Página 29 de 39 PrimerPrimer ... 192728293031 ... ÚltimoÚltimo
Resultados 421 al 435 de 581
Tema: Blender actualidad y avances
  1. #421
    Que viene, que viene.
    Facelop collapse. This would allow for the current selection todo be evalúated and collapsed if it mets the facelop criteria.
    Facelop Cut.
    The idea here would be todo make Edge loop Cut a more blenderish action, by removing selection from the tool. The tool would Cut the existing selection if it is a valid facelop. Then it would a los remove the % lopcut from this action, but instead enter Edge slide mode After the Cut.
    The second option would be todo select the number of loops todo Cut into the facelop. They would be evenly spaced After cutting.
  2. #422
    Edge slide. There has ben some god work on edgeslide in the python_ área lately. And incorperating it into this toolset would make rewriting facelop % Cut much nicer, since i want todo seperate the % Cut característica into it own tool, making the lopcut less comlplex. This tool Will allow for a single Edge or an Edge Loop todo be slid along the perpendicular face Edges.
    Point slide.
    If the user were todo choose the slide tool, but has only one vertex selected, it would trigger a point slide mode.
    Edgering select.
    This is similar todo facelop select except it selects the inner Edges of the Faces only and not the outer rings.
    Y más.
Nombre: Connect.jpg
Visitas: 57
Tamaño: 47.9 KB
    Última edición por 3dpoder; 05-04-2005 a las 22:00 Razón: Tambien podemos usar el adjuntar imagenes del foro, para poder conservar mejor las mismas, gracias.
  3. #423
    Ahora sé porque este foro no me dejaba publicar los quotes, cualquier texto que incluya la palabra Python sin las comillas se va al garete a la hora de publicar.
  4. #424
    El anterior foro tampoco le gustaba la palabreja, será porque se usa mucho en Blender y los enemi, microso, discre, ali, no les int, qu, avance, c, él.
  5. #425
    Python.
  6. #426
    Phyton caca pito chocho puta.
  7. #427
    Vaya, pues censurada no esta.
  8. #428
    Jun 2003
    Claro, escribiéndolo mal, cualquiera.
  9. #429
    ¿Qué ¿no? Es Python, no Python. Al colgar me sale una pantalla negra con un mensaje de que no se ha encontrado el hilo o foro (no recuerdo) y se vuelve al index general sin publicar.
  10. #430
    Vale ya he descubierto el problema. Tenéis que desinstalar Blender de Hd y poner un txt en la carpeta raíz de c:, escribiendo. No lo volveré a instalar, me portare bien.
    Información por Python.
  11. #431
    Esa última captura es de Blender? No intentéis colarmela que Martín Krol no usa Blender, o si? En la intimidad?
  12. #432
    Sep 2004
    www.artificial3d.com -por si se crítica a Blender. Este chico si que se pasa.
Nombre: oldmanwillow.jpg
Visitas: 72
Tamaño: 213.8 KB
ID: 10992   Clic en la imagen para ver su versión completa.
Nombre: snog.jpg
Visitas: 63
Tamaño: 129.3 KB
    Última edición por batou; 02-04-2005 a las 02:09
  13. #433
    Separa los puntos suspensivos de Python y no lo pongas dentro de corchetes de quotes. Saludos.
  14. #434
    Batou no lo has pillado cuando yo diga Blender es un software de nenazas tu di max es el software de los julais es un equilibrio mutuo, si todos respetáramos el software del vecino, las compañías desarrolladoras del mismo estarían perdidas.
    J te doy la razón Leander, no sé que puede pasar, de momento escribelo entre comillas, gracias.
  15. #435
    Vaya. Recuerda que yo nunca menosprecié, menosprecio, ni menospreciaré el 3ds Max, es estupendo, solo critiqué, critico y criticaré el precio.
    ¿Queda claro?
  1. Blender 2.79 release y avances
    Respuestas: 12
    : 30-03-2018, 10:28
  2. Blender 2.68 release y avances
    Respuestas: 55
    : 31-10-2013, 23:55
  3. Blender 2.67 release y avances
    Respuestas: 57
    : 18-07-2013, 21:46
  4. Blender 2.43 release y avances
    Respuestas: 333
    : 14-05-2007, 15:32
  5. Que os parece el hilo Blender actualidad y avances
    Por Leander en el foro Noticias 3D
    : 29-01-2005, 19:18
