Gracias Gracias:  1
Resultados 1 al 14 de 14
Tema: audi : Filter
    Re Member Avatar de _Moe_
    Audi : Filter
    Hola,
    Un spot que me ha gustado mucho :
    Audi : Filter
    + YouTube Video
    ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
    HQ : http://motionographer.com/theater/audi-filter/
    Audi : Filter - Maquíng Of
    + YouTube Video
    HQ : http://motionographer.com/theater/au...ter-making-of/
    ¿Alguna idea de cómo han renderizado las partículasí ¿Con Krakatoa quizásí
    Monigote al ralentí Avatar de Drakky
    Madrid
    Respuesta: Audi : Filter
    Brutal...
    soy un emigrante Avatar de Pit [reloaded]
    viendo bob esponja
    no esta mal, no
    Granada, España
    Las renderizaron con XSI usando mental ray y el volume shader nativo, en el mailing list de XSI se comentó bastante sobre el tema
    Cita Iniciado por Tim Borgman
    to answer your question: the workflow was XSI only. We used EmFluid for
    some takes (which was luckily anonced just at the moment we started with
    the project). The rendering was done with the volumeshader. Really hard
    to setup for some takes, but it works So the workflow was mostly ->
    setup and design of the simulation -> cache writting (which eats a lot,
    really a lot, harddrive space). Loading bak the cache, some duplication
    of the cached particles with clone point, setting the size of the
    particles and finally setting up the volume shader and the light(s).
    Cheers
    Tim
    Cita Iniciado por Christian Keller
    no i first thought we should use krakatoa and fume fx,
    and try to get it it done in in max and xsi.
    but i wanted to use mainly xsi. when i started the research
    how we could do the fluid stuff, there was no way to do it in
    xsi. i played a little bit with the maya fluids and remembered
    that i started to code an importer for maya fluid caches some
    time ago.
    after a bit of digging i had a prototype in python which was working, to use the caches as flowfield. but in the second weeque of research
    the nice emFluid was ported to ice and we gave it a go.
    quite easy to use and as a node in ice quite powerfull.
    you could enhance the resolution of the simulation with simple
    turbulence nodes. for example using the velocity as a multiplier
    for the turb or the turb size ...
    rendering was an other thing. first we wanted to stay away from
    selfshadowing and do something in comp, but after i set up the first
    shot with shadows, just for fun, it was not that problematic
    as i thought. everything on 64 bit because of the massive data amount.
    some shots with over 50 mio particles - Mental Ray was quite nice to us ;-)
    it was a bit painfull,because we had to tune the shader settings of every shot seperately, there was no way to use settings from other shots. the volume shader worked quite well but it´s hard to tune.
    we found one limit with the mental volume thing - you could not
    allocate more than 4 gig.
    the other nice thing is - youre not used to produce such an large amount
    of data with cache files. we had around 1 terra of cache files
    only with the pointposition because of the file size. then we loaded it bak in ice and calculated the size, velocity etc on the flow.
    otherwise it would have killed our server.
    3 months of hard work in the production submarine, but tim and me had
    a nice time.
    chris
    Última edición por Cesar Saez; 17-04-2009 a las 18:22
    Muchas gracias, César.
    Feb 2007
    bufff, la verdad es que XSI es otro programa magnífico, yo lo estoy aprendiendo y empecé con el modulo de modelado, y la verdad es que es una gozada, probablemente el que mejor he usado
    A mí también me esta gustando mucho este software.
    viendo bob esponja
    Cita Iniciado por _Moe_ Ver mensaje
    también lo estas probando?
    Probarlo no, estoy estudiandolo. Me quedan unos meses duros.
    Senior Member Avatar de TheOutsider
    Marbella
    Pit, este tío no es normal .
    Excelente video!...Me quedé impresionado cuando lo vi.
    (Si tienes que aprender Mental, y aprendes algo sobre settings, tu amigo Borja te lo agradecera :D )
    ¿Brotes verdes?....Mis cojones....
    Learning to trade.
    viendo bob esponja
    lo del mental es de provocar jaquecas
    yo cada vez que lo intento salgo escaldado
    crazy bump Avatar de itstimetodraw
    Apr 2009
    LosT In ParaDise!
    impresionante ese making of, quien puediera...
    Click faster! Avatar de hori_hjm
    Apr 2006
    Londres
    wow, no lo había visto, están de moda los fluidos jeje, si que quedaron bonitos, 1 tera de data? por lo que se ve parece que podría haber sido mucho más no?
    Granada, España
    Cita Iniciado por hori_hjm Ver mensaje
    Dentro de poco los veremos en los programas 2D simulando tintas y tal...
    http://visgraph.cse.ust.hk/MoXi
  1. Selection Filter
    Por Vanguardia en el foro Problemas con Programas
    Último mensaje: 04-01-2013, 14:53
  2. Nodes gt; Filter
    Último mensaje: 12-09-2008, 14:46
  3. Select Filter
    Por Keroki en el foro Programación y Scripts
    Último mensaje: 25-06-2008, 12:11
  4. antialiasing filter
    Por mensajero76 en el foro Problemas con Programas
    Último mensaje: 25-03-2008, 17:11
  5. Filter autocad
    Por rubbin en el foro Diseño Gráfico y CAD
    Último mensaje: 04-10-2005, 00:05
