Gracias Gracias:  23
Página 7 de 11 PrimerPrimer ... 34567891011 ÚltimoÚltimo
Resultados 91 al 105 de 157
Tema: Videotutoriales y mas para Houdini
  1. #91
    Re: Videotutoriales y + para Houdini
    Se lo han sabido montar los de DT, han apostado bien y creo que muy oportunamente ;-)
    Victor Navone
    Chuck Jones
    John Lasseter
  2. #92
    Houdini Re: Videotutoriales y + para Houdini
    Leander: Se que este, en particular, te va a gustar y mucho (como a mi):
    Character Tools and Workflow Dec 30, 2007
    In this segment, you will learn how to pose Houdini's default Toon character asset. You will learn how to work with the character controls and alos how to use Channel Groups and the Channel List to help with the posing. This segment will alos take a quik look at some Houdini 9.1 enhancements that support this workflow.
    Download Video - 80MB [20 Min.]
    Fuente original:
    Character Tools and Workflow - Side Effects Software Inc.
    Miniaturas adjuntadas Miniaturas adjuntadas Videotutoriales y mas para Houdini-character_main.png
    Victor Navone
    Chuck Jones
    John Lasseter
  3. #93
    Zaragoza (ESPAÑA)
    ME ESTOY QUEDANDO DE PIEDRA!
  4. #94
    Zaragoza (ESPAÑA)
    Otro banquete apetitoso:
    FUNDAMENTALS OF RIGID BODY DYNAMICS IN HOUDINI:
    Digital-Tutors :: Houdini :: Fundamentals of Rigid Body Dynamics in Houdini
  5. #95
    Gracias Leander, no te había leído, pongo los free tutorials para que estén a la mano
    Houdini : Creating a Ripple Simulation in Houdini
    In this lesson we will learn how to build a ripple solver dynamics network.
    Houdini : Activating and deactivating rigid bodies in Houdini
    In this lesson we will learn how to make a rigid body dynamic object behave like a static one. Lesson 2 of 32 from Fundamentals of Rigid Body Dynamics in...
    Houdini : Bounce parameters in Houdini
    In this lesson we will learn about tweaquíng bounce physical properties of RBD objects. Lesson 7 of 32 from Fundamentals of Rigid Body Dynamics in...
    Victor Navone
    Chuck Jones
    John Lasseter
  6. #96
    Tutorial sobre dinamicas
    Avalanche Previsualization
    Published: April 4, 2008 for Houdini 9.1
    In this video series, learn how to create a simple dynamic simulation by creating a procedural pre-vis avalanche.
    Scene File:
    avalanche.zip
    1. Avalanche Previsualization: Part 1 [62MB QT - 16 Mins.]
    In this tutorial you will set up a basic avalanche using Houdini's Rigid Body Dynamics.
    2. Avalanche Previsualization: Part 2 [84MB QT - 17 Mins.]
    Expanding upon the last tutorial, particles will be integrated into the simulation to add complexity and realism.
    Victor Navone
    Chuck Jones
    John Lasseter
  7. #97
    Senior Member Avatar de pyros
    Vancouver, Canadá
    Muchas gracias por este hilo! Estoy aprendiendo houdini y estos tutoriales me vienen realmente de perlas! intentaré aportar lo posible (cuando pueda!)
  8. #98
    Genial, ya veremos el producto de ese aprendizaje, ánimo
    Victor Navone
    Chuck Jones
    John Lasseter
  9. #99
    Transfiriendo color con dinamicas
    Published: April 8, 2008 for Houdini 9.1
    This 7 part series about how to transfer color using dynamics is a great place to start to understand Houdini's dynamics in a significant way.
    Download Scene Files - dynamics_painting.zip
    1. Painting Setup - [11MB QT - 3.5 Mins.]
    2. Establishing a Paint Source - [23MB QT - 10 Mins.]
    3. Creating Paint - [27MB QT - 11.5 Mins.]
    4. Defining Paint Colors With a Solver - [33MB QT - 17 Mins.]
    5. Painting With Dynamics - [19MB QT - 8.5 Mins.]
    6. Review: How It Works - [27MB QT - 12 Mins.]
    7. Setting Up For Render Output - [45MB QT - 21 Mins.]
    Victor Navone
    Chuck Jones
    John Lasseter
  10. #100
    Creando un "Gas Solver"
    Published: April 25, 2008 for Houdini 9.1
    Esta serie de cinco capítulos va sobre como crear un simple "gas solver" con dinámicas desde cero:
    Download Scene Files - simple_gas_solver.zip
    1. Initial Setup - [15MB QT - 7 Mins.]
    2. Creating Noise Fields - [14MB QT - 7 Mins.]
    3. Initial Dynamics Setup - [61MB QT - 24 Mins.]
    4. Gas Advect - [59MB QT - 14 Mins.]
    5. Conclusión - [65MB QT - 15 Mins.]
    Última edición por SHAZAM; 27-04-2008 a las 05:59
    Victor Navone
    Chuck Jones
    John Lasseter
  11. #101
    Implementing Spectral Colors in Mantra
    Published: May 2, 2008 for Houdini 9.1
    Watch shader writer, Mario Marengo, explain spectral wavelength and how to utilize it within Houdini. This presentation was recorded at a Toronto Technical Evening hosted by Side Effects Software.
    Watch Mario's Presentation - [137MB QT - 58 Mins.]
    Download PowerPoint File - spectral_colours.zip
    Orienting Objects to a Curve
    This tutorial teaches how to sweep an object along a curve while orienting the object to the curve's direction.
    Download Scene Files - sweep_orient_to_curve.zip
    Sweep Orient to Curve - [55MB QT - 13 Mins.]
    Victor Navone
    Chuck Jones
    John Lasseter
  12. #102
    Victor Navone
    Chuck Jones
    John Lasseter
  13. #103
    Gracias por la información...te lo has currao.
    Pero mirar todo eso lleva un tiempo desde luego.
  14. #104
    Victor Navone
    Chuck Jones
    John Lasseter
  15. #105
    Ray Normals
    Published: June 2, 2008 for Houdini 9.1
    Aprende como manipular normales sin utilizar expresiones en esta serie de dos partes
    Download scene files [9KB]
    Ray Normals Part 1 - [38MB QT - 7 Mins.]
    Ray Normals Part 2 - [78MB QT - 11 Mins.]
    Fuente original:
    Ray Normals - Side Effects Software Inc.
    Miniaturas adjuntadas Miniaturas adjuntadas Videotutoriales y mas para Houdini-ray_normals_main.jpg
    Victor Navone
    Chuck Jones
    John Lasseter
  1. Videotutoriales y mas para 3ds Max
    Por SHAZAM en el foro Tutoriales, Libros y Manuales
    Respuestas: 39
    Último mensaje: 23-08-2011, 21:02
  2. LightWave Videotutoriales para Lightwave
    Respuestas: 81
    Último mensaje: 03-05-2009, 17:23
  3. Videotutoriales y mas para Hexagon
    Último mensaje: 06-12-2008, 19:07
  4. Videotutoriales para poser 6
    Por MecklyBver en el foro Peticiones y Búsquedas
    Respuestas: 24
    Último mensaje: 26-06-2005, 22:31
