Tema: Install Autodesk 3ds Max 2016 failed installation aborted result=1603
    Nov 2015
    Install Autodesk 3dsmax 2016 failed installation aborted result=1603
    Buenas tardes, estudio arquitectura y necesito una ayuda con este error que está afectando la instalación del 3dsmax y retrasa mis estudios, por favor ayúdenme, aquí les indico el error, al final salen los errores, gracias de antemano.
    2015/10/30:19:09:08 ASUAREZ ASUAREZ-PC === Setup started on ASUAREZ-PC by ASUAREZ ===2015/10/30:19:09:08 ASUAREZ ASUAREZ-PC Path_Length: 153
    2015/10/30:19:09:08 ASUAREZ ASUAREZ-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm
    2015/10/30:19:09:08 ASUAREZ ASUAREZ-PC Launch
    2015/10/30:19:09:08 ASUAREZ ASUAREZ-PC CommandLine
    2015/10/30:19:09:08 ASUAREZ ASUAREZ-PC Current Directory C:\Users\ASUAREZ\AppData\Local\Temp\_AI1FD0.tmp
    2015/10/30:19:09:20 ASUAREZ ASUAREZ-PC === Setup ended ===.
    2015/10/30:19:09:12 ASUAREZ ASUAREZ-PC === Setup started on ASUAREZ-PC by ASUAREZ ===
    2015/10/30:19:09:12 ASUAREZ ASUAREZ-PC Path_Length: 153
    2015/10/30:19:09:12 ASUAREZ ASUAREZ-PC Current Directory C:\Users\ASUAREZ\AppData\Local\Temp\_AI1FD0.tmp
    2015/10/30:19:09:12 ASUAREZ ASUAREZ-PC Launch
    2015/10/30:19:09:20 ASUAREZ ASUAREZ-PC PageOpen LaunchDialog
    2015/10/30:19:09:25 ASUAREZ ASUAREZ-PC PageOpen LicenseDialog
    2015/10/30:19:09:27 ASUAREZ ASUAREZ-PC PageOpen ProductInfoDialog
    2015/10/30:19:09:38 ASUAREZ ASUAREZ-PC PageOpen ProductSelectionDialog2
    2015/10/30:19:09:41 ASUAREZ ASUAREZ-PC PageOpen FullProgressDialog
    2015/10/30:19:09:41 ASUAREZ ASUAREZ-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.e xe /install /quiet /norestart
    2015/10/30:19:10:24 ASUAREZ ASUAREZ-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeded
    2015/10/30:19:10:24 ASUAREZ ASUAREZ-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.e xe /install /quiet /norestart
    2015/10/30:19:10:49 ASUAREZ ASUAREZ-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeded
    2015/10/30:19:10:49 ASUAREZ ASUAREZ-PC Installing DirectX Runtime: C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\DirectX\DXSETUP.exe /silent
    2015/10/30:19:11:39 ASUAREZ ASUAREZ-PC Install DirectX Runtime Succeded
    2015/10/30:19:11:39 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES=Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:19:12:14 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 Succeded
    2015/10/30:19:12:14 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:19:13:02 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Base Image Library Succeded
    2015/10/30:19:13:02 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:19:14:06 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Medium Resolution Library Succeded
    2015/10/30:19:14:06 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:19:14:12 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Advanced Material Image Library Succeded
    2015/10/30:19:14:13 ASUAREZ ASUAREZ-PC Installing Autodesk 3ds Max 2016: TRANSFORMS=C:\Users\ASUAREZ\AppData\Local\Temp\_AI 1FD0.tmp\x64\max\3dsMax-standalone, mst ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm INSTALLDIR=C:\Program Files\Autodesk\3ds Max 2016 FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:19:18:07 ASUAREZ ASUAREZ-PC Install Autodesk 3ds Max 2016 Failed Installátion aborted, Result=1603
    2015/10/30:19:18:11 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Advanced Material Image Library Succeded
    2015/10/30:19:18:15 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Medium Resolution Library Succeded
    2015/10/30:19:18:18 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Base Image Library Succeded
    2015/10/30:19:18:29 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 Succeded
    2015/10/30:19:18:29 ASUAREZ ASUAREZ-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
    2015/10/30:19:18:29 ASUAREZ ASUAREZ-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
    2015/10/30:19:18:29 ASUAREZ ASUAREZ-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
    2015/10/30:19:18:30 ASUAREZ ASUAREZ-PC PageOpen InstallCompleteDialog
    2015/10/30:19:20:32 ASUAREZ ASUAREZ-PC === Setup ended ===.
    2015/10/30:22:23:02 ASUAREZ ASUAREZ-PC === Setup started on ASUAREZ-PC by ASUAREZ ===
    2015/10/30:22:23:02 ASUAREZ ASUAREZ-PC Path_Length: 153
    2015/10/30:22:23:02 ASUAREZ ASUAREZ-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm
    2015/10/30:22:23:02 ASUAREZ ASUAREZ-PC Launch
    2015/10/30:22:23:02 ASUAREZ ASUAREZ-PC CommandLine
    2015/10/30:22:23:02 ASUAREZ ASUAREZ-PC Current Directory C:\Users\ASUAREZ\AppData\Local\Temp\_AIA6CE.tmp
    2015/10/30:22:23:14 ASUAREZ ASUAREZ-PC === Setup ended ===.
    2015/10/30:22:23:11 ASUAREZ ASUAREZ-PC === Setup started on ASUAREZ-PC by ASUAREZ ===
    2015/10/30:22:23:11 ASUAREZ ASUAREZ-PC Path_Length: 153
    2015/10/30:22:23:11 ASUAREZ ASUAREZ-PC Current Directory C:\Users\ASUAREZ\AppData\Local\Temp\_AIA6CE.tmp
    2015/10/30:22:23:11 ASUAREZ ASUAREZ-PC Launch
    2015/10/30:22:23:14 ASUAREZ ASUAREZ-PC PageOpen LaunchDialog
    2015/10/30:22:23:16 ASUAREZ ASUAREZ-PC PageOpen LicenseDialog
    2015/10/30:22:23:18 ASUAREZ ASUAREZ-PC PageOpen ProductInfoDialog
    2015/10/30:22:23:23 ASUAREZ ASUAREZ-PC PageOpen ProductSelectionDialog2
    2015/10/30:22:23:37 ASUAREZ ASUAREZ-PC PageOpen FullProgressDialog
    2015/10/30:22:23:38 ASUAREZ ASUAREZ-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.e xe /install /quiet /norestart
    2015/10/30:22:24:07 ASUAREZ ASUAREZ-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeded
    2015/10/30:22:24:07 ASUAREZ ASUAREZ-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.e xe /install /quiet /norestart
    2015/10/30:22:24:34 ASUAREZ ASUAREZ-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeded
    2015/10/30:22:24:34 ASUAREZ ASUAREZ-PC Installing DirectX Runtime: C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\DirectX\DXSETUP.exe /silent
    2015/10/30:22:25:02 ASUAREZ ASUAREZ-PC Install DirectX Runtime Succeded
    2015/10/30:22:25:02 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES=Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:22:25:26 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 Succeded
    2015/10/30:22:25:26 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:22:26:21 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Base Image Library Succeded
    2015/10/30:22:26:21 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:22:27:27 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Medium Resolution Library Succeded
    2015/10/30:22:27:27 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:22:27:38 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Advanced Material Image Library Succeded
    2015/10/30:22:27:40 ASUAREZ ASUAREZ-PC Installing Autodesk 3ds Max 2016: TRANSFORMS=C:\Users\ASUAREZ\AppData\Local\Temp\_AI A6CE.tmp\x64\max\3dsMax-standalone, mst ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm INSTALLDIR=C:\Program Files\Autodesk\3ds Max 2016 FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:22:32:02 ASUAREZ ASUAREZ-PC Install Autodesk 3ds Max 2016 Failed Installátion aborted, Result=1603
    2015/10/30:22:32:05 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Advanced Material Image Library Succeded
    2015/10/30:22:32:08 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Medium Resolution Library Succeded
    2015/10/30:22:32:11 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Base Image Library Succeded
    2015/10/30:22:32:22 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 Succeded
    2015/10/30:22:32:22 ASUAREZ ASUAREZ-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
    2015/10/30:22:32:22 ASUAREZ ASUAREZ-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
    2015/10/30:22:32:22 ASUAREZ ASUAREZ-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
    2015/10/30:22:32:23 ASUAREZ ASUAREZ-PC PageOpen InstallCompleteDialog
    2015/10/30:22:32:52 ASUAREZ ASUAREZ-PC === Setup ended ===.
    2015/10/30:22:33:14 ASUAREZ ASUAREZ-PC === Setup started on ASUAREZ-PC by ASUAREZ ===
    2015/10/30:22:33:14 ASUAREZ ASUAREZ-PC Path_Length: 153
    2015/10/30:22:33:14 ASUAREZ ASUAREZ-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm
    2015/10/30:22:33:14 ASUAREZ ASUAREZ-PC Launch
    2015/10/30:22:33:14 ASUAREZ ASUAREZ-PC CommandLine
    2015/10/30:22:33:14 ASUAREZ ASUAREZ-PC Current Directory C:\Users\ASUAREZ\AppData\Local\Temp\_AIFB44.tmp
    2015/10/30:22:33:18 ASUAREZ ASUAREZ-PC === Setup ended ===.
    2015/10/30:22:33:16 ASUAREZ ASUAREZ-PC === Setup started on ASUAREZ-PC by ASUAREZ ===
    2015/10/30:22:33:16 ASUAREZ ASUAREZ-PC Path_Length: 153
    2015/10/30:22:33:16 ASUAREZ ASUAREZ-PC Current Directory C:\Users\ASUAREZ\AppData\Local\Temp\_AIFB44.tmp
    2015/10/30:22:33:16 ASUAREZ ASUAREZ-PC Launch
    2015/10/30:22:33:18 ASUAREZ ASUAREZ-PC PageOpen LaunchDialog
    2015/10/30:22:33:21 ASUAREZ ASUAREZ-PC PageOpen LicenseDialog
    2015/10/30:22:34:55 ASUAREZ ASUAREZ-PC PageOpen ProductSelectionDialog2
    2015/10/30:22:35:40 ASUAREZ ASUAREZ-PC PageOpen FullProgressDialog
    2015/10/30:22:35:40 ASUAREZ ASUAREZ-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.e xe /install /quiet /norestart
    2015/10/30:22:36:13 ASUAREZ ASUAREZ-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeded
    2015/10/30:22:36:13 ASUAREZ ASUAREZ-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.e xe /install /quiet /norestart
    2015/10/30:22:36:39 ASUAREZ ASUAREZ-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeded
    2015/10/30:22:36:39 ASUAREZ ASUAREZ-PC Installing DirectX Runtime: C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\DirectX\DXSETUP.exe /silent
    2015/10/30:22:37:22 ASUAREZ ASUAREZ-PC Install DirectX Runtime Succeded
    2015/10/30:22:37:22 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES=Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:22:37:40 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 Succeded
    2015/10/30:22:37:40 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:22:38:33 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Base Image Library Succeded
    2015/10/30:22:38:33 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:22:38:55 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Medium Resolution Library Succeded
    2015/10/30:22:38:55 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:22:39:01 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Advanced Material Image Library Succeded
    2015/10/30:22:39:02 ASUAREZ ASUAREZ-PC Installing Autodesk 3ds Max 2016: TRANSFORMS=C:\Users\ASUAREZ\AppData\Local\Temp\_AI FB44.tmp\x64\max\3dsMax-standalone, mst ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm INSTALLDIR=C:\Program Files\Autodesk\3ds Max 2016 FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/10/30:22:43:25 ASUAREZ ASUAREZ-PC Install Autodesk 3ds Max 2016 Failed Installátion aborted, Result=1603
    2015/10/30:22:43:28 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Advanced Material Image Library Succeded
    2015/10/30:22:43:31 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Medium Resolution Library Succeded
    2015/10/30:22:43:34 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Base Image Library Succeded
    2015/10/30:22:43:46 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 Succeded
    2015/10/30:22:43:46 ASUAREZ ASUAREZ-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
    2015/10/30:22:43:46 ASUAREZ ASUAREZ-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
    2015/10/30:22:43:46 ASUAREZ ASUAREZ-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
    2015/10/30:22:43:47 ASUAREZ ASUAREZ-PC PageOpen InstallCompleteDialog
    2015/10/30:22:44:27 ASUAREZ ASUAREZ-PC === Setup ended ===.
    2015/11/3:18:24:09 ASUAREZ ASUAREZ-PC === Setup started on ASUAREZ-PC by ASUAREZ ===
    2015/11/3:18:24:09 ASUAREZ ASUAREZ-PC Path_Length: 153
    2015/11/3:18:24:09 ASUAREZ ASUAREZ-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm
    2015/11/3:18:24:09 ASUAREZ ASUAREZ-PC Launch
    2015/11/3:18:24:09 ASUAREZ ASUAREZ-PC CommandLine
    2015/11/3:18:24:09 ASUAREZ ASUAREZ-PC Current Directory C:\Users\ASUAREZ\AppData\Local\Temp\_AI5E05.tmp
    2015/11/3:18:24:19 ASUAREZ ASUAREZ-PC === Setup ended ===.
    2015/11/3:18:24:35 ASUAREZ ASUAREZ-PC === Setup started on ASUAREZ-PC by ASUAREZ ===
    2015/11/3:18:24:35 ASUAREZ ASUAREZ-PC Path_Length: 153
    2015/11/3:18:24:35 ASUAREZ ASUAREZ-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm
    2015/11/3:18:24:35 ASUAREZ ASUAREZ-PC Launch
    2015/11/3:18:24:35 ASUAREZ ASUAREZ-PC CommandLine
    2015/11/3:18:24:35 ASUAREZ ASUAREZ-PC Another Autodesk install/update is now occurring on this computer. Pléase wait for that to complete and then click Retry.2015/11/3:18:24:38 ASUAREZ ASUAREZ-PC Another Autodesk install/update is now occurring on this computer. Pléase wait for that to complete and then click Retry.2015/11/3:18:24:38 ASUAREZ ASUAREZ-PC === Setup ended ===.
    2015/11/3:18:24:14 ASUAREZ ASUAREZ-PC === Setup started on ASUAREZ-PC by ASUAREZ ===
    2015/11/3:18:24:14 ASUAREZ ASUAREZ-PC Path_Length: 153
    2015/11/3:18:24:14 ASUAREZ ASUAREZ-PC Current Directory C:\Users\ASUAREZ\AppData\Local\Temp\_AI5E05.tmp
    2015/11/3:18:24:14 ASUAREZ ASUAREZ-PC Launch
    2015/11/3:18:24:20 ASUAREZ ASUAREZ-PC PageOpen LaunchDialog
    2015/11/3:18:25:39 ASUAREZ ASUAREZ-PC PageOpen LicenseDialog
    2015/11/3:18:25:42 ASUAREZ ASUAREZ-PC PageOpen ProductInfoDialog
    2015/11/3:18:25:57 ASUAREZ ASUAREZ-PC PageOpen ProductSelectionDialog2
    2015/11/3:18:26:01 ASUAREZ ASUAREZ-PC PageOpen FullProgressDialog
    2015/11/3:18:26:02 ASUAREZ ASUAREZ-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.e xe /install /quiet /norestart
    2015/11/3:18:26:28 ASUAREZ ASUAREZ-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Succeded
    2015/11/3:18:26:28 ASUAREZ ASUAREZ-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.e xe /install /quiet /norestart
    2015/11/3:18:27:15 ASUAREZ ASUAREZ-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Succeded
    2015/11/3:18:27:15 ASUAREZ ASUAREZ-PC Installing DirectX Runtime: C:\Autodesk\Autodesk_3ds_Max_2016_EFGJKS_Win_64bit _dlm\3rdParty\DirectX\DXSETUP.exe /silent
    2015/11/3:18:28:03 ASUAREZ ASUAREZ-PC Install DirectX Runtime Succeded
    2015/11/3:18:28:03 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES=Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/11/3:18:29:09 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 Succeded
    2015/11/3:18:29:10 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/11/3:18:29:59 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Base Image Library Succeded
    2015/11/3:18:29:59 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/11/3:18:31:05 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Medium Resolution Library Succeded
    2015/11/3:18:31:05 ASUAREZ ASUAREZ-PC Installing Autodesk Material Library 2016 - Advanced Material Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME=Autodesk 3ds Max 2016 SETUP_PACKAGECODE={8E850B3E-B21A-4790-0464-7CB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPeNDENCIES={29A7D6EC-63C2-42FD-8143-5812ABD2923F},;;; PACKAGEUPI={6721253F-24FD-4F71-91A6-84F9A907DA1B} ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/11/3:18:31:13 ASUAREZ ASUAREZ-PC Install Autodesk Material Library 2016 - Advanced Material Image Library Succeded
    2015/11/3:18:31:14 ASUAREZ ASUAREZ-PC Installing Autodesk 3ds Max 2016: TRANSFORMS=C:\Users\ASUAREZ\AppData\Local\Temp\_AI 5E05.tmp\x64\max\3dsMax-standalone, mst ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROT=C:\Autodesk\Autodesk_3ds_Max_2016_ EFGJKS_Win_64bit_dlm INSTALLDIR=C:\Program Files\Autodesk\3ds Max 2016 FILESINUSETEXT= REBOT=ReallySuppress ADSK_SETUP_EXE=1.
    2015/11/3:18:34:48 ASUAREZ ASUAREZ-PC Install Autodesk 3ds Max 2016 Failed Installátion aborted, Result=1603
    2015/11/3:18:34:51 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Advanced Material Image Library Succeded
    2015/11/3:18:34:55 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Medium Resolution Library Succeded
    2015/11/3:18:34:58 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 - Base Image Library Succeded
    2015/11/3:18:35:10 ASUAREZ ASUAREZ-PC Rollback Autodesk Material Library 2016 Succeded
    2015/11/3:18:35:10 ASUAREZ ASUAREZ-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
    2015/11/3:18:35:10 ASUAREZ ASUAREZ-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
    2015/11/3:18:35:10 ASUAREZ ASUAREZ-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619.
Nombre: hh.jpg
Visitas: 266
Tamaño: 1,002.7 KB
    Parece un problema de librerías, instala el paquete para tu versión de max que hay en esta página y ya dirás.
    https://knowledge.autodesk.com/suppo...e-Library.html.
  1. Maya Problema con Autodesk Maya 2016 shader predeterminados
    Por CRONOGEO en el foro Problemas con Programas
    Último mensaje: 29-11-2015, 23:59
  2. Problemas en el render result
    Por Gabriel_Arg en el foro Render, Iluminación y Cámaras
    Último mensaje: 13-07-2015, 20:44
  3. Autodesk Maya 2016
    Por 3dpoder en el foro Programas de Diseño gráfico y CAD
    Último mensaje: 13-05-2015, 10:16
  4. Autodesk Mudbox 2016
    Último mensaje: 13-04-2015, 10:34
  5. Install plugin 32 bits en 3ds Max 64 bits
    Por akull en el foro Problemas con Programas
    Último mensaje: 04-12-2009, 22:58
