Página 2 de 2 PrimerPrimer 12
Resultados 16 al 26 de 26
Tema: EL Misterioso Funcionamiento de un Espejo
  1. #16
    Re: EL Misterioso Funcionamiento de un Espejo
    Bah.. el arcoiris es un círculo entero,pero solo se ve la mitad, eso no tiene gracia xDDDD
    Lo del espejo me parece que me he explicado mal :P Si hubiera puesto lo de las letras se hubiera entendido mejor
    One way to start to get a handle on this is to take a piece of paper with your name written on it. Look at it in the mirror and it will be reversed. Now turn it vertically. You will find that the lettering is reversed, but it is not upside down. That should start to give you a clue as to what is going on. Now take your finger and point to the first letter in your name, both on the paper and on the mirror. Notice that there is a one-to-one correspondence -- if the letter appears on the left hand side of the paper from your perspective, it appears on the left hand side of the mirror.
    Take a piece of thin, translucent paper and write your name on it. Stand in front of a mirror and hold the paper up so that you can read the paper normally. Now look in the mirror. You are seeing the bak of the translucent sheet in the mirror, and the word is not reversed -- it looks completely normal. Now turn the paper over and look at it in the mirror. It is reversed, but so are the letters on the bak of the translucent sheet. Note that you turned the paper over -- you reversed it!
    In other words, the reason why letters look reversed in a mirror is because you are presenting them to the mirror reversed. The reason why someone coming toward you can read the message on your T-shirt is because the letters on your T-shirt are reversed (from your perspective) when you wear it. If you printed the words on the T-shirt so that you could read them (from the inside of the shirt), the words would look reversed to an approaching person but they would look great in a mirror.
    Y no no recuerdo que me lo explicaran en clase pero por lo menos ahora ya se como funciona
  2. #17
    Destilado artesanalmente Avatar de Rashek
    Jul 2004
    Sobre mis pies
    Aver, lo del espejo también me lo pregunte yo cuando estaba estudiando la síntesis de la luz, y la verdad que no me kedo muy claro (aunque no le di muchas vueltas). El caso es que la profesor decía que el blanco refleja TODOS los rayos de la luz, y entonces fue cuando me pregunte, si el blanco los refleja todos.. que coño hace el espejo?¿ supongo que lo que hará será desviarlos solamente.. en fin, aver si alguien me kita la duda
    www.goldpiece.net
  3. #18
    Valencia-España
    Cita Iniciado por Rashek
    ...si el blanco los refleja todos.. que coño hace el espejo?
    Es espejo refleja todo rayo de luz direccionalmente a diferencia de algo blanco que refleja difusamente la suma de todos los rayos de luz que recibe desde cualquier ángulo.
    Mi web: NicoDigital.com
  4. #19
    Me estoy quitando Avatar de Frodo
    Sep 2002
    Valinor, con montones de elfas ligeritas de ropa.
    Uno de mis profesores de diseño gráfico nos comentó en su día que el blanco es blanco porque refleja todos los colores y el negro en cambio los absorve. Y que un objeto tiene un color determinado porque absorve todos los demás menos el que se ve, que es el que refleja.
  5. #20
    Senior Member Avatar de Trinidad
    Cuenca
    Según recuerdo haber leído en la ayuda de algún programa infográfico, todos los objetos son iguales en ese sentido, sea un espejo, un papel, una vaca, etc., todos reflejan la luz (excepto los colores que absorben) de igual forma, pero en las superficies rugosas se difumina más que en las lisas, porque la luz rebota en muchas más direcciones.
    Sexo: Masculino
  6. #21
    Wired Member Avatar de elec3duende
    May 2004
    Sevilla
    Excepto "el cuerpo negro", que absorbe todo lo que le llega, pero claro es un modelo ideal.
    Yo tampoco entiendo donde esta la complicación de entender el funcionamiento de un espejo.
    ¿Es darle mucho las vueltas a las cosas o me da esa impresión?.
    Ejemplo:
    2+2=4 pero si afinamos mucho 2+2 no es 4 si definimos esta operación en otra base mayor de 2. Pero claro se sobreentiende que cuando se dice 2+2=4 es porque estamos en base 10.
    Buscarle las vueltas a las cosas es quieres confundir a nuestro pequeño cerebro de primate que esta poco desarrollado. Aleluya!!!
    La ignorancia afirma o niega rotundamente; la ciencia duda.
    Voltaire, François Marie Arouet
  7. #22
    Glidereando Avatar de Chaman
    Jul 2005
    Madrid
    Cita Iniciado por elec3duende
    Si afinamos mucho, 2+2=4 para cualquier base > 4, siempre que esté bien definido la operación + y la relación de equivalencia =. :
    (otro por detrás vendrá que una colleja matematica me dara... )
  8. #23
    Buenos Aires, Argentina
    joe, que el funcionamiento de un espejo no tiene truco, lo que pasa es que estamos acostumbrados a decir que invierte derecha e izquierda y eso es falso. Si tu levantas el brazo derecho, la imagen también leanta el brazo que esta a la derecha, o no? claro para ti es el brazo izquierdo porque lo ves de frente al tío porras, pero ahí esta el truco: el espejo hace una inversión sobre el eje Z, o sea invierte la espalda por el frente. Ahora si? ta claro? de paso, es un buen tip para tener en cuenta si queréis hacer un render y el programa no trabaja con reflejos y tenéis que fabricarlo " a mano"
  9. #24
    Jun 2003
    Castellón
  10. #25
    May 2004
    Sevilla
    mu bien Mars, ole.
    ¿qué tal una investigación del efecto fresnel o el ángulo de brewster o la reflexión límite? esta todo muy relacionado.
  11. #26
    Senior Member Avatar de Quel
    Sep 2004
    Vic (Barcelona)
    Cita Iniciado por ChamanMan
    Beo que en la uni también has estudiado algebra. Yo desde esas clases ya no aseguro nunca que 2+2 sean 4 . Porque como dices ... todo depende de lo que se entienda por la operación "+" y la operación "=". también es importante saber sn estamos en un anillo, un cuerpo, etc ... o en que "mundo numerico" se supone que estamos trabajando y bla bla bla bla bla (Suspendí muchos años la maldita algerbra, eso de ser capaz de resolver la mayoría de problemas de cabeza, pero sin saber dar una explicación lógica. Eso ponia histeria a la profesora, que se negaba a aprobarme pese a dar las respuestas correctas, solo por no ser capaz de justificarlas correctamente sobre papel ).
    Quel XX's (... ...)
  1. Maya El Misterioso Problema: Mental Ray ha dejado de Funcionar
    Por Moiras7 en el foro Problemas con Programas
    Último mensaje: 08-02-2011, 13:25
  2. El segmento misterioso
    Por alfabetico en el foro Modelado
    Último mensaje: 19-12-2010, 16:51
  3. Misterioso punto
    Por metalfox6383 en el foro Modelado
    Último mensaje: 01-09-2009, 04:55
  4. misterioso comportamiento de aMD phenom x4 y vray
    Por shams2222 en el foro Render, Iluminación y Cámaras
    Último mensaje: 15-08-2009, 02:43
