Tema: 3ds Max 9 0 32 Bit Hot Fix 1 y 2
    Viva Blender !!! Avatar de miguelito08
    Apr 2006
    República Dominicana
    3ds Max 9.0 (32 Bit) Hot Fix 1 y 2
    Hola
    Quisiera saber si algunos de ustedes a instalado los dos
    hotfix para max 9.0 y como le han funcionado
    más información
    http://usa.autodesk.com/adsk/servlet...linkID=5573636
    Suerte
    Suerte
    Senior Member Avatar de cabfl
    Canary Islands
    Re: 3ds Max 9.0 (32 Bit) Hot Fix 1 y 2
    This hot fix package resolves the Shockwave issue where the exporter is missing from the product's install. This resolves the same issue as Hotfix 0.1, the only difference is that it is rolled into an hotfix installer.
    This hot fix package resolves the problem of the DX material who was unable to use UV channels higher than 1.When installing Hot fix 2 , you will alos install hot fix 1. it is ONLY for 32 bit build
    según explican, son 2 tonterías las que han arreglado con los hotfix, estos.
