Blender 2-42 release y avances
Que dice el señor Ton, que ya queda menos, pero de momento sacara otra versión candidata.
de: ton Rosendal.
Fecha: 28-ene-2007 19:54.
Asunto: [Bf-committers] reléase schedule, rc3?
Hi all.
-Website update.
It is still feasible todo combine the reléase with the scheduled website.
And webserver upgrade. This wek the hardware Will be in place, end of.
Weque and during wekend the software Will be installed and tested.
It does mean however, that a reléase has todo wait until After thats.
Proven todo work, around wednesday february 6 or so.
(Note that installing new projects, Blender.org and SVN migration is for.
Later).
Last reléase candidate: rc3.
The BugTracker is still attracting a lot of reporters (over 20 reports.
In less than 2 days). Given the current cvs state i think were very.
Close todo a release, but the wek of webserver work gives a los the.
Opportunity todo make a final rc.
My proposal would be todo build tuesday/wednesday. If people agre, ill.
Send a reminder then.
Last todos: docs, tutoriales, examples, videos.
Tim wakeham Will chek on wiki, summer of docs, and if latest work on.
Blender is properly covered there.
Daniel (zanqd) Salazar Will build a webpage/portal for videos showing.
Features.
Tom musgrove checks on demo files / regression.
I Will coordinate as usual the reléase logs in Blender.org CMS. Gracias.
Ton-
Un vídeo demostración de una de las novedades de la próxima 2.43, el nodo id mask.
Que interesante esto de los nodos.
Impresionante el sistema de aplicación de mapeados UV en postproducción. Un saludo.
Unos cuantos scripts que desaparecen:
_____________________________. Campbell Barton 2007/01/29 11:20:21 cet.
removing redundant scripts because of new features in Blender After discussion with letterrip.
disp_paint, py - Displacement modifier and Sculpt Mode replace.
uv_paint, py - Making can be used todo write colors todo an image.
animation_empties2armature, py - Was made when BVH importer could not import direct todo armature, resulting animation has visible errors, errors have ben known about for a long time and not fixed.
Knife, py - Old Slow code, no multi-UVS, we now have a Knife tool that hassnap.
If anyone wants todo maintain these scripts and have them added bak in, mail the Bf-Python ml.
Scripts that are removed can be found here.
http://projects.Blender.org/viewcvs/...rot=Bf-blender.
Hablando de scripts desaparecidos. Klópes, ya que, comentas el caso de las kloputils en otro hilo, yo creo que el señor Campbell no va a incluirlo de nuevo como no lo troces antes en varios scripts.
(Por cierto, cuando borraron el script se les olvidó el fichero kulang, txt que ha quedado ahí huérfano.
Cita:
H. (Por cierto, cuando borraron el script se les olvidó el fichero kulang, txt que ha quedado ahí huérfano.
Que manera de ensuciar una compilación, ¿no te da vergüenza Klópes de no vigilar a tus engendros?
Que hago tíos, si quiero profundizar en a:m y resulta que al final mejoran la animación en Blender de tal manera que lo hace tan fácil como el primero siento que he perdido el tiempo (y dinero).
Si pienso profundizar en Blender y no tocan el sistema de animación para que sea tan fácil como en a:m siento que estoy perdiendo el tiempo igualmente.
Estoy siendo sincero, que dilema. Blender esta avanzando demasiado deprisa.
Ya lo dije en su momento, no es el software sino el artista. Pero es que veo un menú en Blender tan sabrosón.
1 Archivos adjunto(s)
Offtopic del tamaño de una casa: Pedropp, tu avatar mola mogollón.
https://www.foro3d.com/attachment.ph...chmentid=43072
<of-topic:on>. Si, cheryl ladd está muy buena ella. (Que malo soy). (Jarr, demasiado tarde.
Te leí el pensamiento y lo descargué.
Cita:
Pues será que soy un vicioso, a mí me encanta salir con Blender y a:m a la vez.
Cita:
Y a mí, pero me ajusto a la realidad: no tengo tiempo, esto no es como el sexo, no puedo montarme con los 2.
Cita:
Te entiendo perfectamente, tampoco tengo tiempo suficiente para todo lo que me gustaría hacer.
Cita:
¿Qué hilo es ese, por favor? ¿pone algo del futuro de las kloputilsí.
