Página 2 de 5 PrimerPrimer 12345 ÚltimoÚltimo
Resultados 16 al 30 de 62
Tema: Maya 8 y 3DS Max 9
  1. #16
    manumanolololomanuel
    Jun 2003
    Ciutat d´Elx
    Re: Maya 8 y 3DS Max 9
    Y cuando recibiremos el max9? yo ya estoy aquí en la empresa comiendome las uñicas después de ver el mental ray en accion, es la polla con cebolla!
    Poderoso el frikismo en mi es
  2. #17
    Jijiji, como se nota que el Siggraph esta cerca
    Victor Navone
    Chuck Jones
    John Lasseter
  3. #18
    Senior Member Avatar de Gagui
    Aug 2003
    La Coruña
    Shazam el Siggraph ya ha llegado. Comenzó el 31 de Julio y acabara el 8 de agosto.
    PORTFOLIO
    www.gaell.com
    gaell@gaell.com
  4. #19
    Cita Iniciado por Gagui
    Si, a eso me refiero
    Victor Navone
    Chuck Jones
    John Lasseter
  5. #20
    Aug 2005
    Create breathtaquíng 3D content with Autodesk® Maya® 8 software. With Maya 8, Autodesk demonstrates its commitment to meeting the demands of next-generation productions. The new release addresses the fundamental challenges Maya customers are facing today–and those they expect to face in the future.
    Achieve more with the feature-packed Autodesk Maya 8. For full product details, please refer to the detailed features.
    Key New Features & Enhancements
    64-bit Release (Windows and Linux platforms)
    Maya 8 marks the first full release of Maya with both 32-bit and 64-bit (Windows® and Linux®) executables. It allows you to address considerably more memory than you could in the past, enabling you to handle larger and more complex scenes than ever before.
    Performance
    Maya 8 has been optimized to provide superior performance across many áreas of the software, both through algorithmic speedups and scalable multi-threading to take advantage of the latest generation of workstations.
    Transfer Polygon Attributes
    A new Transfer Polygon Attributes feature allows you to transfer UV, color per vertex (CPV) and vertex position information between surface meshes of differing topologies. This proves particularly useful when working with two different versións of an object/character (e.g., one high resolution and one low resolution). You could then transfer existing UV sets that have already been laid out to the lower resolution model. The feature alos lets you create a “shrink-wrap” effect as they transfer vertex positions from one model to another.
    Streamlined New Polygon Tools and Workflows
    New and improved tools such as polygon bridge, múltiple edge loop replaceion, and enhanced UV layout, and new workflows, such as the ability to interactively create, position, and scale primitives in a single operation, maximize productivity for the most common tasks.
    Geometry Caching
    You can now cache deformations on polygon, NURBS (including curves) and subdivisión surface geometry, allowing for faster playbak and rendering of scenes. Caches can be edited and blended in the Trax Editor, letting you blend the results of various vertex animations together in order to form a new animation: for example, you could correct deformations by remodeling and replacing particular frames and then smoothly blend in and out of the changes.
    Override Viewport with Renderer of Choice
    You now have the option of overriding the Maya viewports with a proprietary or third-party plug-in renderer. This will enable you to review your scene as it will appear in the target renderer–such as a game engine–while maintaining the ability to interact with the scene in the interactive view. Two example Windows® plugins are provided with the Maya Devkit: one for OpenGL® and one for Direct3D® drivers.
    Toxique Interoperability
    New as of Maya 8, information about a Maya scene can be exported to Autodesk® Toxik™ collaboration software thereby greatly improving the workflow between the two packages. A Toxique composition can be generated from within Maya based on the render layers in the scene. The exported compositing graph includes the associated image sequence filenames, Maya blend modes, and specific render settings. Iterative updates on composition elements can be created and passed to the Toxique application, enabling you to collaborate on specific elements without starting over each time. Additionally, múltiple versións of a composition can be kept for comparison and changes can be easily reverted at any time.
    mental ray 3.5 Core
    Maya now uses the mental ray® 3.5 rendering core which has been optimized for superior performance and memory usage.
    Mucha versión y pocos cambios
  6. #21
    tiruri.... Avatar de RavenX
    Valencia
    Cita Iniciado por Ballo
    dios mio eso es un final gather en condiciones! y con previo yujuu!!!
    Pse.... eso ya lo traía XSI hace tiempo...
    jiji.. bueno.. por la cuenta que me trae en aspecto profesional, espero jubilar en el curro Max 7, ya que es el que quieren los "jefes" que usemos... y que sea lo que promete este 9...
    Después ya no.
  7. #22
    Expulsado
    Jun 2006
    soporte 64 bits y 3 mejoras insignificantes para ambos programas... como se pensaba, solo han sacado las versiones estas para ingresar dinero con licencias y actualizaciones.
    Que les den a los de autodesk, panda de bolsilleros... ya podrían haber mejorado de verdad el programa. Nada! que a usar XSI.
  8. #23
    Aprendiz de Blender Avatar de Derbiii
    Valencia
    La historia interminable empieza de nuevo, hilo kilometrico a la vista
    Un saludo.
    MIGÜEB
    Keith Lango:
    Estos son sólo trucos, no reglas. La única regla es la animación: ¿luce bien?
    Sí la respuesta es sí, entonces el truco es bueno. Si no, el truco es malo.
  9. #24
    Granada, España
    jjojojojojo, veo las mejoras de mental ray LEVEMENTE influenciadas por vray
    Al fin glossy interpolado!!!
  10. #25
    Por lo que se ve en el video, el mental ray se va pareciendo a vray. Da la sensación de que va ha ser más fácil de usar, tanto en materiales como en configuración del final gathering. Ya se vera, no sabemos que máquina usan para hacer los videos, lo mismo tiene 4 opteron duales en la placa, jejeje. Un saludo.
  11. #26
    Expulsado
    Jun 2006
    Donde Max me lleve ....
    Wowwwwww... Me encanta...jeje
  12. #27
    Senior Member Avatar de cabfl
    Canary Islands
    Cita Iniciado por NeCRoManCeR
    esta me parece horrible...
    Prefiero la negra lisa del 8
    ¿decía usted?
  13. #28
    Corrientes - Argentina
    mmmmm ¿Lo hiciste vos? Eso se ve magnífico ^^
  14. #29
    Yo lo que hago es hacer una copia del "hotkeys.swf" y cambiarle el nombre a "splash.swf" así mientras se inicia salen los atajos de teclado y tal...
  15. #30
    Senior Member Avatar de Birkov
    Coruña - Barcelona
    Algunas cosas tienen buena pinta como poder peinar el pelo directamente en el visor o las nuevas características del mental ray, espero que tengan la opción esa que vi por la página con un preset que evita los parpadeos en animaciones usando el final gather, las mejoras en el point cache también están muy bien
  1. Maya Abrir archivo .mb de Maya 2014 en Maya 2016
    Por Moritz en el foro Animación y Rigging
    Último mensaje: 22-12-2016, 13:15
  2. Maya Importar personajes de maya en escenas distintas de maya
    Por conisco en el foro Animación y Rigging
    Último mensaje: 12-03-2014, 23:54
  3. Respuestas: 5
    Último mensaje: 07-04-2013, 20:41
  4. Respuestas: 0
    Último mensaje: 06-04-2013, 01:22
  5. Maya Comandos de acceso rapido a los kek frames en maya en maya
    Por robby en el foro Peticiones y Búsquedas
    Último mensaje: 14-07-2009, 22:28
