Tema: Wings3D 1 0 1 modelador gratuito actualizado 06sep09
    Wings3D 1.0.1 (modelador gratuito) Actualizado 06sep09
    Nueva versión del pequeño gran programa de modelado Open Source:
    Wings3d 1.0.1
    Latest Stable Rel: 1.0.1 mac | win | linux | source | notes Development Rel: 1.1.12 mac | win | linux | source Other Releases Download page
    Release Name: 1.0.1
    Notes:
    - Magnets are now drawn correctly in Tweaque when selections across multiple
    objects are dragged. [optigon]
    - Selectings múltiple objects in Tweaque and calling a command via a hotkey would
    only affect one of the objects. Now corrected. [optigon]
    - Tweaque Crash to do with unchecked camera mode reported by Fonte Boa corrected.
    [optigon]
    - Tweaque mode temporary selection fix. [optigon]
    - Select Similar Normals with the option Connected Faces Only and
    a selection comprising múltiple objects would cause a crash.
    (Thanks to pauljs75.) [bjorng]
    - When creating a texture from vertex colors in the AutoUV window, the
    colors will be properly interpolated (smoothed). [scorpius]
    - Keyboard events in Tweaque while dragging could cause slow downs. Now Fixed.
    (Thanks to Fonte Boa.) [optigon]
    - Additional Geometry Windows can now be closed from within Tweaque mode.
    - Dragging in Tweaque is no longer limited to the size of the current window.
    [optigon]
    - Conflicts due to mouse events in adjacent Geometry Windows have been solved by
    locking the focus to the original window during paint selection and dragging
    in Tweaque Mode. (Thanks to Fonte Boa.) [optigon]
    - New Tweaque option to set Tweaque Magnet Increment. [optigon]
    - Spherical UV mapping corrected. [dgud]
    - Doing a Doo-Sabin sub-división on múltiple objects would leave an
    invalid selection that could cause crashes. (Thanks to Fonte Boa.) [bjorng]
    - Very old Wings files could have invalid mirror faces, which would cause
    crashes. Now clearing the mirror face if it is invalid when loading
    a Wings file. [bjorng]
    __________________________________________________
    Wings3d 0.99.53
    Latest Stable Rel: 0.99.04a
    Development Rel: 0.99.53
    Other Releases
    Download page
    Notes:
    - Kerkythea exporter added to Wings. [contributed by Chris Hegarty (Avariant)]
    - Added a file browser to the Text plugin. [optigon]
    - Tweaque can now use single and double clicking to select geometry. There is an
    options panel beside the Tools|Tweaque menú heading where you can set the
    clik speed and alos turn off this feature. There is alos an option to reduce
    the number of button used to activate Tweaque Slide. (Thanks to puzzledpaul,
    Fonte Boa, and marcin wuu for their input). [optigon]
    - Added temporary highlight selection for Edge Loop, Edge Ring, Select All, and
    Select Similar commands. Now, you can extend a selection by pressing the
    associated hotkey over a highlighted element. An option to activate this
    feature can be found in the Edit|Preferences|Advanced dialog. [optigon]
    - Bug fixes for the mode specific hotkey implementation. [optigon]
    - Code imporvements and an extensión of the Select|Similar Normals command.
    The command now has a new preference to save the Angle Tolerance, which in
    combination with the Connected Faces Only option, makes this tool great for
    selecting face regions bounded by sharp edges. [optigon]
    - Some object mode selections would cause crashes when used in conjunction with
    the Duplicate command. (Reported by Fonte Boa). [optigon]
    - Dragging Lights as an edge selection in Tweaque mode would crash. Now fixed.
    [optigon]
    - Mouse over highlighted items are now added temporarily to a drag operation
    in Tweak. [optigon]
    - Following a Slide+Clean operation in Tweak, if any short edges were collapsed,
    then an empty selection will now be returned. Returning the original selection
    was offen times unsafe, because the selected element might have been removed,
    causing Wings to crash. [optigon]
    - Toggling wireframe display for objects in the Geometry Graph using the right
    mouse button option would not yeild the correct results in some situations.
    Now fixed. (Reported by pauljs75). [optigon]
    - Select by material called from the Outliner would select hidden faces. This
    has been corrected. (Thanks to odf). [optigon]
    - Blocked some face selection tools from selecting hidden faces. [optigon]
    Última edición por SHAZAM; 06-09-2009 a las 20:42 Razón: Actualización
    Victor Navone
    Chuck Jones
    John Lasseter
    Senior Member Avatar de themonster
    islas cayman
    Respuesta: Wings3D 0.99.53 (modelador gratuito)
    ya salio la versión 1!!
    http://www.wings3d.com/
    y parece que cambiaron el logo
    Miniaturas adjuntadas Miniaturas adjuntadas Wings3D 1 0 1  modelador gratuito  actualizado 06sep09-f3c26c243d5028c84c85ab7bd708f21adb8241e1.gif
    Última edición por 3dpoder; 09-09-2009 a las 09:27
    Blog con mis practicas de animación:
    http://visualbug.wordpress.com/
    mi pagina web: http://visualbug.com/
    Si, esta muy bien, han habido varias sub-versiones antes de llegar a la actual en un corto período de tiempo. Se lo están currando
    Victor Navone
    Chuck Jones
    John Lasseter
    Respuesta: Wings3D 1.0.1 (modelador gratuito) Actualizado 06sep09
    Hilo actualizado (gracias a themonster)
    Victor Navone
    Chuck Jones
    John Lasseter
  1. Blender Tener Blender actualizado
    Por Freemind en el foro Blender
    Último mensaje: 27-06-2012, 11:44
  2. Collada actualizado
    Por Klópes en el foro Programación y Scripts
    Último mensaje: 10-07-2007, 18:26
  3. Nueva Web actualizado 11-11-04
    Por Frodo en el foro Trabajos en Proceso
    Respuestas: 14
    Último mensaje: 11-11-2004, 14:54
  4. Render actualizado
    Por TroGLoD en el foro Trabajos Finalizados
    Respuestas: 13
    Último mensaje: 08-09-2003, 07:25
  5. Wings 3D Wings3D modelador poligonal sencillo
    Por Siquier en el foro Modelado
    Último mensaje: 08-05-2003, 03:32
