Log message:
2.5.
First versión of region-scaling. Wip commit, so Bear with me ha while.
All fixed sized Regions have a small drag widget, on the left or top.
(not yet for free-sized Regions, like 4-Split).
- Mouse-over on widget changes cursor and allows drag.
- Click on widget hides/reveals.
- Fun for test; 3d view Header, if high enough, draws more rows of.
Buttons when width is todo small.
The wip Stuff;
- It doesnt save yet in files, using the minsize variable of region.
Definitions, a los means other similar áreas show same sizes now.
- Definitions for pref size, mínimo/máximo Will be added.
- Properties panel in fcurve window draws widget on wrong place when.
Hidden (subdiv system neds tweak)
- Widgets dont draw perfecto yet, a los neds further tweaks.
But, in general it quite fun and usable. Many variatians are posible, like for real tabs, or Little icons, or just click-drag on edge.
The reason todo first try the widget/tab variation:
- It re-uses the Area action zone code, widgets for layouting screens.
- It visible, hotkey-only options for screen layouts are not preferred.
- Distinguish clearly Area-Edges from region-Edges this way. Having the.
Cursor change shape on every Edge (and block input) is probably annoying.
To, but that can be tested.
Later more.
