Página 17 de 20 PrimerPrimer ... 71314151617181920 ÚltimoÚltimo
Resultados 241 al 255 de 286
Tema: Blender hoy Videos de Pablo Vázquez para blenderitas hispano hablantes
  1. #241
    Torrevieja-Alicante
    MASIVAS NOVEDADES - Blender Hoy LIVE #186
    https://www.youtube.com/watch?v=wMLGFvoVXME
    Blender 3.1.2! https://twitter.com/Blender/status/15...
    The place https://www.reddit.com/r/place/?cx=31...
    CORE
    Apply Object Transform: Multi-user data support https://developer.blender.org/D14377
    Modifiers: Support applying modifiers for multi-user data https://developer.blender.org/D14381
    CYCLES
    Cycles: Add support for light groups https://developer.blender.org/rBad354...
    Cycles: approximate shadow caustics using manifold next event estimation https://developer.blender.org/rB1fb02...
    Cycles: Optimize Nishita sky https://developer.blender.org/rB633c8...
    VSE
    VSE: Add channel headers https://developer.blender.org/rB277fa...
    VSE: Use edge panning https://developer.blender.org/rBe49fe...
    GREASE PENCIL
    GPencil: Fading for build modifier https://developer.blender.org/D14309
    GEOMETRY NODES
    Geometry Nodes: Don't create node tree when adding nodes modifier https://developer.blender.org/rB08b4b...
    Geometry Nodes: Remove soft min from extrude node scale https://developer.blender.org/rB4a93c...
    Curves: Port resample node to the new data-block https://developer.blender.org/rB60a6f...
    Geometry Nodes: Add search to named attribute input node https://developer.blender.org/D14516
    NODES
    Fix: Nodes: Remove hidden links when creating node groups https://developer.blender.org/D14249
    UI
    UI: Fix cosmetic papercuts of the reroute node https://developer.blender.org/rBee1d5...
    UI: Improve node editor dot background https://developer.blender.org/D13302
    Add soft limit for Bevel segments in modifier. https://developer.blender.org/D14477
    ASSET BROWSER
    Assets: Support automatic collection previews https://developer.blender.org/rB810e2...
    Assets: Enable collection assets (no longer experimental) https://developer.blender.org/rB253e4...
    Assets: Instancing operator option for collection asset dropping https://developer.blender.org/D14507
    CURVES
    Curves: Curve Pen https://developer.blender.org/rB33608...
    Curves: improve Snake Hook brush https://developer.blender.org/D14408
    Curves: support converting curves to legacy hair system https://developer.blender.org/D14441
    LIBRARY OVERRIDES
    LibOverride: Implement default 'user override' behavior https://developer.blender.org/rB6cc9b...
    LibOverride: Add a new 'virtual' non-editable override icon and use it in Outliner https://developer.blender.org/rB9394d...
    LibOverride: Rename 'delete hierarchy' to 'clear hierarchy', add 'clear single' operations. https://developer.blender.org/rB354db...
    Outliner: Don't show indirectly linked Library Overrides properties https://developer.blender.org/rB8b529...
    Outliner: New "Hierarchies" view mode for Library Overrides https://developer.blender.org/D14440
    KEYMAP
    Keymap: "Mouse Select & Move" now uses click to de-select others https://developer.blender.org/rB24997...
    I/O
    OBJ: New C++ based wavefront OBJ importer https://developer.blender.org/rBe6a9b...
    ADD-ONS
    Many glTF improvements https://wiki.blender.org/wiki/Referen...
    FIXES
    Fix long hangs when launching Blender with disconnected network shares https://developer.blender.org/D14506
    Fix offset in icons https://developer.blender.org/rB49858...
    EXPERIMENTAL
    OBJ: mark the new 3.1+ exporter as experimental for now https://developer.blender.org/rBca28f...
    UserDef: Add experimental flag for 3d texturing brush. https://developer.blender.org/rB3ce6c...
    No se pierdan este vídeo, trae novedades importantes.... entre ellas, una sobre las CAUSTICAS.
    Minuto 20 mas o menos.
    Sin cáusticas... con cáusticas
    Última edición por Soliman; 05-04-2022 a las 12:20
  2. #242
    28.10º N 15.43º W in a blue planet of Solar System
    GEOMETRY NODES PARA CURVAS: EXPLICADO
    https://www.youtube.com/watch?v=xIHudjoH8Ow
    00:00 Intro
    01:31 Arc Primitive
    04:22 Bezier Segment
    04:53 Curve Circle
    05:02 Curve Line
    05:28 Curve Length
    06:31 Curve to Mesh
    07:36 Profile Curve
    08:06 Curve to Points
    09:42 Set Point Radius
    10:19 Fill Curve
    11:12 Fillet Curve
    11:20 Star
    12:24 Resample Curve
    13:53 Reverse Curve
    14:28 Sample Curve
    15:22 Subdivide Curve
    15:37 Instance on Points
    17:01 Trim Curve
    18:42 Curve Handle Positions
    19:16 Curve Tangent
    21:03 Curve Tilt
    22:12 End Point Selection
    24:16 Handle Type Selection
    25:21 Is Spline Cyclic
    25:54 Set Spline Cyclic
    26:28 Spline Length
    28:10 Spline Parameter
    28:25 Set Curve Radius
    30:05 Set Curve Tilt
    30:12 Set Handle Positions
    30:28 Set Handle Type
    30:44 Set Spline Resolution
    30:56 Set Spline Type
    Manual con todos los nodos (inglés) https://docs.blender.org/manual/en/l...rve/index.html
    Victor Navone
    Chuck Jones
    John Lasseter
  3. #243
    RETO BAJO EL AGUA - Blender Hoy LIVE #187
    https://www.youtube.com/watch?v=TDUe0V4Hlv8
    Victor Navone
    Chuck Jones
    John Lasseter
  4. #244
    NUEVO VERTEX PAINT - Blender Hoy LIVE #188
    https://www.youtube.com/watch?v=u5jC83iVtqQ
    BCON22 - https://twitter.com/BlenderConf/statu...
    Webby Awards - https://vote.webbyawards.com/PublicVo...
    NEW VERTEX COLORS
    Unify vertex and sculpt colors into new color attribute system https://developer.blender.org/rBeae36b
    POTPOURRI
    Fix: T78228 Send all python errors to info editor https://developer.blender.org/rB2d2bae
    Preferences: enable Duplicate Data for curves and point cloud objects https://developer.blender.org/rBe40b0d
    Fix setting key shortcuts for insert keyframe menu items https://developer.blender.org/rBcda333
    Fix T97098: Color filter sharpening artifacts. https://developer.blender.org/rBd683ea
    Fix T96824: New 3.1 OBJ exporter writes incorrect polygon/vertex groups in some cases https://developer.blender.org/rBb32cb0
    Fix T97002: Preserve multi socket link order https://developer.blender.org/D14535
    UI
    UI: Add support for showing socket descriptions in tooltips https://developer.blender.org/rB484a91
    UDIM: Move UDIM grid controls to the Overlay panel https://developer.blender.org/rB92c89d
    Curves: Hair to Curves rename in Cycles/EEVEE UI https://developer.blender.org/rB8b0430
    BLF: sub-pixel positioning support https://developer.blender.org/rBae4387
    Gizmos: enable gizmos for the action space https://developer.blender.org/D13999
    Render: Add operators to add all used or remove all unused lightgroups https://developer.blender.org/rB2e77a8
    ANIMATION
    Animation: Select markers before/after current frame https://developer.blender.org/rBf1ae69
    Animation: Add F2 for renaming markers https://developer.blender.org/rBd6e724
    NLA: Keyframe Remap Through Upper Strips https://developer.blender.org/rB3acbe2
    Object: Set Parent (Keep Transform Without Inverse) https://developer.blender.org/D14581
    GEOMETRY NODES
    Curves: initial geometry nodes support for curves objects https://developer.blender.org/D14277
    Curves: Port tangent and normal calculation to the new data-block https://developer.blender.org/rBceed37
    Curves: Port curve to mesh node to the new data-block https://developer.blender.org/rB7484f2
    Geometry Nodes: show used named attributes in nodes https://developer.blender.org/D14618
    Geometry Nodes: Add "Connected" mode to Merge by Distance node https://developer.blender.org/rB81ec3d
    Geometry Nodes: Parallelize mesh line node https://developer.blender.org/rB8f344b
    Curves: Add support for new curves type in Set Material node https://developer.blender.org/rBc4f7f5
    GREASE PENCIL
    GPencil: Add skip option to envelope modifier https://developer.blender.org/D14503
    CYCLES
    Cycles: Support adding Lightgroups from the object/world properties https://developer.blender.org/rB321402
    Fix T97159: AOV Pass in Cycles always gets Alpha Value of 1 for whole image https://developer.blender.org/rB0b05e0
    Revert "Cycles: enable HIP for Vega and Vega II (Radeon 7) GPUs on Windows" https://developer.blender.org/rB2d472b
    CURVES
    Curves: improve Add menu for new curves object https://developer.blender.org/D14556
    Curves: new Grow/Shrink brush https://developer.blender.org/D14474
    Curves: operator to snap curves to surface https://developer.blender.org/rB50869b
    Curves: expose convert to particle system operator in sculpt mode https://developer.blender.org/rB30f9eb
    Curves: Port legacy curve viewport drawing to the new data-block https://developer.blender.org/rBb84255
    PAINT
    Painting: Canvas switcher for painting brushes/tools. https://developer.blender.org/rB8b7cd1
    PERFORMANCE
    PBVH Pixel extractor. https://developer.blender.org/rBe96a80
    Edit Mesh: Parallelize bounds calculation with deform modifiers https://developer.blender.org/rB0ba061
    Functions: parallelize materializing arrays after field evaluation https://developer.blender.org/rB2aff04
    Functions: optimize simple generated multi-functions https://developer.blender.org/rB67c42e
    OBJ: further optimize, cleanup and harden the new C++ importer https://developer.blender.org/rB213cd3
    KEYMAP
    Keymap: restore key-shortcut to remove from local-view https://developer.blender.org/rBf07649
    PYTHON API
    Text Editor: Get/Set region text API https://developer.blender.org/rBf49a73
    ADD-ONS
    FBX Export: Add Limit To Visible Objects checkbox to match GLTF export https://developer.blender.org/rBA4075c
    Collection Manager: Add QCD widget preference https://developer.blender.org/rBAa65df
    WM: avoid unnecessary undo step creation when duplicating https://developer.blender.org/rBd00de9
    Victor Navone
    Chuck Jones
    John Lasseter
  5. #245
    BAKE PARA UDIMs - Blender Hoy LIVE #189
    https://www.youtube.com/watch?v=4khMIEOUjck
    BAKE
    Bake: add UDIM Tile baking support https://developer.blender.org/rB6787c...
    CYCLES
    Cycles: enable AMD RDNA GPU support on Linux https://developer.blender.org/rB17910...
    Cycles: removed UV requirement for MNEE, along with fixes and cleanups https://developer.blender.org/rB58be9...
    Mikktspace: Reduce number of data queries to caller https://developer.blender.org/rBc486d...
    GEOMETRY NODES
    Geometry Nodes: show used named attributes in modifier https://developer.blender.org/rB0178e...
    Geometry Nodes: Better support for byte colors https://developer.blender.org/D14705
    VSE
    VSE: Add frame selected operator for preview https://developer.blender.org/rBe16ff...
    VSE: Update first thumbnail when moving handle https://developer.blender.org/rB29b91...
    PAINT
    UI: Add option to create color attribute directly from canvas selector. https://developer.blender.org/rB56d1d...
    Commit D14179: Revamp Vertex Paint With C++ https://developer.blender.org/rB575ad...
    Curves: Show sculpt tool settings in panels. https://developer.blender.org/D14700
    Color Management: add ACEScg to the default configuration https://developer.blender.org/rBf991f...
    ADD-ONS
    Magic UV: Release v6.6 https://developer.blender.org/rBA2cbb...
    Rigify UI changes https://developer.blender.org/D11352
    Fix T97458: Snap_Utilities_Line rotate navigation not working https://developer.blender.org/rBA1ca9...
    Change Vertex Colors panel to Attributes in Node Wrangler https://developer.blender.org/D14668
    glTF Exporter
    PYTHON
    PyAPI: temporary context override support https://developer.blender.org/rBf4383...
    Text Editor: add Python 3.10 soft keywords to `builtinfunc` list https://developer.blender.org/rBc6ed8...
    BUILD
    Build: upgrade many library dependencies to new versions for Blender 3.2 https://developer.blender.org/rBb9c37...
    SHOUTOUTS
    Fix T97497: NLA strip names are now properly contained within the strip bounds https://developer.blender.org/rB2882c...
    Fix - Display correct units in "Edit voxel size" widget https://developer.blender.org/rBb2262...
    https://developer.blender.org/D14694
    NLA: Add Bake Action to the NLA edit menu https://developer.blender.org/rBc63d6...
    Fix T96925: Fast diagonal movement in walk navigation https://developer.blender.org/rB0a86a...
    Victor Navone
    Chuck Jones
    John Lasseter
  6. Gracias 3dpoder Agradece este post
  7. #246
    BLENDER 3.3 ALPHA - Blender Hoy LIVE #190
    https://www.youtube.com/watch?v=OsDY4zH29QM
    Blender 3.2 goes Beta! https://twitter.com/Blender/status/15...
    Artwork by Oksana Dobrovolska https://dabrosha.artstation.com/proje...
    VSE
    VSE: Add precise drag and drop and strip previews https://developer.blender.org/D14560
    VSE: Add option to limit timeline view height https://developer.blender.org/D14263
    GEOMETRY NODES
    Geometry Nodes: Add "Named" to "Remove Attribute" node name https://developer.blender.org/rB2fd8f...
    Geometry Nodes: rename used attributes panel https://developer.blender.org/rB9a535...
    Geometry Nodes: Move named attribute nodes out of experimental https://developer.blender.org/rB3e7ee...
    Geometry Nodes: Add default attribute name to field inputs/outputs https://developer.blender.org/rB0ad73...
    Geometry Nodes: refactor array devirtualization https://developer.blender.org/rBae94e...
    Curves: Support applying geometry nodes modifier https://developer.blender.org/rB96bdd...
    Curves: support spherical delete brush https://developer.blender.org/D14797
    UI
    UI: Improvements to "Add Color Attribute" menu https://developer.blender.org/D14785
    Color Attributes: Add initial fill color option https://developer.blender.org/rB3d5f5...
    UI: Fix consistency issues with tooltips and icons https://developer.blender.org/D14768
    Shortcuts don't appear on tooltips for tool icons. https://developer.blender.org/T62945
    Animation: Sensible frame range for motion paths https://developer.blender.org/rB4e57b...
    T95386: Add Discontinuity (Euler) filter to Dope Sheet. https://developer.blender.org/rB7fd11...
    PAINT
    Use saturation as multiplier for saturation filter https://developer.blender.org/D14808
    OUTLINER
    Outliner: Add icon column to toggle if library overrides are editable https://developer.blender.org/rB994da...
    GREASE PENCIL
    GPencil: New Sculpt Auto masking options https://developer.blender.org/rBab5d5...
    GPencil: Fix offset modifier performance regression https://developer.blender.org/rB16fe7...
    VR
    XR: Add object extras, object types visibility session options https://developer.blender.org/D14220
    Victor Navone
    Chuck Jones
    John Lasseter
  8. Gracias 3dpoder Agradece este post
  9. #247
    MEJORAS PARA PELO! - Blender Hoy LIVE #191
    https://www.youtube.com/watch?v=RAb2FiMvl54
    NODES
    Nodes: Add general Combine/Separate Color nodes https://developer.blender.org/rB82df4...
    Geometry Nodes: Improve performance of mesh to points node https://developer.blender.org/D14661
    UI
    UI: Add Gizmos toggle to SpaceImage https://developer.blender.org/rBed096...
    UI: Expand the Snap Curves to Surface operator https://developer.blender.org/D14873
    Outliner: add icons for nodegroups https://developer.blender.org/rBb968e...
    ANIMATION & RIGGING
    NLA: improve visibility of action & active channel https://developer.blender.org/D14820
    Allow surface deform when target mesh increases number of vertices https://developer.blender.org/rB5f8f4...
    Fix T97529: NLA track buttons still work when hidden https://developer.blender.org/rB4ac61...
    CURVES
    Curves: support symmetry in curves sculpting brushes https://developer.blender.org/D14795
    Curves: add second experimental option for new curves tools https://developer.blender.org/D14840
    Curves: control number of control points in new curves https://developer.blender.org/D14857
    Curves: show warning when using Add brush without surface https://developer.blender.org/rB18bcd...
    Curves: move curve sculpt settings out of advanced panel https://developer.blender.org/rB5b242...
    Curves: use old Add - Curve menu for new curves object https://developer.blender.org/D14861
    Curves: disable Empty Hair operator when there is no active mesh https://developer.blender.org/rB2ba08...
    Curves: support converting legacy curves to new curves object https://developer.blender.org/D14872
    PAINT & UV
    Transform: use a threshold for UV snapping https://developer.blender.org/D13873
    UI: Add color attribute create to canvas selector https://developer.blender.org/rBb96cd...
    Switch viewport shading for color tools in solid mode https://developer.blender.org/rB90042...
    GREASE PENCIL
    GPencil: New option to make noise random in Keyframes only https://developer.blender.org/D14566
    LineArt: Object loading optimization https://developer.blender.org/rB03aba...
    WINDOWS
    Win32: Dark Mode Title Bar Color https://developer.blender.org/D14847
    GHOST: Add support for precision touchpad gestures on Windows https://developer.blender.org/rBe58b1...
    POTPOURRI
    IMBUF: Faster JPEG Thumbnails https://developer.blender.org/D14727
    XR: Expose the OpenXR user paths in the event data for XR events https://developer.blender.org/rB23be3...
    I/O & ADD-ONS
    USD: add volume/VDB export https://developer.blender.org/D14193
    Alembic: Enable operator presets when exporting https://developer.blender.org/rB1d668...
    Amaranth: Support Image preview on Geometry Nodes https://developer.blender.org/rBA67e4...
    Victor Navone
    Chuck Jones
    John Lasseter
  10. Gracias Soliman Agradece este post
  11. #248
    POPURRÍ DE NOTICIAS - Blender Hoy LIVE #192
    https://www.youtube.com/watch?v=dtmpmV7bpHY
    Qué hay de nuevo:
    CURVES
    Curves: Interpolate point count in add brush https://developer.blender.org/rB88521...
    Curves: Adjust sculpt mode UI layouts https://developer.blender.org/D14922
    Curves: add operator to convert hair particle system to new curves https://developer.blender.org/rB94a54...
    GEOMETRY NODES
    UI: Geometry Nodes Icon https://developer.blender.org/rB28240...
    https://code.blender.org/2022/05/geom...
    MODELING
    Mesh: Add Auto Smooth option to Shade Smooth operator https://developer.blender.org/rBeef98...
    UV
    UDIM: Add support for packing inside .blend files https://developer.blender.org/rB57877...
    3D Texturing: Undo https://developer.blender.org/rB00eb7...
    UI
    DrawManager: Hide lock acquire behind experimental feature https://developer.blender.org/rB15021...
    OUTLINER
    Outliner: Remove 'rename library' feature https://developer.blender.org/rB2d9a6...
    Outliner: Remove the 'Remap data-block usages' operation https://developer.blender.org/rB30534...
    PERFORMANCE
    OBJ: improve new importer file parsing performance on windows https://developer.blender.org/rB9757b...
    FIXES
    Fix: Cycles blocky caustics with rough glass https://developer.blender.org/T97867
    Color Management: various improvements and fixes for image saving https://developer.blender.org/rB5baa3...
    Fix T97386: Node socket labels swallow click/drag events https://developer.blender.org/rB05b56...
    MacOS/AMD: Drawing artifacts in VSE https://developer.blender.org/rBcbc02...
    Victor Navone
    Chuck Jones
    John Lasseter
  12. #249
    ¡GSoC 2022! - Blender Hoy LIVE #193
    https://youtu.be/4_T3Prt4uKk
    Qué hay de nuevo:
    Blender is now part of the list of recommended Free Software for French public agents https://twitter.com/codegouvfr/status...
    Google Summer of Code 2022 https://code.blender.org/2022/05/blen...
    High priority bugs: https://pasteall.org/media/7/3/73f80f...
    VSE
    VSE: New Change Scene option in Change menu https://developer.blender.org/rB205c6...
    VSE: Add new Scene and Strip https://developer.blender.org/rBbe84f...
    VSE: Delete Strip and Scene Data in one step https://developer.blender.org/D14794
    VSE: Display sound sample rate and channels https://developer.blender.org/rB89106...
    UI
    Revert "Outliner: Remove the 'Remap data-block usages' operation." https://developer.blender.org/rB8c980...
    UI: rename Hue/Saturation node to Hue Saturation Value in shaders and textures https://developer.blender.org/rB9b082...
    GREASE PENCIL
    GPencil: A Ping Pong effect to Time modifier https://developer.blender.org/rB82d72...
    CURVES
    Curves: Support pressure in sculpt brushes https://developer.blender.org/rBcea37...
    OVERRIDES
    LibOverride: Do not write MeshDeform, Corrective Smooth, Surface Deform, Laplacian Deform, modifier binding data. https://developer.blender.org/rBb6636...
    IMBUF: Thumbnails of all EXR files using less RAM https://developer.blender.org/rBf600a...
    PYTHON
    Python API: add mathutils.Color functions to convert color spaces https://developer.blender.org/rB469ee...
    Python API: make Image.save and Image.save_render more consistent with operator https://developer.blender.org/rB29a3f...
    EEVEE NEXT
    EEVEE-Next: Add Velocity module https://developer.blender.org/rB0fcfc...
    EEVEE-Next: Display error instead of crashing on unsupported hardware https://developer.blender.org/rBf4028...
    Victor Navone
    Chuck Jones
    John Lasseter
  13. #250
    Reto: Haiku - Blender Hoy LIVE #194
    La próxima semana sale... ¡Blender 3.2!
    https://youtu.be/51m8mh9mwhg
    VSE
    UI
    GREASE PENCIL
    CURVES
    OVERRIDES
    PYTHON
    EEVEE NEXT
    Victor Navone
    Chuck Jones
    John Lasseter
  14. Gracias 3dpoder Agradece este post
  15. #251
    Fiesta Lanzamiento BLENDER 3.2 🎉 Blender Hoy LIVE #195
    https://youtu.be/TubAG0u7DBI
    Victor Navone
    Chuck Jones
    John Lasseter
  16. #252
    ¡De regreso de Annecy! - Blender Hoy LIVE #196
    https://youtu.be/9WQ8-8ZWbSo
    Victor Navone
    Chuck Jones
    John Lasseter
  17. #253
    ¡SCROLLBARS! - Blender Hoy LIVE #197
    https://youtu.be/Q-gsel9rPVc
    Blender 3.2.1 release this week
    UI
    * UI: Scrollbar Behavior Changes https://developer.blender.org/rB624397
    UV
    * UV: Add "Select Similar" operator in UV editor https://developer.blender.org/D15164
    PAINT
    * Voxel Remesh Size Edit - Constant Size by default https://developer.blender.org/rB5946ea
    * Tip roundness - match square and round brush radius https://developer.blender.org/rBb6a762
    ANIMATION
    * Dopesheet: Add Custom Properties panel https://developer.blender.org/D14646
    * Armature: Add poll message explaining bone groups need pose mode https://developer.blender.org/rB2ae439
    * Animation: Add function to remove all FCurves from an Action https://developer.blender.org/rB091100
    CLIP EDITOR
    * Mask Editor: Add mask blending factor for combined overlay https://developer.blender.org/rBeca0c9
    * Mask Editor: Add toggle for mask spline drawing https://developer.blender.org/rBdf2ab4
    * Spreadsheet: Support operations for filtering colors https://developer.blender.org/D15191
    * Geometry Nodes: Add Points Node https://developer.blender.org/D13920
    * Geometry Nodes: Field on Domain Node https://developer.blender.org/D15289
    * Geometry Nodes: Speed up Separate color node in RGB mode https://developer.blender.org/rB047346
    PYTHON
    * PyAPI: PyAPI: Expose event.type_prev, value_prev https://developer.blender.org/rB2580d2
    ADDONS
    * Node Wrangler: create world output if the node tree is of type world https://developer.blender.org/rBAebe0b
    * glTF exporter: Export DEF bones only, without animation, is now possible https://developer.blender.org/rBA807a6
    * glTF exporter: Allow custom name for merged animation https://developer.blender.org/rBA501c9
    LINUX/WAYLAND
    * More Wayland support
    * https://developer.blender.org/rB29755e
    * GHOST/Wayland: support for cursor warp with hidden/wrapped grab enabled https://developer.blender.org/rB3323cd
    EXCITEMENT
    * Cleanup: removed unused Blender Internal bump/normal mapping texture code https://developer.blender.org/rB9622da
    Victor Navone
    Chuck Jones
    John Lasseter
  18. #254
    ¡NODOS DE UV! - Blender Hoy LIVE #198
    https://youtu.be/DWm2LjORb4c
    Blender Conference ticket sale! https://conference.blender.org/2022/
    Blender 3.2.1 release this week, for real https://wiki.blender.org/wiki/Referen...
    WHAT'S NEW
    GEOMETRY NODES
    * Geometry Nodes: Add Mesh To Volume Node https://developer.blender.org/rB1516f7
    * Geometry Nodes: UV Unwrap and Pack Islands Nodes https://developer.blender.org/rB4593fb
    * https://twitter.com/amalbubble/status...
    MODELING
    * UV: Improve UV Straighten operator https://developer.blender.org/rB9dd27a
    * Transform Snap: nearest face snap mode, snapping options, refactoring https://developer.blender.org/rB011327
    GREASE PENCIL / LINE ART
    * LineArt: Shadow and related functionalities https://developer.blender.org/rB6dd8ce
    MOTION TRACKING
    * Tracking: Image from Plane Marker operators https://developer.blender.org/rBe4bf58
    * Mask editor: Always use smooth drawing https://developer.blender.org/rBc1ffea
    CYCLES
    * Cycles: Add support for rendering on Intel GPUs using oneAPI https://developer.blender.org/rBa02992
    * Cycles: enable Vega GPU/APU support https://developer.blender.org/rBabfa09
    USER INTERFACE
    * UI: add Custom properties panel to collections https://developer.blender.org/rBb91011
    * UI: add tooltips for nodes to the shader node add menu https://developer.blender.org/D15309
    VSE
    * VSE: Improved Retiming system https://developer.blender.org/rB302b04
    * FFmpeg: Add VFR media support https://developer.blender.org/rBf0a3d2
    CURVES
    * Curves: New tools for curves sculpt mode https://developer.blender.org/rB416aef
    * Sculpt Curves: UI tweaks and shortcut https://developer.blender.org/rB3ffc55
    I/O
    * COLLADA: Support for alpha color in vertex data https://developer.blender.org/rB106d93
    * IO: print import & export times of Alembic & USD https://developer.blender.org/rBe7a212
    POTPOURRI
    * Benchmark: Add EEVEE viewport playback tests https://developer.blender.org/rB66f826
    Victor Navone
    Chuck Jones
    John Lasseter
  19. Gracias 3dpoder Agradece este post
  20. #255
    ¡MEJORAS EN WORKSPACES! - Blender Hoy LIVE #199
    https://youtu.be/cKIu3QBXAJg
    USER INTERFACE
    * Workspaces: Option to pin scene to a workspace https://developer.blender.org/rBe0cc86
    * UI: Superimposed pin icon for workspace scene pinning in the scene switcher https://developer.blender.org/D11890
    CURVES
    * Hair Curves: The new curves object is now available https://developer.blender.org/rBbecb15
    * Curves: support deforming curves on surface https://developer.blender.org/D14864
    * Curves: Add sculpt selection overlay https://developer.blender.org/D15219
    * Draw: Curve outline drawing in object mode https://developer.blender.org/rBa8f7d4
    * Curves: Port subdivide node to the new data-block https://developer.blender.org/rB9435ee
    RIGGING
    * Weight & Vertex Paint: always respect edit mode hiding on faces https://developer.blender.org/rBe3801a
    OUTLINER
    * Outliner, Library Overrides: List child objects under parents https://developer.blender.org/D15339
    * ID Management: Purge: Make outliner button use recursive purge https://developer.blender.org/rBa27024
    COMPOSITOR
    * Compositor: Pre-fill active scene movie clip in more nodes https://developer.blender.org/rBda8524
    * Compositor: Pre-fill motion tracking fields https://developer.blender.org/rBc76e1e
    PERFORMANCE
    * Object: Speed up duplication of large selections by doing fewer collection syncs https://developer.blender.org/rB2d041f
    CYCLES
    * Cycles: enable oneAPI in Linux release builds https://developer.blender.org/rB0f50ae
    * Curves: use consistent default radius for Cycles, Eevee, Set Curve Radius node https://developer.blender.org/rB8159e0
    I/O
    * IO: speed up import of large Alembic/USD/OBJ scenes by optimizing material assignment https://developer.blender.org/rB94323b
    * OBJ: remove "experimental" from C++ based importer/exporter, mark Python legacy https://developer.blender.org/rB8fb8a6
    ADD-ONS
    * Rigify: make uniform limb scaling optional and hide the constraint https://developer.blender.org/rBA7ea2e
    * Fix T99335: Rigify horse has wrong parents https://developer.blender.org/rBAe5d87
    * Node Wrangler: expose Custom Color property in the Frame Selected operator https://developer.blender.org/D15320
    * glTF exporter: export all actions of a single armature is now under an export option https://developer.blender.org/rBA09d75
    * glTF importer/exporter: Manage some official Khronos Extensions about Materials https://developer.blender.org/rBA042fb
    * AnimAll, and Sun Position: add French translation https://developer.blender.org/rBA7faf9
    PYTHON
    * Python: support v3.11 (beta) https://developer.blender.org/rB780c0e
    * PyAPI: add Matrix.is_identity read-only attribute https://developer.blender.org/rB133d39
    POTPOURRI
    * BLF: Add Support for Variable Fonts https://developer.blender.org/D12977
    * GHOST/Wayland: support dynamic loading libraries for Wayland https://developer.blender.org/rBe58e02
    FIXES
    * Fix T99386: Driven modifiers are always re-evaluated during animation https://developer.blender.org/rBeb7218
    Victor Navone
    Chuck Jones
    John Lasseter
  1. Blender Nueva comunidad de Blender python para hispano hablantes
    Por ofuscado en el foro Programación y Scripts
    : 15-01-2013, 01:44
  2. Blueprint hispano suiza
    Por Ares-esp en el foro Blueprints Coches
    : 08-03-2011, 01:19
  3. Una pequeña lección sobre el maestro Vázquez
    Por FRANK SOLO en el foro Ilustración y 2D
    : 07-05-2010, 20:55
  4. Cine y series Muere Jose Luis López vazquez
    Por Klópes en el foro Cine
    : 02-11-2009, 21:07
  5. Videos de Blender org
    Por tonilogar en el foro Infografía General
    : 01-03-2007, 19:26
