Tema: aYUDa CON BRaZIL
    May 2004
    AYUDA CON BRAZIL
    HOLA...tengo el motor de render de Brazil y cuando lo aplico me sale un mensaje en el editor de materiales que dice "LA IMAGEN ESPECIFICADA NO ESTA SOPORTADA POR BRAZIL. EL Máximo ANCHO ES DE 512 PIXELES Y EL ALTO MAX ES DE 384". SI alguien sabe donde puedo yo configurar el max para que no suceda esto se lo agradecería.GRACIAS
    ¿Brazil Rio? Si es positiva la respuesta seguramente es debido a las limitaciones que tiene con respecto a la versión comercial completa.
    Un saludo,
    Shazam.
    Victor Navone
    Chuck Jones
    John Lasseter
    Senior Member Avatar de Mario
    Madrid
    Supongo que debe ser eso si, la Rio tiene ese tipo de limitaciones, especialmente en el tamaño y que no permite render distribuido si no recuerdo mal.
    Aunque lo cierto es que nunca encontré una lista de las cosas que están capadas.
    Un saludo
    Esta es la info:
    What's Not In This Build
    This build is based upon the current versión of Brazil r/s, but is selectively feature-limited so as to make it primarily usable for educational and testing purposes. Rio is not designed or intended for use in professional or production environments and will not work well in a mixed "Brazil r/s" and "Brazil Rio" environment. A list of disabled features and limitations would include:
    no support for network rendering
    image size has been limited to 512x384 maximum
    file saving/loading limitations:
    scene files can be created/saved/loaded freely between Rio versións
    scene files saved in Brazil Rio will be loadable/savable in Brazil r/s
    scene files saved in Brazil r/s will be loadable, read-only, in Brazil Rio (meaning you will not be able to re-save the loaded file)
    This versión is much faster and more complete than previous public test builds and contains the same features that were used to generate all the images in the gallery at splutterfish.com.
    What's the differenece between Rio and a full evaluation of Brazil r/s
    The evaluation is typically a 30 day, full-featured, timelocked versión of Brazil r/s and it includes access to all our normal support services, network rendering, floating licensing, full documentation and examples, etc. Evaluation licenses are handled on a case by case basis.
    For further information on evaluating or purchasing the full versión of Brazil r/s, pleast contact one or our our resellers or sales@splutterfish.com.
    Usage
    Those that have used previous Brazil r/s test versións should be able to pik up the basics of Rio fairly quickly. SplutterFish doesn't officially provide any support for Rio, but we have a community forum that is probably be the best spot to get good answers. A subset of the Brazil r/s documentation and example files will be available for Rio users on the SplutterFish website.
    Sacada de esta página: http://www.splutterfish.com/sf/sf_ge...ents/docs/info
    Saludos renderiza2,
    Shazam.
    Victor Navone
    Chuck Jones
    John Lasseter
    May 2004
    gracias por su ayuda, voy aver como hago para corregila.GRACIASSSSSS
  1. ayuda instalar Brazil a 3ds max 2009
    Por solaresmty en el foro Problemas con Programas
    Último mensaje: 09-09-2010, 22:30
  2. ayuda parametros brazil
    Por juanmis78 en el foro Render, Iluminación y Cámaras
    Último mensaje: 22-06-2009, 06:09
  3. ayuda Instalacion Brazil
    Por ercoqui en el foro Plugins
    Último mensaje: 19-04-2006, 19:46
  4. Splutterfish Brazil 1 2 52 For 3Ds Max 7 ayuda
    Por rak vader en el foro Render, Iluminación y Cámaras
    Último mensaje: 11-07-2005, 01:07
  5. Instalo luces y camaras Brazil pero luego no se como rederizar en Brazil
    Por jmsmonteoliva en el foro Render, Iluminación y Cámaras
    Último mensaje: 06-05-2005, 09:05
