Búsquedas
    Último mensaje: 15-01-2007, 15:56
