Campbell Barton 2007/03/19 04:22:43 cet.
added Mesh skin todo the face key menú and added a Python slot here.
este mensaje de Joshua parece algo estropeado.
Joshua leung 2007/03/19 08:32:37 cet.
== preview range ==
Preview range is a useful tool for animating (espcially on longer timelines). It allows you todo only run th rouge a limited set of frames todo quickly preview the timing of a section of movement without going th rouge the whole timeline. It means you dont have todo set/reset start/end frame for rendering everytime you wish todo only preview a región of frames.
Hi ton.
Attached is a patch (i know youve already got Lots of them in the tracker) for a característica that ive sometimes wanted. It sems that this sort of thing is supported in other packages, but i cant be sure.
Note: i may have left in a few bits and pieces i didnt mean todo in the patch (this is of a source tree which had quite a few revisións in it, all of which was experimental).
== preview range ==
Preview range is useful for animating (espcially on longer timelines). It allows you todo only run th rouge a limited set of frames todo quickly preview the timing of a section of movement without going th rouge the whole timeline. It means you dont have todo set/reset start/end frame for rendering everytime you wish todo only preview a región of frames.
* Control p in action/nla/timeline sets preview range. Click+drag todo form selection-box defining región of frames todo preview.
* Alt p in action/nla/timeline todo clear preview range.
* pre button beside start/end Fields in timeline toggles whether start/end Fields refer todo scene or preview.
* Control rightarrow and Control leftarrow Jump todo start/end of preview región when it is set.
* s and e set the start/end frames of preview región when it is set (just like normally) in timeline only.
* in action/nla editors, frames out of preview región are now drawn darkened when preview-region is set.
Se the following page for more información later:
http://wiki.blender.org/index.php/us.../preview_range .
Ton Rosendal 2007/03/19 10:40:42 cet.
patch by juho v.
Colorband: nodes now show an add button todo.
