No se pierdan este vídeo, trae novedades importantes.... entre ellas, una sobre las CAUSTICAS.MASIVAS NOVEDADES - Blender Hoy LIVE #186
https://www.youtube.com/watch?v=wMLGFvoVXME
Blender 3.1.2! https://twitter.com/Blender/status/15...
The place https://www.reddit.com/r/place/?cx=31...
CORE
Apply Object Transform: Multi-user data support https://developer.blender.org/D14377
Modifiers: Support applying modifiers for multi-user data https://developer.blender.org/D14381
CYCLES
Cycles: Add support for light groups https://developer.blender.org/rBad354...
Cycles: approximate shadow caustics using manifold next event estimation https://developer.blender.org/rB1fb02...
Cycles: Optimize Nishita sky https://developer.blender.org/rB633c8...
VSE
VSE: Add channel headers https://developer.blender.org/rB277fa...
VSE: Use edge panning https://developer.blender.org/rBe49fe...
GREASE PENCIL
GPencil: Fading for build modifier https://developer.blender.org/D14309
GEOMETRY NODES
Geometry Nodes: Don't create node tree when adding nodes modifier https://developer.blender.org/rB08b4b...
Geometry Nodes: Remove soft min from extrude node scale https://developer.blender.org/rB4a93c...
Curves: Port resample node to the new data-block https://developer.blender.org/rB60a6f...
Geometry Nodes: Add search to named attribute input node https://developer.blender.org/D14516
NODES
Fix: Nodes: Remove hidden links when creating node groups https://developer.blender.org/D14249
UI
UI: Fix cosmetic papercuts of the reroute node https://developer.blender.org/rBee1d5...
UI: Improve node editor dot background https://developer.blender.org/D13302
Add soft limit for Bevel segments in modifier. https://developer.blender.org/D14477
ASSET BROWSER
Assets: Support automatic collection previews https://developer.blender.org/rB810e2...
Assets: Enable collection assets (no longer experimental) https://developer.blender.org/rB253e4...
Assets: Instancing operator option for collection asset dropping https://developer.blender.org/D14507
CURVES
Curves: Curve Pen https://developer.blender.org/rB33608...
Curves: improve Snake Hook brush https://developer.blender.org/D14408
Curves: support converting curves to legacy hair system https://developer.blender.org/D14441
LIBRARY OVERRIDES
LibOverride: Implement default 'user override' behavior https://developer.blender.org/rB6cc9b...
LibOverride: Add a new 'virtual' non-editable override icon and use it in Outliner https://developer.blender.org/rB9394d...
LibOverride: Rename 'delete hierarchy' to 'clear hierarchy', add 'clear single' operations. https://developer.blender.org/rB354db...
Outliner: Don't show indirectly linked Library Overrides properties https://developer.blender.org/rB8b529...
Outliner: New "Hierarchies" view mode for Library Overrides https://developer.blender.org/D14440
KEYMAP
Keymap: "Mouse Select & Move" now uses click to de-select others https://developer.blender.org/rB24997...
I/O
OBJ: New C++ based wavefront OBJ importer https://developer.blender.org/rBe6a9b...
ADD-ONS
Many glTF improvements https://wiki.blender.org/wiki/Referen...
FIXES
Fix long hangs when launching Blender with disconnected network shares https://developer.blender.org/D14506
Fix offset in icons https://developer.blender.org/rB49858...
EXPERIMENTAL
OBJ: mark the new 3.1+ exporter as experimental for now https://developer.blender.org/rBca28f...
UserDef: Add experimental flag for 3d texturing brush. https://developer.blender.org/rB3ce6c...
Minuto 20 mas o menos.
Sin cáusticas... con cáusticas
