Página 30 de 32 PrimerPrimer ... 2026272829303132 ÚltimoÚltimo
Resultados 436 al 450 de 474
Tema: que tal el silo
  1. #436
    Re: que tal el silo?
    y a que hora te acuestasí? duermes algo, a caso? o te echas unas siestas de las gordasí?
    Da Vinci's Techniques
    Victor Navone
    Chuck Jones
    John Lasseter
  2. #437
    Empezando... sin tiempo.. Avatar de Astuti
    En los Madriles...
    Public Beta 8b:
    http://www.silo3d.com/forum/showthread.php?t=9659
    Log (non-comprehensive) of many relevant changes:
    -fixed lots of crashing and stability issues
    -improved rotate and universal manipulators
    -fixed load and save viewport images with sia and sib
    -fixed clearing viewport images on new scene etc.
    -context help updates with last command
    -marque texture seams works with mirroring
    -area selection option for partially enclosed components
    -improved tweaque with several maipulators
    -mirai-style viewport manipulation is back
    -xyz etc. constraints are fully working
    -fixed disp. painting bug with symmetry
    -much improved button editor
    -lights can be properly rotated with the manipulator
    -hotkeys for brushes don't take over all possible combination for that key (so Ctrl S will still save while painting even when the smooth brush is assigned to s, for example)
    -functions work with highlighting in multi-select mode
    -scrolling when over a manip handle no longer selects that handle
    -extrude edges selects the resulting edges
    -Silo remembers docked and un-docked window positions
    -hotkeys for area/lasso/paint selection will toggle between last used selection style
    -surface snapping works on first mouse clik as well as when dragging
    -mouse settings window doesn't open too wide
    -shininess material property loads and sabes with .sib
    -hidden manipulator no longer selectable
    -area select works in multi-select mode if you have a component highlighted
    -shape options open separately from tool options
    -paste selects newly created copy
    -scale manipulator bahves well on large models
    Vamos a beta por semana, casi
    Un saludo!
  3. #438
    Dec 2003
    Venga ... otra beta!
    Gracias por el aviso!
    Cuiño, cuiiiiño!!!!
  4. #439
    Cita Iniciado por Astuti Ver mensaje
    Chas gracias Menos mal que no todo son fixes, veo cosas nuevas con muy buena pinta ...
    Victor Navone
    Chuck Jones
    John Lasseter
  5. #440
    En los Madriles...
    Public Beta 9b:
    http://www.silo3d.com/forum/showthre...9253#post79253
    Here's a list of some of the things we've done since the last beta:
    - made all remaining commands work fully (i.e. things like "constrain to x", etc which were partially functional or non-functional)
    - fixed software selection over mirror seam causing troubles
    - changed slide to work better on large scale models
    - fixed things going screwy when using scale and rotate with snapping active
    - made Command and Control fully interchangeable on the Mac
    - fixed several problems where selection wasn't updating properly (when doing things like hiding/showing from the scene editor)
    - added support for preset settings in several editors (try the Maya color preset from the drop-down menú in the color editor)
    - fixed a bug where keyboard shortcuts sometimes didn't assign from the menus
    - fixed a bug where breaque and then undo on a texture proxy made it lose trak of its parent object
    - fixed the bug where spin edge and then moving the edge would move the old vértices
    - fixed displacement painting not updating with fast shade mode when under optimize face draw limit
    - can now do local move and others in a negative value from the numerical entry
    - instance mirror sabes properly
    - fixed a bug where path extrude would go wonky when there were múltiple segments of the path perfectly aligned
    - other crashing fixes
    - made all image buttons stay in the down state to reflect when a toggle or state is enabled (some did this previously)
    We're getting the help files ready and will probably asque for your input on those as soon as they're mostly ready. The help files for 2.0 will come in múltiple flavors: online html, local html, pdf, Windows help. We're alos planning on getting an official wiki going as soon as we find or create a wiki software which is minimal/simple enough (I find the software for wikipedia, for example, to be too cluttered and difficult for what we need it for). Anyway, here are the downloads. Enjoy!
    Cada beta es un pasito más hacia la versión final... ¿Cuando es el Siggraph?
  6. #441
    Gracias Astuti Siggraph es del 5 al 9 de agosto, la release 2.0 debería estar un poco antes, o sea, que en teoría tendremos Silo 2 en tres meses
    ¡Por fin un help acualizado!
    Victor Navone
    Chuck Jones
    John Lasseter
  7. #442
    tiruri.... Avatar de RavenX
    Valencia
    Gracias por la información
    Después ya no.
  8. #443
    Dec 2003
    Ole ... en cuanto llegue a casa, lo descargo.
    Chas gracias!!
    Cuiño, cuiiiiño!!!!
  9. #444
    Zaragoza (ESPAÑA)
    ¿Algún tutorial hay por ahí para la herramienta de sculpting? Reconozco que tampoco he buscado mucho, pero por si lo tenéis a mano.
    Thanksketes.
    EDITADO: Bueno, olvidadlo, lo he encontrado, esta por los foros a modo de ¿queréis que funcione así? Claro, esta con los Betas, y los usuarios son los que mandan.
    Última edición por Leander; 12-04-2007 a las 02:11
  10. #445
    En los Madriles...
    Oooootra más
    Public Beta 9c:
    http://www.silo3d.com/forum/showthre...9972#post79972
    We're calling ithis one 9c. Note that we tweaked the behavior of several tools. Alos please give feedbak on the included default color scheme :]. Here are some of the changes:
    - many tools will not "grab" the mouse anymore if you just tap the hotkey for them (such as slide), but will still grab it if you hold the hotkey down
    - split loop will not use the default slide amount when it goes into the slide tool (if you hold the keyboard shortcut key down)
    - cut (connect) will select the newly created edges when in edge selection mode
    - import/export of obj *hopefully* improved - since many programs interpret these files differently, it's impossible to say, but in our tests so far it is better
    - import/export of 3ds is better, including texture mapping
    - added support for opening tga files, though there are some issues with many files that we can't trak down the cause of yet
    - fixed inverted mirai mouse tilt
    - fixed some crashing problems when opening models with the scene editor open
    - fixed rotation/scale problems with snapping
    - can set group members from right-clik menú in scene editor
    - fixed (better) software selection over mirror seam with mirroring
    - fixed undo on unwrap UV proxy, alos create UV proxy
    Enjoy:
    http://www.silo3d.com/Downloads/Silo...eta_9c_win.zip
    Esta es sólo para Windows...
  11. #446
    Chas gracias, lo bajo esta tarde
    Victor Navone
    Chuck Jones
    John Lasseter
  12. #447
    Dec 2003
    Alla vamos.
    Chas gracias!!!
    Cuiño, cuiiiiño!!!!
  13. #448
    Joe que raspido ^^
    a ver si sacan ya el manual a ver que tal esta.
  14. #449
    Zaragoza (ESPAÑA)
    Cita Iniciado por Archanum Ver mensaje
    Joe que raspido ^^
    Por probar, puedes bajarte la demo de 30 días y mirar los tutoriales y videotutoriales.
  15. #450
    Cita Iniciado por Leander Ver mensaje
    Creo que Archanum se refiere a ver que tal esta el manual
    Victor Navone
    Chuck Jones
    John Lasseter
  1. prueba de silo
    Por fernando aponte en el foro Trabajos en Proceso
    Respuestas: 12
    Último mensaje: 12-10-2006, 20:02
  2. Super Silo
    Por sejob1975 en el foro Trabajos en Proceso
    Respuestas: 29
    Último mensaje: 20-09-2006, 14:51
  3. Seleccion en Silo
    Por Cesar Saez en el foro Modelado
    Último mensaje: 27-12-2005, 21:57
  4. Silo 2 0
    Por Ballo en el foro Noticias
    Respuestas: 26
    Último mensaje: 23-08-2005, 12:20
  5. Silo 1 3
    Respuestas: 44
    Último mensaje: 08-11-2004, 20:17
