Tema: M~R it Test Render v1 0
    May 2003
    ITALY
    M~R.it Test Render v1.0
    "M~R.it Test Render":
    - pdf informativo ita/ing
    - piante-prospetti-sezioni dwg
    - modello 3d (nei vari formati)
    - foto
    Miniaturas adjuntadas Miniaturas adjuntadas M~R it Test Render v1 0-3testrenderv1.jpg
    Última edición por 3dpoder; 24-05-2005 a las 15:06
    Senior Member Avatar de NECROS
    Jul 2003
    BCN
    Re: M~R.it Test Render v1.0
    Muy buen aporte...hace tiempo que sigo los pasos de este forum(una o tres semanas...jijiji) y esta bastante bien...el material es de primera...si señor!!!
    Gracias mil!!!
    Timmy!!
    May 2003
    ITALY
    M~R.it have organized a little test render, the rules and an introducion of the test are collected in the pdf file.
    In the download section of M~R.it site
    you con find the 3D model files in the following format:
    MAX-3DS-OBJ-C4D-DWG-DXF-SAT-FBX
    To better understand the church in the download section you can find alos a photo collection and 2D files of the plans, the prospects and a section.
    General rules to participate at M~R TestRender v1.0
    The character and the reliability requirements that we want to make, we have decided to purpose some rules that you must respect if you want to participate, all the results must be rigorously comparables.
    The images must respect the following characteristics:
    LIGHT: Lights parameters must equal for interiors scenes and exteriors scenes; sky (skydome o phsky) sun ( phsun o artificiale emitter).
    SIZE: Images size must select between this suggestions; px 1000x1000 - px 1000x700 - px 700x1000.
    CAMERAS: there is no limits
    MATERIALS:Used materials for texturing must be similar at the original building; you can to base yourself with photographic materials found on others resources (the founded material must be produced before the end of contest)
    TEXT: It is oblige to replace the following data relatively on the image:
    - used plugin
    - render time
    - used hardware
    - lights setup
    - cameras setup
    EXTENSION: All the image must be saved in .jpg with high quality to publish her on the forum.
    MODEL: It is impossible to modify or to add some external elements.
    May 2003
    ITALY
    BlenderAdicto Avatar de 8tintin
    Jun 2002
    Interesante el foro. Jeje.. he tenido la sensación de "deja vu" al ver esta imagen de la galería:
    http://www.maxwellrender.it/modules....view_photo.php
    ¿No había alguien insinuado por aquí que Arnold podía tener algo que ver con maxwell render?
    No me hagáis caso, frikadas marujiles de nuevo XD
    Mar 2005
    en mi casa
    y yo también tintin, pero la foto que debe ser impresionante es la del cartel primero de la izquierda
    Cuanto mas se, mas cuenta me doy de lo poco que se
  1. Test Render Consejos
    Por yunans en el foro Infografía General
    Último mensaje: 02-10-2016, 20:25
  2. Render test que no se hacer
    Por Cicli en el foro Render, Iluminación y Cámaras
    Último mensaje: 26-11-2009, 23:10
  3. Test Render Interior
    Por karlosMX en el foro Trabajos en Proceso
    Último mensaje: 05-03-2007, 10:59
  4. M~R it Test Render v2 0 artificial light
    Por isma en el foro Noticias
    Último mensaje: 30-09-2005, 21:03
  5. Dos test mas
    Por DonOscar en el foro Cortos de Animación
    Último mensaje: 05-09-2005, 02:44
