Tema: Messiah:Studio 2 24c
    Messiah Messiah:Studio 2.24c
    Nueva versión del mejor complemento para ZBrush-Modo-Silo-Hexagon-Wings3D
    http://www.projectmessiah.com/x4/downloads_main.htm
    La demo aun no ha salido, habrá que esperar.
    Cita Iniciado por Taron en los foros de pmG en CGTalk
    Here are a list of changes and bug fixes for the 2.4c versión:
    • autosave - múltiple auto save files are possible now (up to 100, default
      is 10.)
    • incremental scene saving - save fxs or mpj file incrementally. The new
      scene will automatically be incremented by one, so if the original was
      myscene0001.fxs the new one will be myscene0002.fxs.
    • object sequence loading added to dmorph. The surfaces will remain
      the same as those of the base object you applied the dmorph to. This
      is handy if you have an object, which has been textured in messiah.
      When the object is replaced, the texturing will remain intact.
    • fixed double armature load upon program start
    • material nodes will not be partially transparent any more obscuring
      the node text on certain graphics cards when they overlap
    • fixed the problem of the mat tray selecting the next material down,
      when you delete a shader from a material, and it's the only shader left.
    • fixed the problem with making a gradient and going into the light block
      and when you double clik a light the blok would collapse.
    • the view no longer changes focus to the first view, when saving, or auto
      save is activated, and you're in a quad or double view.
    • cylindrical map fliped on x fixed as well as the rotation assignment
      problem.
    • particles - Now able to choose NULLS in particle slave popup.
    • material copy - connections to material inputs are preserved when a
      copy material happens.
    • particle emitter now has visual guides for type (cone, box, plane).
    • spot light cone can be seen when looking through the spot light as a
      camera object.
    • graph now zooms with the current frame marker as the center, instead
      of the left edge of the graph.
    • min max can be set for the viewport sliders.
    • correct list item is selected after a delete of the last of it's child items.
    • reactivated GI lighting from transparent objects.
    • inactive keys remain inactive, even after being moved in time and
      selection.
    • fix to self shadow from no cast shadows, and GI from transparent
      objects.
    • fixed chunque files overwritting each other, when 2 messiahs are run
      on the same machine.
    • fixed the background image not being scaled to the same fit, as the
      new viewport camera recticle fitting.
    • image sequence texture color should behave properly now
    Saludiños
    Victor Navone
    Chuck Jones
    John Lasseter
    Dec 2003
    Re: Messiah:Studio 2.24c
    Lo que hace falta que implementen es días de 72 horas para probar todo!!
    Última edición por elGordo; 09-05-2006 a las 14:12
    Cuiño, cuiiiiño!!!!
    Cita Iniciado por elGordo
    Lo que hace falta que implementen es sias de 72 horas para probar todo!!
    Diccionario 3DPoder
    Sias: Días de más de 24 horas.
    Muy de acuerdo con tu propuesta, por cierto.
    Victor Navone
    Chuck Jones
    John Lasseter
    Dec 2003
    cachis ... maldita dislexia!!!
    Cuiño, cuiiiiño!!!!
    Nah, yo creo que es la emoción de ver la diversión que nos espera
    Victor Navone
    Chuck Jones
    John Lasseter
    Dec 2003
    jejejeje ... espero que el verano sea largo y ocioso, para poder probar todo esto ... y lo más importante, aplicarlo!!! (que dicho sea de paso, tenemos dónde!)
    Un saludo.
    Cuiño, cuiiiiño!!!!
  1. Messiah Studio 6
    Por 3dpoder en el foro Programas de Diseño gráfico
    Último mensaje: 25-04-2013, 09:34
  2. Messiah Messiah Studio 5
    Por themonster en el foro Noticias
    Último mensaje: 04-12-2010, 07:11
  3. Messiah:Studio 3 0 ya disponible
    Por SHAZAM en el foro Noticias
    Último mensaje: 03-12-2008, 21:50
  4. WIP Oakis, Messiah Studio
    Por fabian4d en el foro Animación y Rigging
    Último mensaje: 21-11-2007, 16:11
  5. Respuestas: 8
    Último mensaje: 11-10-2006, 13:41
