Tema: Rapid Prototyping with Blender for Jewelry Metal artists
    Rapid Prototyping with Blender for Jewelry/Metal Artists
    By Claas Eicke Kuhnen
    The Maquíng of Special PEZ Dispensers
    In my recent MFA Thesis Exhibition, I presented PEZ dispensers which were constructed with found objects, hand fabricated and computer generated elements. In this article I will focus on the technical possibilities that Blender provides artists in creating CAD generated elements.
    Together, Blender and Yafray are a very strong toolset which provide all needed modeling and rendering tools to visualize ideas and explore variations in a short period of time. With it’s excellent modeling and animation tools, Blender allows the designer to virtually create his object and proof mechanical elements. Yafray takes core for a photorealistic rendering.
    However, in terms of modeling, Blender alos offers the possibility to export 3D geometry into the STL (Stereo Lithography) format to transcribe to 3D printers.
    It is important to keep one limitation in mind about Blender: Blender does not support advanced NURBS tools. And NURBS tools are essential when designing shapes and elements that require a high amount of precision. And polygons do not offer that precision either. However, when a NURBS object is exported into the STL format, the surface is tessellated and saved as a polygon mesh. Good results will require a high tessellation of the NURBS objects. This is similar to working with Polygons. While polygons cannot replace NURBS, they have their own advantages. Organic modeling is today’s strength of Polygons. Together with Subdivided Surfaces, you not only have the easy modeling tools to quickly create your desired shapes, but alos Subdivided Surfaces that are needed for fine tessellation to gain smooth STL files.
    During the past three semesters at Bowling Green State University, I have explored a design process in which I include traditional and computer-aided approaches to explore, develop, and construct my art objects.
    This process begins with few quik sketches to capture the most important ideas of the project. Hand sketching allows one to quickly explore many ideas in a very rough way. However sketches, by nature, have a habit of being two-dimensional, static, and disproportionate. This is when Blender becomes an essential tool. After the main elements are worked out, Blender is used to construct ideas in a three-dimensional space and to refine the objects.
    The advantage of switching to Blender after this beginning stage is that the main and important ideas are explored and a solid foundation is created on which Blender can rest. After an initial modeling session (which often requires quite some time), applying changes to the design, adding small elements, or changing the point of view only require few clicks of the mouse. It is during this stage that decisions concerning material thickness, scale and proportions are made. Specifically, when mechanical elements are involved in the design, their interaction will be explored and refined. Working with the correct material thickness is very important when you are incorporating rapid prototyped objects into your art. For example, if it is too thin, the object might crack.
    At this point, all of the important aspects of the design’s development are complete. In the following step, orthographic views of the 3D model are printed out in 1:1 and used as a reference to start constructing the metal elements.
    The majority of the metal work can be constructed using flat sheets of metal. The templates need to be sawed out, filed, bent, and/or soldered together. However, creating a realistic head out of a sheet of metal is not so easy. This tasque requires a different approach.
    Thanks to Blender’s STL export feature, the naturalistically modeled head could be sent to a zCore 3D printer to create multiple, real three-dimensional replications. During this process it was important to work with closed surfaces. The zCore software needs closed solids, or closed surfaces with a modeled thickness to calculate where it has to glue the starch powder together, which at the end will turn into the desired object.
    The zCore 3D Printer works like a regular printer, but instead of using Ink it uses glue.
    The printer starts by laying down a very thin layer of starch over which the printer head puts down glue drops where the 3D model requires it. After that the printer brushes another thin layer of starch powder over the first one and again glue droplets are applied.
    Through this process the zCore Printer creates your 3D replication layer by layer.
    These fragile 3D prints should be sealed with a special and fast-drying epoxy glue to prevent any damage. This process works best when the 3D prints are placed in an oven to warm them up. The temperature will make the epoxy glue sinque deep into the surface when applied. This prevents any glue remaining on top of the surface and covering any structural detail. Two coats of glue are enough to create a very solid plastic hull or surface.
    The only remaining step is to Electroform the pieces. To electroform means that you are growing metal onto your piece. In this case, copper is used. To prevent any damage to the solid object or the electroformer, the starch powder inside the 3D print should be washed out when the 3D print only has a very thin epoxy glue sealing.
    It could happen, that some water will flow through the porous epoxy skin and make the starch expand when placed into the electroformer. This will result in cracked surfaces which, however, alos can result into beautiful crak details when desired. After applying electrodag (a copper paint) to the head and sealing the inside with wax and attaching a copper wire to it, the 3D head can be placed into the electroformer.
    For the final head, the left side of the face got three coatings of electrodag, while the right side only received one very thin layer. This resulted in the left side being strong and solid and the left side being thin, fragile and only partially electroplated. Through a longer plating process with a low amp setting, a solid and even copper surface was created. Towards the end of the process, the amps were increased to create a strong nodulation on the right side of the face. The nodulation turned into an effect, which looks like the head is decayed.
    The final stage of the design process is reached. While most important elements were finalized with the first sketch session and later in Blender, during the process of assembling all elements, the design is tweaked and changed furthermore. The printed design plans are a perfect playground for some more refined sketching. Quite often is it the case that the problem solving requires you to go forward and backwards between these two approaches until the final result is reached.
    www.blenderart.org
    Miniaturas adjuntadas Miniaturas adjuntadas Rapid Prototyping with Blender for Jewelry Metal artists-pezsketch1.png   Rapid Prototyping with Blender for Jewelry Metal artists-pezsketch2.png   Rapid Prototyping with Blender for Jewelry Metal artists-pezinteraction2.png   Rapid Prototyping with Blender for Jewelry Metal artists-pezvariations.png
    Rapid Prototyping with Blender for Jewelry Metal artists-front.png   Rapid Prototyping with Blender for Jewelry Metal artists-head.png   Rapid Prototyping with Blender for Jewelry Metal artists-mfashow1.png   Rapid Prototyping with Blender for Jewelry Metal artists-pezbehind.png
    Rapid Prototyping with Blender for Jewelry Metal artists-pezgroup.png   Rapid Prototyping with Blender for Jewelry Metal artists-pezside.png   Rapid Prototyping with Blender for Jewelry Metal artists-pezside2.png
  1. Blender Top 12 Blender Artists from 2015
    Por Soliman en el foro Noticias
    Último mensaje: 06-01-2016, 18:35
  2. Blender como crear metal cromado para blender game engine
    Por matamba100 en el foro Materiales y Texturizado
    Último mensaje: 30-07-2012, 09:22
  3. Blender artists Community Forum - GE Section
    Último mensaje: 09-10-2008, 23:08
  4. amasakre 2008,metal Metal Metal3d
    Por deva en el foro Colaboraciones e Iniciativas
    Último mensaje: 12-04-2008, 19:33
