Página 25 de 30 PrimerPrimer ... 152324252627 ... ÚltimoÚltimo
Resultados 361 al 375 de 436
Tema: Blender 2.41 release y avances
  1. #361
    Dec 2003
    Blender 2-41 release y avances
    Guay, así que, en dos semanas nueva release, buenas noticias (, y a partir de entonces a esperar como agua de mayo los avances del Google soc). Gracias Koex, un saludo.
    Cuiño, cuiiiiño!!!!
  2. #362
    Ton Rosendal 2006/06/12 16:39:08 cest. New característica. (well, replacement for the exisiting cumbersome Dispview). Next todo the dispwindow there are now two new choices:
    -Display render output todo image editor.
    Display render output todo screen-sized image editor.
    Both options wont open a 2nd window anymore, which makes work quite more.
    Smooth Even, especially because focus isnt lost. Further it fits in the.
    Single window UI paradigm of Blender. Should have ben done 10 years ago.
    Lastly it might bypass issues with x11, having 2 Windows with OpenGL.
    Context is not always stable in Linux.
    This option uses an idéntical trik as for the compositor viewer, using an.
    Image block with a fixed name (render result).
    The flow, when invoking a render, goes as follows:
    -First it checks if there an image editor visible displaying the render.
    Result, if so then it uses that Area-window.
    (Use this option for Dual-monitor setups for example, a render Will always.
    Go todo the same location then).
    Else it checks if there an image editor open in general, it then.
    Assigns that window the render result image.
    Else: it searches for the largest área in the screen, and turns that into.
    A temporal image editor showing render output.
    After a render, an Esc Will push bak the former view, if the área type has.
    Changed.
    Same rules apply for the full screen option. Here an Esc Will always go.
    Bak todo the regular screen, and restore área type if required.
    While rendering, the queue for the renderwindow isnt handled yet, so you can.
    Not zoom (nor get full redraws), as for the regular render window.
    Existing conflicts:
    -In faceselect mode, the image editor enforces todo display the face texture.
    After rendering again.
    -When using an image window for compositing, youll lose the viewer output.
    On a render.
    Implementation note:
    While rendering updates, nothing is drawn in frontbuffer anymore. Thats.
    God news for b0rked OpenGL drivers (and faster). However, for the few.
    OpenGl cards that dont do a swap copy but a swap exchange you get.
    Issues, has todo be worked on. Im afraid we have todo drop frontbuffer.
    Drawing altogether.
    Other fixes:
    -Hotkeys Numpad 1, 2, 4, 8 Will set zoom levels (was half coded only?)
    Use shift todo zoom out (smaller).
    Rendering Tile updates still had draw errors on Edges of tiles, in osa.
    Only. (caused by commit 4 days ago).
  3. #363
    Jan 2004
    Blender Blender 2-41 release y avances
    Hola gente. Yo ya sculpo en Blender, y tú?
    Http://www.Megaupload.com/octogono/? D=bl9fryqd
    Solo está el binario Blender-Sculpt, exe para usar en conjunción con la compilación que subí el 09-06-06 (o cualquier otra reciente), solo hay que copiarlo en el directorio y ejecutarlo.
    Compilado con mingw.
    Modo de uso:
    Para activar el modo Sculpt, desplegar el menú de selección de modo (object mode, Edit Mode, weight Paint.) y seleccionar Sculpt Mode. Las opciones disponibles están en el menú edición (f9).
    Aún no es muy usable, pero está bien para empezar a trastear. Saludos. .
Nombre: 130606shoot-1.jpg
Visitas: 84
Tamaño: 125.8 KB
    Última edición por koex; 13-06-2006 a las 15:00
  4. #364
    Dec 2003
    Anda la osa, así que, ya ha empezado? Bajando. Gracias Koex. Un saludo.
    Cuiño, cuiiiiño!!!!
  5. #365
    Vaya. Para mí ya está muy bien: acaba de empezar y ya esculpe con texturas y todo sé de alguien que hizo un script que no estará muy contento con la noticia.
    ...y estaba superbueno.
    Dos niñas en el parque
    no se elevará, nunca más
  6. #366
    Koex, como ya te he comentado esa compilación con Sculpt no funciona bajo mi ventanas XP. Me gustaría saber si alguien con el mismo so que yo se encuentra con ese problema. Si no me equivocó esa imagen que has adjuntado esta capturada con la compañero corriendo bajo Linux.
  7. #367
    Jan 2004
    No, no, la captura esta echa bajo Windows equispé. Ya digo, que aún no es muy usable, habrá que esperar a que evolucione. Saludos.
  8. #368
    Vaya, por que no suben las compilaciones a http://www.graphicallorg? Intenté bajarla, pero parece que por el momento no hay conexiones disponibles para mí ciudad. Saludos.
  9. #369
    Jan 2004
    Tienes toda la razón Matai, soy consciente de que según en que países es casi imposible descargar de Megaupload, com. Ya he hablado con Zanqdo y a partir de ahora las subiré en graphicall, org. Un abrazo compañero.
  10. #370
    Tienes toda la razón Matai, soy consciente de que según en que países es casi imposible descargar de Megaupload, com. Ya he hablado con Zanqdo y a partir de ahora las subiré en graphicall, org. Un abrazo compañero. Gracias Koex, ya la he descargado de graphicall, incluso ya hice mi primer chorrada con las sculpting tools se ven bien, apenas empieza, pero me gustó mucho, estaré atento.
    No se rían, esta es mi prueba con las sculpting tools, seguiré probando. Saludos.
  11. #371
    Feb 2006
    A ver, ya probé lo que va de las herramientas de escultura y puedo decir que ocurrió lo que me esperaba: con tantos polígonos es intrabajable.
    Si lo que se espera es simplemente un traspaso de las características de sharpconstruct a Blender, entonces no van a servir de nada salvo que se tenga una tarjeta de video monstruosa (porque trabajar en modo wireframe es ridículo). Ojalá que no sea así y se modifique de alguna manera la estructura de las mallas mientras se esculpe.
    Última edición por Duhast; 14-06-2006 a las 03:53
  12. #372
    Jan 2004
    Hola gente.compilación del cvs de hace un rato : http://www.graphicall.org/builds/bui...on=show&id=150
    - Fecha 15/06/06
    - Compilado con visualc++ express. para Windows.
    - No tiene parches aplicados.
    - Aquí podéis ver los logs.
    - Recomiendo el uso para testear nuevas features, no para producción. Saludos. .
  13. #373
    Grande grande. Ahora podemos dimensionar numéricamente las mallas, en medidas absolutas.
    (por fin. Y, por cierto, otra paridilla obsoleta en el klopútils gsef).
Nombre: Untitled.jpg
Visitas: 89
Tamaño: 9.6 KB
  14. #374
    Dec 2003
    Qué guay. (.cómic sans? Un saludo.
    Cuiño, cuiiiiño!!!!
  15. #375
    Y colores fashion.
    30 años de Star Wars
  1. Blender 2.77 release y avances
    Respuestas: 50
    : 30-09-2016, 15:24
  2. Blender 2.74: release y avances
    Respuestas: 29
    : 21-06-2015, 08:04
  3. Blender 2.69 release y avances
    Respuestas: 65
    : 19-03-2014, 23:39
  4. Blender 2.58 release y avances
    Respuestas: 128
    : 16-08-2011, 19:04
  5. Blender 2.46 release y avances
    Respuestas: 267
    : 24-08-2008, 12:21
