ASSET BROWSER: LIBRERÍA DE POSES! - Blender Hoy LIVE #158
https://www.youtube.com/watch?v=3_cV47CMBDA
Versión para imprimir
AUTOSMOOTH RÁPIDO - Blender Hoy LIVE #159
https://www.youtube.com/watch?v=lFchT88BxF8
MEJORAS DE UI - Blender Hoy LIVE #160
https://www.youtube.com/watch?v=OiS_QWzyeCc
IMPORTAR U$D - Blender Hoy LIVE #161
https://www.youtube.com/watch?v=aFXIiAuAkos
Lo más notable:
USD: add USD importer
This is an initial implementation of a USD importer.
This work is comprised of Tangent Animation's open source USD importer,
combined with features @Michael Kowalski (makowalski) had implemented.
The design is very similar to the approach taken in the Alembic
importer. The core functionality resides in a collection of "reader"
classes, each of which is responsible for converting an instance of a
USD prim to the corresponding Blender Object representation.
The flow of control for the conversion can be followed in the
import_startjob() and import_endjob() functions in usd_capi.cc.
The USDStageReader class is responsible for traversing the USD stage
and instantiating the appropriate readers.
Reviewed By: sybren, HooglyBoogly
Differential Revision: https://developer.blender.org/D10700
MULTI-CUCHILLO 🔪 Blender Hoy LIVE #162
https://www.youtube.com/watch?v=VoOVQTj_HPw
https://developer.blender.org/rB49ea...8d0e06e6d4049e
COMPRESIÓN ~ Blender Hoy LIVE #163
https://www.youtube.com/watch?v=BLxYBDD0M_M
SOBREESCRIBIR en VSE | Blender Hoy LIVE #164
https://www.youtube.com/watch?v=cFL6Rl6yb38
GREASE PENCIL SUAVE | Blender Hoy LIVE #165
https://youtu.be/1fNR-YC0k3w
GEOMETRY TODO | Blender Hoy LIVE #166
https://youtu.be/Bie5EITTwNs
GEOMETRY NODES
Geometry Nodes: Support modifier on curve objects https://developer.blender.org/rBb9feb...
Geometry Nodes: support for geometry instancing https://developer.blender.org/rB5a9a1...
Geometry Nodes: fields and anonymous attributes https://developer.blender.org/rBbf47f...
Geometry Nodes: Allow exposing color sockets to the modifier https://developer.blender.org/rBb4fd8...
Geometry Nodes: Support "Evaluated" mode in Resample Curve node https://developer.blender.org/rBd475f...
USER INTERFACE
UI: Area Split and Join Mouse Cursor Feedback https://developer.blender.org/D11396
Fix T90317: Confusing File Browser Preferences https://developer.blender.org/D12436
GPencil: Replace temp icons for final design LineArt,Length, Dot-Dash https://developer.blender.org/rBd9ad7...
Implement generic slider in graph_slider_ops https://developer.blender.org/D9361
Rename options for Quad View to be more readable https://developer.blender.org/D12381
Asset: Dropping Material assets on material slot under mouse cursor. https://developer.blender.org/rB54f5c...
PERFORMANCE
Fix T90825: Performance texture painting with limited scale. https://developer.blender.org/D12388
Anim: Keylist drawing optimization by using arrays. https://developer.blender.org/rB60cfd...
T78995: Enable keylist threaded drawing. https://developer.blender.org/rB7f1fe...
Fluid: 16% increase in performance Parallelizations for Mantaflow functions https://developer.blender.org/D12002
POTPOURRI
Modifiers: export motion blur velocity through attribute https://developer.blender.org/rB128eb...
Mesh Cache Modifier: add support for vertex groups https://developer.blender.org/rBc8f80...
BLI: Add Cycles compatible Perlin noise https://developer.blender.org/rBa1167...
XR: Re-enable SteamVR OpenGL backend for AMD gpus https://developer.blender.org/rB82ab2...
CYCLES X
Cycles X: Bring back tiles support https://developer.blender.org/rBcaee3...
Cycles X: Use GPUDisplay for non-interactive render https://developer.blender.org/rB8d6a8... ️
DOT DASH | Blender Hoy LIVE #167
https://www.youtube.com/watch?v=SnMSy7k3xAg
GEOMETRY NODES
Geometry Nodes: new Realize Instances node https://developer.blender.org/rB7da9d...
Geometry Nodes: support Set Position node on instances https://developer.blender.org/rB8c7c4...
Geometry Nodes: support Noise Texture node https://developer.blender.org/rBfc4f8...
Geometry Nodes: Transfer attributes in the curve to mesh node https://developer.blender.org/rBf81ba...
Geometry Nodes: Add a toggle to use attributes as input values https://developer.blender.org/rB8e21d...
Geometry Nodes: multi threaded field evaluation https://developer.blender.org/rBe6ca0...
Geometry Nodes: Add fields version of material nodes https://developer.blender.org/rB09f14...
ASSET BROWSER
Assets: Recursive reading of asset libraries https://developer.blender.org/rBc9daa...
UI
UI: keep navigation gizmos visible during modal operators https://developer.blender.org/rB917a9...
UI: wait for input for operators that depend on cursor location https://developer.blender.org/rBda2ba...
UI: split screenshot area into a separate operator
UI: enable the depend-on-cursor flag for some operators https://developer.blender.org/rBf8b51...
UI: expose "Lasso Select" & "Extrude to Cursor" in menus https://developer.blender.org/rB8bc27...
UI: Freestyle UI Upgrade https://developer.blender.org/rB6f52e...
UI: Automatic Blend Thumbnail Selection https://developer.blender.org/rB4fa0b...
Asset Template: Extra UI options https://developer.blender.org/rB3ff60...
App Settings: Edge Resize https://developer.blender.org/rB867e6...
App Settings: Regions Visbility Toggle https://developer.blender.org/rBf2cfa...
UI: Remove Menus & Show Wait Cursor When Saving https://developer.blender.org/D12507
UI: Always Create Asset Previews https://developer.blender.org/rB6cf73...
GREASE PENCIL
Line Art feature update: Automatic crease with flat/smooth surfaces https://developer.blender.org/D12051
GPencil: Dot dash modifier. https://developer.blender.org/rBa2c5c...
COMPOSITOR
Compositor: Add OIDN prefiltering option to Denoise node https://developer.blender.org/rB276ee...
FIXES
Fix straight line gesture snapping not working for modal tools https://developer.blender.org/rB503d7...
Fix T85564: FCurve modifier zero influence on restrict range borders https://developer.blender.org/rB9dee0...
ADD-ONS
Rigify: support executing an arbitrary script after generation https://developer.blender.org/rBAecf3...
CYCLES X
Cycles X: set integrator state size relative to the number of GPU cores https://developer.blender.org/rB22717...
Cycles X: Improve performance of transparent shadows with OptiX https://developer.blender.org/rBcad00...
BLENDER NUEVO | Blender Hoy LIVE #168
https://youtu.be/dgpy0z3wVV4
CYCLES
Cycles: merge of cycles-x branch, a major update to the renderer https://developer.blender.org/rB08031...
Hair Info Length Attribute https://developer.blender.org/rB6a88f...
VSE
Increase VSE strip channels limit from 32 to 128 https://developer.blender.org/rB8fecc...
Strip Thumbnails https://developer.blender.org/rB997b5...
VSE: Image transform tools https://developer.blender.org/rBfa2c1...
Fix T91666: Missing pivot point in VSE https://developer.blender.org/rBf9e09...
VSE: Expose Zoom to Fit in all display modes https://developer.blender.org/rBad3e5...
MODELING
Applying patch D12600, GSOC Knife Tools branch https://developer.blender.org/D12600
Knife: Expose XYZ axis locking in modal keymap https://developer.blender.org/rB93b36...
PERFORMANCE
FileBrowser: Reduce Overhead Browsing Libraries. https://developer.blender.org/rBfc7be...
Assets: Read catalogs immediately when loading a library https://developer.blender.org/rBc87e6...
GREASE PENCIL
GPencil: Curvature support for length modifier https://developer.blender.org/rB2e6a7...
LineArt: Smooth tolerance value for chaining. https://developer.blender.org/D12050
GPencil: Split Weight modifier in two to make more consistent https://developer.blender.org/rB368b5...
GPencil: Reorganize list of modifiers https://developer.blender.org/rB9cf59...
UI
Keymap: preference for keys to set the active tool https://developer.blender.org/rBf5c60...
Keymap: preference for Alt-LMB to use the active tool https://developer.blender.org/rB8b8a6...
UI: keymap preference tweaks https://developer.blender.org/rB599d9...
Keymap: preference for fallback-tool with RMB select https://developer.blender.org/rBc9d9b...
Keymap: RMB select option to place cursor on Alt-LMB https://developer.blender.org/rB83975...
UI: Style drag-drop indicators as tooltips https://developer.blender.org/rB499db...
UI: Change "Favorites" to "Bookmarks" https://developer.blender.org/rBa79c3...
Custom Properties: Rewrite edit operator, improve UX https://developer.blender.org/rBbf948...
UI: Add description for Batch rename https://developer.blender.org/D12594
UI: Tree-View API for easy creation of tree UIs https://developer.blender.org/rB323fd...
LIBRARIES
LibOverride: Add utils to convert all proxies to overrides. https://developer.blender.org/rBcdcdd...
LibOverride: Deprecate Proxies: Add auto-conversion on file load. https://developer.blender.org/rB501b0...
LibOverride: deprecate Proxies: Remove 'Make Proxy' operator. https://developer.blender.org/rB59387...
ANIMATION
Animation: Pose Slide Operator - Blend to Neighbour https://developer.blender.org/rBf7a49...
RIGGING
Weight Paint Gradient tool: expose falloff to the UI https://developer.blender.org/rBf8a0e...
Rigify: support generating mirrored linked duplicate widgets. https://developer.blender.org/rBAeed6...
ADD-ONS
Auto Tile Size: remove the add-on after the cycles-x merge https://developer.blender.org/rBA20cb...
POTPOURRI
3DView: Use "real" angle for viewport roll https://developer.blender.org/D12582
3DView: ability to cancel out of viewport roll https://developer.blender.org/rB5d550...
¡MEJORAS DE UV! | Blender Hoy LIVE #169
https://www.youtube.com/watch?v=nybI0yTlx_A
¡ASSET BROWSER MEJORADO! | Blender Hoy LIVE #170
https://www.youtube.com/watch?v=ph3vDbuXPNQ
NODOS POR DOQUIER | Blender Hoy LIVE #171
https://www.youtube.com/watch?v=DxiMUq9r0FA
